Old 8th August 2020, 12:57   #41  |  Link
candela
Windows builds 32/64 bit updated in first post. Libaacs no longer requires extra patches, libbdplus still has cached table patch and now fixes Kodi playback
candela is offline   Reply With Quote
Old 8th August 2020, 15:14   #42  |  Link
jbkempf
j-b
We're focusing on improving libbluray, those days, for better menu support and misc crashes.
jbkempf is offline   Reply With Quote
Old 25th August 2020, 17:00   #43  |  Link
SilentK
Bluray playback with libaacs & libbdplus
I have followed your directions and attached a screen shot of the error messages. I have also attached the DEBUG File.
I am running Windows 10 64 bit and installed VLC 3.0.11 32 bit. I have a libre compliant drive that works with makeMKV.
I can play DVD's but not Blu Ray or 4K Blu Ray
Any help would surely be appreciated.
Thanks!
SilentK is offline   Reply With Quote
Old 27th August 2020, 07:41   #44  |  Link
candela
Thanks!
can you also upload the files on tinyupload . still cant get the attachments
Old 27th August 2020, 15:54   #45  |  Link
SilentK
Google Chrome throws a security error and won't let me upload to tinyupload. I don't know why you can't open the attachments, I can!!
Old 27th August 2020, 16:43   #46  |  Link
SilentK
It appears the attachments are pending approval. I'm not sure who approves them but that may be the reason you can not get them.
Old 27th August 2020, 16:47   #47  |  Link
SilentK
It appears the attachments are "Pending Approval". I'm not sure who approves them but that may be why you cant get them.
I tried using tinyupload and Goggle Chrome posted a security alert and would not let me upload the files.
Old 31st August 2020, 08:06   #48  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Rename them to something unsuspicious and try wetransfer.com ?
"Data reduction ? Yep, Sir. We're working on that issue. Synce invntoin uf lingöage..."
Old 1st September 2020, 02:05   #49  |  Link
DanTheMann15
zippyshare is also an option if need-be.
DanTheMann15 is offline   Reply With Quote
Old 5th September 2020, 03:27   #50  |  Link
SilentK
Have you tried to open the files I sent? I can open them perfectly. The .png is an image file and 8 ZIP is a very common zip tool that can be downloaded via google search. I don't see why I have to use any other tool. Can someone explain why I need to use another tool other than the one I am currently using?
Old 5th September 2020, 05:44   #51  |  Link
DanTheMann15
it's not the zip tool you are using, it seems that files uploaded here for some reason need to be "approved" before anyone else can download them,
which is a stupid policy when you are just trying to upload a logfile, image, or crashdump.
the only way to circumvent this is to host your attachments elsewhere and then put a link to them here,
hence why i mentioned using a free file hosting site like zippyshare, tinyupload, etc.
i hope this is helpful.
Old 24th October 2020, 19:16   #52  |  Link
jbkempf
j-b
Btw, libbluray 1.2.1 is now out.
Old 24th October 2020, 23:39   #53  |  Link
mick0
Thanks!
It seems your attachments got approved.
Logfile you attached comes from VLC and doesn't contain messages from libaacs. We would need to see the libaacs log instead.
However, from that error message we can tell that either 1) you don't have host certificates in your keyfile or 2) all host certificates in your keyfile have been revoked by your drive.
Note that for 4K blurays to work you need to use AACS1 drive with a friendly firmware. AACS2 drives require AACS2 host certificates for 4K discs. Libre compliant drive that works with makemkv doesn't necessarily mean that the drive is friendly.
mick0 is offline   Reply With Quote
Old 27th October 2020, 01:42   #54  |  Link
nuraman00
I tried the steps in the OP.
I am getting an error when I try to play the Blu-Ray.
I can't attach the log file because it says the max attachment size is 200 KB.
The log file is 3,346 KB.
nuraman00 is offline   Reply With Quote
Old 27th October 2020, 02:13   #55  |  Link
nuraman00
I zipped the log file.
Old 31st October 2020, 22:01   #56  |  Link
nuraman00
Here it is on ZippyShare.
https://www46.zippyshare.com/v/HzrkEeDC/file.html
Old 31st October 2020, 23:50   #57  |  Link
candela
Originally Posted by nuraman00 View Post
Libaacs can't retrieve the key for that disc, use FindVuk
Old 1st November 2020, 18:36   #58  |  Link
DanTheMann15
@nuraman00
you can get FindVUK here: https://forum.doom9.org/showthread.php?t=172472
and DVDFab here: https://www.dvdfab.cn/download.htm
Old 1st November 2020, 23:22   #59  |  Link
nuraman00
EDIT:
Nevermind.
Old 1st November 2020, 23:30   #60  |  Link
candela
How do you know it's looking for FindVuk? I searched through the logs for "FindVuk", but couldn't see that reference.
FindVUK is a program to extract the keys needed for playback from the commercial ripper DVDFab. Also when you run FindVUK, it synchronizes your local key database with the online database. Once someone uses FindVUK on a particular disc, the key gets added to the database and then everyone can play that disc. Since no one has added the key to the database before, you will have to do it.
