8th September 2010, 03:12 | #1 | Link |
Playing Flac to Multiple Channels
I ripped The Lord of the Rings Trilogy recently and decided I wanted to use flac for the audio. On my computer I'm set up through a S/PDIF with the single co-axle cable going to my surround sound. When I encode audio with AC3 and 640 kb/s I get audio played through all 6 channels. However, when playing a movie with an audio encoded with flac, I'm only getting audio out of the left/right and LFE.
I have Classic Media Player set up with the FFDshow audio filter. I've screwed around with settings within ffdshow, but have been unsuccessful. Mostly because I really have no idea what I'm doing. I have the mixer set up to handle 3/0/2 - 5 Channels with LFE checked. Under output I have all the boxes checked for Pass-through (S/PDIF, HDMI). My main guess is that my receiver doesn't decode a flac encoded audio file properly or something. The only way I can hear it from all channels is if I check the box for AC3 (S/PDIF encode mode) which I think basically encodes the audio on the fly to AC3 and whatever bitrate I give it (not ideal as I want the lossless audio). Is there a setting perhaps that I'm just completely missing? Or perhaps a different decoder I need installed (currently using libavcodec). Any ideas or suggestions anyone has would be much appreciated. I apologize if this is in the wrong thread, but it seemed logical to me. |
8th September 2010, 07:31 | #4 | Link |
Yes, the coax isn't suitable. However ADAT-compatible optical I/O can transport 8 channels, but it's an expensive solution (on both ends). Equally expensive is the use of 3 identical cards, so one can transport 3x2 signals at a time*; expensive because one needs at least semipro cards (resources and drivers that alow parallel function).
*This was also a workaround to get digital-out from SA-CDs (well, not soundcards but soldered chips). PS: are the FLAC files multi-channel? |
8th September 2010, 11:01 | #5 | Link |
To play FLAC 5.1 you have two options:
1) The player decode the FLAC file to PCM 5.1 and send multichannel PCM through HDMI conexion to a receiver than accept this. - Standard SPDIF conexion only support PCM 2.0 (your actual situation) - You need a receiver than accept PCM multichannel HDMI input. - At least standalone player Xtreamer can output PCM multichannel, with a PC you need the hard (full HDMI audio compatible) and the soft (maybe ffdshow, read http://forum.doom9.org/showthread.php?t=151151 ) compatible. 2) The player decode the FLAC file to PCM 5.1, make the digital to analog conversión and send the audio to the 6 analog input of a receiver. - You need a receiver with, at least, 6 channel analog input. - Standard PC audio cards can add noise (interferences, thermal, ...) to analog output, without a good audio card maybe is better recode to ac3 640 Kb/s and use the SPDIF output.
8th September 2010, 12:05 | #6 | Link |
Yes, my flac files are indeed multi-channel.
Audio Count : 141 Count of stream of this kind : 1 Kind of stream : Audio Kind of stream : Audio Stream identifier : 0 ID : 2 ID : 2 UniqueID : 458993544 Format : FLAC Format/Info : Free Lossless Audio Codec Format/Url : http://flac.sourceforge.net/ Format_Commercial : FLAC Codec ID : A_FLAC Codec ID/Url : http://flac.sourceforge.net Codec : FLAC Codec : FLAC Codec/Family : Flac Codec/Url : http://flac.sourceforge.net Duration : 10765760 Duration : 2h 59mn Duration : 2h 59mn 25s 760ms Duration : 2h 59mn Duration : 02:59:25.760 Bit rate mode : VBR Bit rate mode : Variable Channel(s) : 6 Channel(s) : 6 channels Sampling rate : 48000 Sampling rate : 48.0 KHz SamplingCount : 516756480 Resolution : 16 Resolution : 16 bits Bit depth : 16 Bit depth : 16 bits Delay : 0 Delay : 00:00:00.000 Video delay : 0 Video0 delay : 0 Writing library : reference libFLAC 1.2.1 20070917 Writing library : libFLAC 1.2.1 (UTC 2007-09-17) Writing library/Name : libFLAC Writing library/Version : 1.2.1 Writing library/Date : UTC 2007-09-17 How would I go about converting the audio to analog over the SPDIF connection? My receiver has 5.1 or 6 channels. |
8th September 2010, 13:27 | #7 | Link |
23sKiDdOo!
in fact, thats paradox.
SPDIF transports digital Data. If it would transport Analog Data, it wouldn't be SPDIF anymore, but a simple analog connection. So in fact you have to use the A/D Converter of your Soundcard to transport 6 independent channels. As said before, there are several disadvantages to it. First of all you need a Receiver, which has 6 analog inputs (often called analog 5.1 Input, which consists of 3xStereo Connectors), additionaly you have to have a Soundcard, which has 3x2 Analog outputs (most of the actual soundcards can give you this, even the Realtek chip, if it is soldered with the appropriate Connectors). But keep in mind: If you go that way, your bottleneck is the Soundcard of your PC and the following Analog Cable.(worst setup is: Realtek Chip with cheap cables, best setup would be HiQ Soundcard with HiQ Cables) For "normal" playback you easily can go this way, but transporting a DIGITAL AC3 Stream at 640kbps via SPDIF may be the better solution, if you Audio Equipment lacks. I personally don't like the SPDIF Concept and go the Analog Way, just as years before. BTW: Don't you think the 6xPCM via SPDIF is gunning with cannons at birds? I personally do not believe you'll ever in your Life feel a significant loss of quality compared to AC3 640kbps. But in the end: It's your choice and your money... ... If you have the Money, i would firstly recommend to buy a new Sound Equipment and first of that new 4Ohm Based Loudspeakers - THAT would be a quantumjump in Quality - Soundcard and/or Encoding Issues discussed here are nearly not recognizable. I have never met a person who would be able to surely and unseen separate Ac3640 from Raw-Wav Data. Unless you have First Class Audio Equipment, you should throw your Idea away, use Ac3 and try to get lucky with that. Last edited by Hagbard23; 8th September 2010 at 13:34. |
8th September 2010, 13:34 | #9 | Link | |
Use HDMI for multichannel uncompressed audio (PCM).
You need use 6 different channels (3 stereo jacks in PC and 6 RCA input in receiver, normally)
8th September 2010, 13:52 | #10 | Link |
Well I do have an Asus O!Play, which is capable of decoding flac (not sure about 5.1 or not haven't tried it). But it also has an HDMI connector, and I assume that it will transmit the audio. Therefore, I can use the receiver I have currently hooked up to my computer and have the 5.1 PCM audio that way (hopefully). At least for now, I'll just transmit the digital audio with AC3, I doubt I'll personally notice the difference.
Although, I could have sworn when watching a blu-ray movie that I was getting the full 5.1, but my guess is that is because the SPDIF is just allowing the pass-through and not converting it at all and allowing the receiver to do all of the decoding. Do you think that might be what is happening? Again, I really don't know too much about this stuff. I've just recently started getting into it. I feel I've come a long way in about a month. EDIT: I do have some old logitech 5.1 speakers that have the 3 plugs that I could probably use for analog sound. I just figured the digital would be better. Probably because I know nothing. Last edited by patmann03; 8th September 2010 at 13:54. |
8th September 2010, 14:01 | #11 | Link |
23sKiDdOo!
It is right, that the BluRay plays at 5.1 as long as it is coded in Ac3 (which is mostly the case).
I do not know how the things look like, if the BluRay uses DTS, but since the formats are comparable, i think it would go the same way as Ac3. As said before the Bandwith of SPDIF is the problem - and this particular Bandwith is not sufficient to transport the (HUUUUUGE) 6xPCM Data, BUT it is capable of doing so with Ac3 6Ch (since it uses smaller Bandwith). One last word: If you want to transport 6xPCM/Wav via your ASUS O!Play, it does matter if it is able to transport 6xPCM via HDMI. It is of secondary interest if the ASUS is able to decode FLAC, because normally this should be done by a Filter inside your Player(software). |
8th September 2010, 14:07 | #12 | Link | |
I suppose that's another option - downmix to ProLogic / Prologic II in ffdshow. I'd stick with AC3 encoding though. |
8th September 2010, 15:59 | #14 | Link |
Banned
I think people are confusing what you can do with S/PDIF vs. what TOSLINK can now do. S/PDIF is coaxial, and you can't send 24/192 over it. TOSLINK now supports 125 mbit/s. Things were always labeled as coax and the optical both being S/PDIF because no one would ever care or know any better. But HDMI is taking both over anyway because it can do 24/192 at 8 channels, plus video.
I have some questions of my own though. What would I need to transport audio over HDMI? Say I have movies encoded with FLAC tracks and I would also want to be using mplayerc-hc to play these. Do video cards with HDMI just have an audio device driver built in to accept PCM from the bus and just stream it to HDMI then? |
8th September 2010, 16:05 | #15 | Link |
23sKiDdOo!
As Far as I Know graphic cards with HDMI Connectors have to be connected to the Soundcard as well, but i am not sure.
I can only talk about my GT9600 Video Card and they (NVidia) say, that you have to connect graphic card and sound card. Maybe there is a software solution too, but i don't know that kind... But: I am not quite sure about that. It would be helpful to hear other opinions. |
8th September 2010, 16:19 | #16 | Link |
Yes, but according to the specs, your graka needs S/P-DIF input into the adapter (DVI->HDMI), which returns us back to the initial story . I'm not sure about the HDMI add-ons (Blackmagic) whether they can reroute the digital audio to the HDMI, too, or not.
Unless your LOTR is a Bluray that has uncompressed audio, better stick with the original AC-3/DTS track. Or use the standalone to play it. |
8th September 2010, 17:18 | #17 | Link |
Yes, my LOTR is Bluray. And more than likely 99% of the time I'll be using the Bluray to watch the movie, I just wanted a digital alternative that I wouldn't feel as if I cheated on my wife with a cheap prostitute and ended up with AIDS. Which is why I wanted to go with the FLAC encode. If I can get the full 5.1 from my Asus O!Play than I think I'll be satisfied. If I were to watch it on my PC, than I would just encode on the fly with ffdshow to the AC3 format. Stupid SPDIF! Not being able to handle 5.1 uncompressed audio. What if I use optical instead of Co-axle? I have that option as well.
8th September 2010, 17:26 | #18 | Link | |
You need a [semi]pro audiocard (these have ADAT I/O) and an ADAT D/A-converter. I'm not sure about hacker solutions such as rerouting 6 channels with a normal audio card (maybe with a false header) and tweak the AVR to understand the optical signal and to play it. Should you manage, let us know. |
8th September 2010, 17:29 | #19 | Link |
Banned
Optical will handle it, but you have to find a device that is updated for the new speed it offers. It may be easier to encode to a format like DTS-HD Master or TrueHD. I think ffdshow does do TrueHD bitstreaming, but it's for HDMI and select hardware. I really don't think there is any hardware out there that expanded to the new TOSLINK standards, at least not for the PC.
8th September 2010, 18:06 | #20 | Link | |
flac 5.1 |
