16th April 2021, 11:36 | #42 | Link |
Sorry T, not so amusing.
16th April 2021, 17:37 | #43 | Link |
I don't intend to make a new build for now, as it take a long time, and the last update has no effect on PC build. I'll make a new build only when there is a "significant" update => A fix, or a new feature.
But i've updated the github, so, feel free...
My github. |
19th April 2021, 15:38 | #44 | Link | |
Acid fr0g
Any chance to include the -dither part of x265 into x264? I hope someone more skilled than me will compile that build.
@turment on Telegram |
29th April 2021, 09:07 | #46 | Link | |
Acid fr0g
Using internal dither is way faster than dithering with AVS+ scripts, we are talking about 15-20% when going from 16bit to 8/10 bit.
29th April 2021, 10:50 | #47 | Link | |
Broadcast Encoder
feeding 16bit planar works like a charm!
XAVC Classes also work like a charm! Quote:
x264.exe "AVS Script.avs" --avcintra 50 --avcintra-flavor sony Code:
x264.exe "AVS Script.avs" --avcintra 100 --avcintra-flavor sony Code:
x264.exe "AVS Script.avs" --avcintra 200 --avcintra-flavor sony Code:
x264.exe "AVS Script.avs" --avcintra 300 --avcintra-flavor sony Code:
x264.exe "AVS Script.avs" --avcintra 480 --avcintra-flavor sony Now I'm finally happy here at work! Once enough people have tested it, if you could make a final build with OpenCL enabled in x64 that would be great! (and only if you have time and just for my old computer sitting at home, an x86 XP compatible build would be very sweet too for me and other xp die-hard) Last edited by FranceBB; 29th April 2021 at 10:54. |
29th April 2021, 18:09 | #49 | Link |
Broadcast Encoder
Oh, that's a shame...
Nope, Bcrypt and AcquireSRWLockExclusive are missing... Well, it doesn't matter... The important thing is that I've got the classes on Win10. |
12th May 2021, 12:44 | #51 | Link |
Broadcast Encoder
Great!
I tested the build, it works just fine as I've encoded an XAVC Intra Class 10bit planar feeding it with a 16bit 4:2:2 planar, but... here's the thing: my AppleProRes masterfile was 10bit planar 4:2:2, but after indexing it I had to go all the way up to 16 planar 4:2:2 and feed x264 which then used the Sierra 2-4A Error Diffusion Dithering to go back to 10bit planar, which is... well... alright, but I couldn't feed x264 with 10bit 4:2:2 planar directly as it was saying that it's not supported. Maybe in the future it would be worth adding support for 10bit planar as well to avoid useless dithering if sources are 10bit planar in the first place. This is just me thinking out loud, though. Thanks for the build, Jean Philippe. Last edited by FranceBB; 12th May 2021 at 12:50. |
12th May 2021, 18:18 | #52 | Link | |
In general, using error diffusion doesn't seem to be needed in doing 10-to-16-to-10. The intermediate 16 has enough precision that a straight truncated conversion will return the same values as long as you're not doing any filtering (including scaling). |
26th May 2021, 09:46 | #53 | Link |
Acid fr0g
Can we please make a point about direct HBD support in current x264 builds?
AFAIK JPSDR has implemented it, plus a Sierra dithering to output to lower bitplanes, but without OpenCL, DJATOM supports it but without dither. The perfect build would be with dithering and OpenCL. Please
30th May 2021, 09:40 | #54 | Link |
In the dawn of time, during my first attempts to build x264, the build failed with an OpenCL related error. Adding --disable-opencl allowed the build to success, and as i'm not interested in OpenCL, i didn't want to spend time to search why the build failed and how fix this.
Out of curiosity, just now, i tested to make a build removing --disable-opencl, to see if by any chances, things changed since. And the build worked. So, unless bad unexpected surprise, there is a big chance that the next release will have OpenCL, or at least, not build with --disable-opencl.
My github. |
30th May 2021, 13:31 | #57 | Link |
Broadcast Encoder
Maybe for some scenarios, but in my case I've seen some improvement on a Quadro P4000 on my server. The reason is that such a server is almost always busy encoding Apple ProRes or whatever to XDCAM MPEG-2 or doing some linear transformation from AVC Intra Class log to BT709 whatever in the meantime, so if I can free up the CPU it's always a good thing. As a matter of fact I did in the past and I've seen some improvements for low bitrate (2.5 Mbit/s to 5 Mbit/s) FULL HD 8bit x264 preset medium High 4:2:0 --ref 4 encode from masterfiles that are supposed to go to the web (like Twitter, Facebook, Instagram etc).
I know that this is a bit different from the everyday folk usage, but professionally speaking you always wanna make the best out of your server and I can't of course use NVEnc for those kind of files so if one of the encoders like x264 can offload something to the GPU, why not... Last edited by FranceBB; 30th May 2021 at 13:36. |
31st May 2021, 18:00 | #58 | Link |
The reason i'm not interested in OpenCL, is that i have a very old blur memory of reading that it produced result less good than with pure CPU for of course the exact same encode.
My github. |
31st May 2021, 20:12 | #59 | Link | |
Broadcast Encoder
But again, it's a matter of taste. For what is worth, thank you for integrating my patch for XAVC and also for allowing 16bit planar, those two things alone made my day. What would make it perfect would be VideoLAN integrating it in the official repository, but... I don't think that's ever gonna happen... |
