5th July 2021, 22:19 | #61681 | Link |
Use 8bit 444, there's no reason to go down to 422 for 10bit. 444 is way more visually impactful than 10bit, and that's assuming the device actually does 10bit properly.
The only thing 10bit is visually useful for is smooth gradients, which don't come up often in movies. Whereas 444 flat out gives you better texture detail, and this is across the board. I don't know how that device behaves for color but it shouldn't clamp saturation based on bit-depth, unless it's suppose to be kicking into an sdr/hdr mode.
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 5th July 2021 at 22:23. |
6th July 2021, 01:42 | #61682 | Link |
The Nvidia control panel only has a choice of 8 bit or 12 bit for some reason, so I'll just use 8. Where do I choose 4:4:4 for 8 bit though?
Sent from my SM-N975U using Tapatalk Last edited by LenniePaz; 6th July 2021 at 01:45. |
6th July 2021, 16:08 | #61685 | Link |
Not strictly madVR related, but this thing happens with Kodi DSPlayer using madVR... I repost from Kodi forums, hoping that with so many video enthusiasts here my chances of a solution might increase.
I want my Kodi GUI at 60Hz. I start from my desktop at 60Hz. Kodi starts at 60Hz. When I play something it switches refresh rate correctly. I stop the video. I exit Kodi. As soon as the process is terminated (Kodi.exe, I mean), the screen switches to 50Hz. Anything comes to mind as to why this could be happening? If I don't use the refresh rate functionality, it doesn't happen. I have tried launching in portable mode, same thing. This happens both with Kodi 19 and Kodi 17.6 DSPlayer (which switches through madVR). So I'd be inclined to say it's not strictly Kodi dependent. But if I play back a video with MPC-HC, it switches refresh rate correctly but when I exit the player nothing happens, it goes back to 60Hz and stays that way.
LG 77C1 - Denon AVC-X3800H - Windows 10 Pro 22H2 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - RTX 4070 - Ryzen 5 3600 - 16GB RAM |
6th July 2021, 21:01 | #61687 | Link | |
Kodi always starts at desktop resolution/refresh.
6th July 2021, 21:10 | #61688 | Link |
I found with DSplayer, I have to let kodi do the refresh rate switch, otherwise I get that same problem you have described - just my experience.
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema |
6th July 2021, 22:29 | #61689 | Link | |
You can read the EDID with e.g. EDIDViewer and there you'll see a 'preferred' timing mentioned. This is the one that is used when installing a new driver. |
7th July 2021, 00:23 | #61690 | Link |
Solved it! In Kodi System/Display settings, under resolution, there were two 3840x2160p resolutions. One for 50Hz and one for 60Hz. For some reason, the 50 Hz one got chosen. And that was messing things up.
Oldpainlesskodi, I have madVR handling refresh switch and it works correctly (now).
7th July 2021, 00:46 | #61691 | Link | |
Sent from my SM-N975U using Tapatalk |
7th July 2021, 07:37 | #61692 | Link |
@ashlar42 - seems that was my issue too. Thanks.
7th July 2021, 11:08 | #61693 | Link | |
Oh, wow! Glad to have been of help. Sorry all for the semi-offtopic, btw.
7th July 2021, 14:47 | #61694 | Link |
One question I have. I ended up going back to old, trusty Reclock (thanks to redfox for making it Win10 compatible). I forgot how easy it is to get perfectly smooth results with it.
Since that exists only in 32 bit, am I missing something in madVR by not using the x64 build? Or in LAV filters, if you know something... Everything seems to be working perfectly but I might be missing something.
7th July 2021, 16:51 | #61697 | Link |
32-bit will be limiting you sooner or later. Software decoders are significantly slower on 32-bit, and hardware decoding won't engage for very high resolutions due to memory limits (> 4K, I believe, its driver-controlled). It might work today, but it does not have a future.
7th July 2021, 17:17 | #61698 | Link | |
Soul Seeker
7th July 2021, 17:19 | #61699 | Link | ||
Source: https://en.wikipedia.org/wiki/Nvidia...n_PureVideo_HD
LG 77C1 - Denon AVC-X3800H - Windows 10 Pro 22H2 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - RTX 4070 - Ryzen 5 3600 - 16GB RAM Last edited by ashlar42; 7th July 2021 at 18:56. |
