9th August 2022, 13:50 | #19561 | Link |
I suspect that some device is waking up your pc. Mouse, keyboard and so on... Windows should also have some logs showing what woke up your device.
https://www.minitool.com/news/find-w...-computer.html
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 9th August 2022 at 13:52. |
9th August 2022, 19:14 | #19562 | Link | |
the only thing apart from the lan, TV, AV reciever, UPS (via usb), is a logitech wireless keyboard. ive monitored it tonight and it stays off for about 3 mins then powers up and before it even has time to send a post screen to my TV and beep it shutsdown. so maybe 5 secs? ill trun off the keyboard and see if it stays off. |
9th August 2022, 23:57 | #19564 | Link |
Like i said you should check logs in event viewer.
When in sleep mode poweroff your pc and then check logs
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 9th August 2022 at 23:59. |
10th August 2022, 11:38 | #19566 | Link | |
Then open EVENT VIEWER an check this entry
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 10th August 2022 at 11:41. |
12th August 2022, 11:11 | #19567 | Link | |
next problem after going to sleep at 19:00 yesterday it didnt wake up this morning at 7:00. so tried WOL and it woke then shutdown. so pressed the power button and it woke from sleep. ripbot says its suspended till tomorrow at 7:00. so i tried changing my clock to 6:58 the next day and it goto 7:00 and nothing, that was while i was logged in not in sleep mode. |
12th August 2022, 13:43 | #19568 | Link | |
https://www.mediafire.com/file/0ndbx...ot264.exe/file BTW. Thank you for reporting that issue.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 12th August 2022 at 15:34. |
16th August 2022, 08:25 | #19569 | Link |
Formally known as .......
Feature additions request for Batch, and LUT problem..
Hi Atak,
I have been using the Batch feature a lot recently, and I have several series that need a particular aspect ratio, and I cannot add it when using Batch, the closest is "Auto Height" which doesn't produce the desired results. Could you please add an option like the Custom setting, in the single job settings :- Custom x,xx:1, so you type in exactly what is needed ?? EDIT:- I've just noticed that it would also be handy to be able to select a "Colour" option, so you could import a LUT (.cube). EDIT #2:- So now that I am trying to use LUT's, I am now getting an error in Encoding Server...but this is when using a "custom" .cube created with Adobe Premiere It will work in MPC-HC "preview", but when starting the encode, I get this :- Code:
y4m [error]: bad sequence header magic x264 [error]: could not open input file Last edited by TDS; 17th August 2022 at 03:29. |
20th August 2022, 14:12 | #19570 | Link | |
21st August 2022, 14:46 | #19571 | Link |
I just got a small Auto update, and it's really only been "core.exe", and MKVToolNix 70.0 (which didn't download properly) but I can't figure out what might have changed.
Any explanation ??? Cheers EDIT:- On further investigation, it appears that the LUT folder has been moved from the "Profiles" folder, to "AviSynth plugins/avscube/LUT", for whatever reason. No changes in the Batch settings Last edited by TDS; 22nd August 2022 at 05:44. |
22nd August 2022, 10:40 | #19572 | Link | |
22nd August 2022, 11:46 | #19574 | Link | |
one thought do i need to clear the schedule and reapply it? as i just updated ripbot and left the work hours as they were in the list. |
22nd August 2022, 11:58 | #19575 | Link | |
Clear the schedule, you've got nothing to lose... I would suggest with all the issues you're having that you just forget about it, and do something else to control your encoding time. |
22nd August 2022, 17:32 | #19577 | Link | |
for example Code:
"2022-08-22 16:00";"2022-08-22 16:01" "2022-08-22 16:02";"2022-08-22 16:03"
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 22nd August 2022 at 17:35. |
23rd August 2022, 07:45 | #19578 | Link | |
If you could please add the above features to the Batch process, would finish it off nicely. |
25th August 2022, 02:27 | #19579 | Link |
Custom Audio Scripts
Hi Atak,
So most of us are aware that Custom Scripts are generally for video adjustments etc, but I don't think you can create/change audio scripts the same way. I tried to add a delay in the audio, and added it to an existing video custom script, AVSMeter didn't want to know about it, and just stopped. In the "Show Audio Script" window, there are several # category's:- #Audio Source #Delay #Tempo #Normalize # Audio Dub Could you please advise how this might be achieved ?? |
25th August 2022, 16:44 | #19580 | Link | |
#Return DelayAudio(1)
