Old 20th July 2009, 17:59   #1  |  Link
hawthorn
How do I convert VCD to DVD?
I have two VCDs, each in .bin/.cue format and want to convert them to DVD - I did try copying the .DAT files and used AVS Video Converter but the sound was completely out of sync.
Any ideas gratefully received.
hawthorn is offline   Reply With Quote
Old 20th July 2009, 19:43   #2  |  Link
Ghitulescu
Ghitulescu's Avatar
You don't need any conversion. The only difference that exists between VCD and a DVD compliant MPEG-1 stream is the GOP length. Fortunately, no DVD player would "quack" at MPEG-1 streams that are "out of bounds".
So, import the DAT files in any DVD authoring program and be happy.
bin, cue, vcd
