6th February 2010, 12:03 | #101 | Link |
There seems to be a problem with DTS ES and AC3 EX Audio tracks. They are reported as "unknown" and can not be encoded or demuxed/remuxed.
Even if selected, BluRip reports "No audio streams selected" when pressing "start". Source is a Pixar Shorts BluRay-Disc. Thank you very much for this program and keep up the good work! |
6th February 2010, 12:41 | #102 | Link |
BluRip author
Can you send me the log after getting the streamlist? I'll add the audio types to the list of known types.
BluRip : 1-Click BluRay/m2ts to h264 mkv converter http://code.google.com/p/blurip/ |
7th February 2010, 11:16 | #104 | Link | |
[07.02.2010 11:14:05] ------------------------------------------------------------------------------- M2TS, 1 video track, 1 audio track, 0:04:43, 24p /1.001 [07.02.2010 11:14:05] 1: h264/AVC, 1080p24 /1.001 (16:9) [07.02.2010 11:14:05] 2: AC3 EX, German, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB [07.02.2010 11:14:06] Done. Won´t help much - The log is ok. But AC3 EX and DTS ES Audio tracks do not work. Stream selection windows reports "unknown" audio. |
8th February 2010, 09:01 | #105 | Link |
BluRip author
Because I rely on string parsing I need the exact spelling. That's why I asked for the log
9th February 2010, 00:38 | #106 | Link |
@_hawk_
can you make the main window adjustable so stream info displays completely?
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo Last edited by MuLTiTaSK; 9th February 2010 at 04:24. |
9th February 2010, 05:10 | #107 | Link | |
I'm getting this error: "Failed to get stream info" !!!
9th February 2010, 05:16 | #108 | Link |
@rmd3003
where is your source?
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo |
9th February 2010, 05:18 | #109 | Link |
@rmd3003
update to the lastest version check first post
9th February 2010, 06:22 | #111 | Link |
@rmd3003
are you running AnyDVD HD?
9th February 2010, 09:00 | #112 | Link | |
BluRip author
Atm there is no option to edit the queued projects. You can save alle projects before queue and open & edit them and queue again deleting the old one.. Maybe I'll find a better solution.
9th February 2010, 09:01 | #113 | Link |
BluRip author
Maybe I can add a horizontal scroll bar. I'll check this..
9th February 2010, 09:03 | #114 | Link | |
BluRip author
You'll need external tools to do this. There's a hint under usefull tools.. You can adjust size when using 2-pass mode. You have to specify the bitrate yourself then. I'll add a bitrate calculator later..
9th February 2010, 09:14 | #115 | Link |
@_hawk_
scroll bar would be perfect .srt subtitles import support?
9th February 2010, 09:36 | #116 | Link | |
BluRip author
Won't be possible to do automatic srt creation.. Goal of BluRip was automatic conversion. Would love to have a good working sup->srt tool..
9th February 2010, 10:00 | #117 | Link |
@_hawk_
that makes two of us ocring is a pain but necessary and SupRip helps get the job done but hopefully someone codes a automated command line tool soon to simplify the process
9th February 2010, 10:16 | #118 | Link | |
BluRip author
If you have a 12gb file (video+audio) 50mb for bmp subs don't matter. For txt subs you may always get error when ocr isn't working 100%. And I don't want to read and correct all subs by hand.
10th February 2010, 22:16 | #119 | Link |
would this be a X264 problem or not?
[2/10/2010 4:07:14 PM] [33.5%] 56100/167704 frames, 7.63 fps, 5877.92 kb/s, eta 4:03:43 [2/10/2010 4:07:23 PM] Exception: Thread was being aborted. [2/10/2010 4:07:24 PM] Exception: Object reference not set to an instance of an object. [2/10/2010 4:07:31 PM] [2/10/2010 4:07:31 PM] x264 [info]: frame I:478 Avg QP:15.75 size:178352 |
11th February 2010, 06:48 | #120 | Link |
@mackworth
did you try to cancel the encode?
blu-ray, blurip, eac3to, ffms2, mkv, mkvtoolnix, x264 |
