Old 30th May 2013, 18:43   #1  |  Link
fibonacci
Video encoding with 10+ passes
I just wondering, would the dvd video quality better if i encoded with 20 passes of cce than 10 passes? or worth it anyway encoding video with more than 10 passes::
fibonacci is offline   Reply With Quote
Old 30th May 2013, 20:37   #2  |  Link
ggtop
More than 3 passes are overkill IMO with CCE. This has been discussed many times in the past.
But of course you could do some test encodings and compare them. If the result is worth to wait a few days for a DVD encoding go for it Would also be useful if you don't have to pay for electricity...
ggtop
ggtop is offline   Reply With Quote
Old 31st May 2013, 00:56   #3  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
I found 10 to make "busy" scenes very messy.
I did a small test with a scene from Cutthroat Island (Blu-ray to DVD).
The scene was a ballroom party with thousands of people. (lots of edges)
More than 3 or 4 just produced a lot of noise and didn't look pretty.
When zoomed in to the max on MPC-HC.
But then, with CCE, there's other options you can play with other the number of passes.
Which require a lot of testing.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Old 31st May 2013, 01:55   #4  |  Link
jdobbs
In fact, at one time the CCE manual stated clearly that anything over 3 passes didn't show a difference -- but in the later releases they removed that note. In reality everything needed to make the best backup at a given bitrate can be obtained in two passes -- one to collect the information needed, and one to use that information for final encoding. There is a word for CCE passes over 3 -- placebo.
Website: www.jdobbs.net
Old 31st May 2013, 14:39   #5  |  Link
fibonacci
ggtop
no need to wait days i encode dvd9 to dvd5 with 15 passes no more than 2 hrs
Old 31st May 2013, 18:43   #6  |  Link
smok3
brontosaurusrex
smok3's Avatar
so would 25 passes improve upon 20 passes or not?
certain other member
smok3 is offline   Reply With Quote
cce, dvdrebuilder, reencoding
