20th July 2020, 10:00 | #21 | Link |
Authoring BD soft (to burn) must recognize .dtshd
If not you can use : eac3to input.dtshd output.dts DTS-HD Master Audio Suite can output standard dts, without the header than make it .dtshd, but you need select Destination Format (DVD .cpt only up to 5.1). And after change the .cpt with .dts
20th July 2020, 15:50 | #22 | Link |
Big Bit Savings Now !
You would use .dtshd for BD-Authoring, so it is expected to be muxed it into .m2ts.
Burn and listen: Well, maybe .dtshd is not meant for that, although some software players indeed can play .dtshd. P.S. Ah, I was meaning to answer the last post on page 1... tebasuna51 already posted the complete solution.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 20th July 2020 at 15:52. |
24th July 2020, 21:07 | #25 | Link |
Windows 10 64 bits can run soft 32 bits, you can have Java 32 and 64 bits at same PC runing Windows 64 bits.
We need Java 32 bits because DTS-HD Master Audio Suite is a 32 bits soft.
5th August 2020, 12:22 | #34 | Link | |
DTS HD Master Audio Suite need mono wav channels like input, you can adjust the volume of each channel, before load them, with many tools: audio editors like Audacity, command line tools like eac3to, ffmpeg, ...
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 5th August 2020 at 12:26. |
