Old 26th December 2005, 08:43   #1  |  Link
omion
omion's Avatar
CAVLC -> CABAC?
I've just started to encode an HDTV movie, and have been playing around with the settings. After a few quick tests, I found that at 720p24 I can't play back CABAC-encoded files, but I can play CAVLC. Is there any tool available which can "recompress" between the two?
My idea is to encode with CAVLC and just accept the slightly larger file until I get my next computer. Then I'll "recompress" the file to CABAC to save space.
So is there anything available which can do this? If not, is it something simple enough to expect it to be available in the future?
"We demand rigidly defined areas of doubt and uncertainty!" - Vroomfondel, H2G2
omion is offline   Reply With Quote
Old 26th December 2005, 08:59   #2  |  Link
akupenguin
x264 developer
akupenguin's Avatar
There is no such tool existing, but it shouldn't be hard to write.
Old 26th December 2005, 16:03   #3  |  Link
Chainmax
Huh?
Chainmax's Avatar
Forgive my complete and utter ignorance, but it can be done in a lossless way? How?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it.
Chainmax is offline   Reply With Quote
Old 26th December 2005, 16:18   #4  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Converting CABAC compressed data in CAVLC... something like converting a 7-zip archive into a normal zip.
Old 26th December 2005, 16:23   #5  |  Link
virus
Senior n00b
Originally Posted by Chainmax
Forgive my complete and utter ingorance, but it can be done in a lossless way? How?
Entropy coding via CABAC or CAVLC is done as last step, after ME and quantization have taken place. Let's say it's a lossless process that just "writes down to the bitstream" the already-computed data (transformed&quantized coefficients, macroblock types, motion vectors, plus additional side-infos). All you need to do is to decode the CAVLC/CABAC stream and reencode it to the other format, while signalling in the slice headers that you've switched entropy coder type. Nothing will be lost in the process, since detail removal (which comes from quantization) need not be performed again. You just redo the very last step in your encoding chain (see what I've written above).
virus is offline   Reply With Quote
Old 26th December 2005, 17:07   #6  |  Link
Chainmax
Huh?
Chainmax's Avatar
So, it would be akin to switching headers on a video stream or demuxing and remuxing into a different container?
Old 26th December 2005, 20:43   #7  |  Link
omion
omion's Avatar
@Chainmax:
It would be a bit like changing containers, but Sharktooth's zip analogy is better. The data is compressed with either CABAC or CAVLC before it is written to a file.
By the way, I found I can read 720p24 CABAC movies as long as I use the overlay mixer. Since I watch a lot of subbed anime, I always have VMR9 renderless on, but it seems to be a bit too slow in this case.
Old 8th August 2006, 09:26   #8  |  Link
j7n
j7n's Avatar
As far as I understand CABAC considerably increases CPU load during playback. I think that after recompressing into CAVLC my older computer would be able to decode my H.264 files in real-time. Has the situation changed after 7 months and a tool to convert between CABAC & CAVLC become available?
j7n is offline   Reply With Quote
Old 8th August 2006, 10:15   #9  |  Link
Limobar
aka Rabomil
I would welcome a CABAC-to-CAVLC-converter because that would make more encodes decodable for the Xbox.
Limobar is offline   Reply With Quote
Old 8th August 2006, 10:32   #10  |  Link
codimahi
Conversion from CABAC to CAVLC includes CABAC decoding and CAVLC encoding in which both are very computational intensive. Let's say for a 1hr h.264 CABAC encoded movie, this recompression may take more than 3hrs(depend on resoulution). I don't think so any body would like to do this before seeing a very interesting movie.
codimahi is offline   Reply With Quote
Old 8th August 2006, 10:38   #11  |  Link
j7n
j7n's Avatar
However computation intesive or unoptimized that program might be it would really help if purchasing a faster computer (or re-encoding the video) is not an option.
The choice is real simple:
*- spend 3hrs and watch the movie
*- do not watch the movie at all
Old 8th August 2006, 12:19   #12  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
Originally Posted by omion
@Chainmax:
Slightly off topic - I'm assuming you use VMR to view subtitles. However, MPC's internal subtitle renderer uses VMR7 (which is faster), and vsfilter runs best in overlay, so why use VMR9?
check is offline   Reply With Quote
Old 8th August 2006, 17:15   #13  |  Link
akupenguin
x264 developer
akupenguin's Avatar
No. CABAC is about 20-40% of the decoding time (depending on bitrate). CAVLC is less. If you can play the CAVLC version in realtime (otherwise you wouldn't be converting), then the CABAC version can't be more than 30% slower than realtime.
But the CABAC->CAVLC converter doesn't have to do any of the other steps of decoding, it just parses the bitstream and writes it out again. So at the high end (CABAC=40% of decoding, CAVLC version takes 100% CPU), I'd expect the converter to run no slower than 1.5x realtime.
Old 8th August 2006, 17:37   #14  |  Link
Inventive Software
Turkey Machine
Potentially stupid question, but I'll ask anyway.
Does the CABAC/CAVLC take place in each frame after the ME and bitstream has been written? Or is it done before the bitstream is written? Or is it done completely different?
EDIT: Does CAVLC happen anyway even if CABAC is enabled?
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline   Reply With Quote
Old 9th August 2006, 04:20   #15  |  Link
sysKin
sysKin's Avatar
CABAC/CAVLC is THE two ways of writing a bitstream
No, it's one or the other.
Visit #xvid or #x264 at irc.freenode.net
sysKin is offline   Reply With Quote
Old 14th October 2006, 02:01   #16  |  Link
Limobar
aka Rabomil
Dear Developers,
Please consider writing a tool that converts CABAC to CAVLC. People that use the Xbox (XBMC) would then be able to enjoy so much more content that is available, but not decodable because of the limited processing power of the Xbox and the processing power needed by CABAC.
The combination of a tool that appears not to be that hard to write (according to akupenguin) and the reasonable conversion time needed, in my opinion, makes it worth the effort. I hope you feel the same.
Regards,
Limobar
Old 16th September 2009, 18:48   #17  |  Link
pokazene_maslo
I second this request. It would be a useful tool for users with slower machines.
pokazene_maslo is offline   Reply With Quote
Old 17th September 2009, 10:07   #18  |  Link
iwod
Does this tools exist after nearly 3 years?
iwod is offline   Reply With Quote
Old 17th September 2009, 14:19   #19  |  Link
Shevach
Video compressionist
CABAC is about 20-40% of the decoding time .
In average CABAC performance is 20-40% higher than CAVLC one. But CABAC encoding/decoding can have severe performance peaks (unlike CAVLC where peaks are significantly smaller).
The reason is that CABAC is very hard for optimization due to back-dependency between bins. Choice of context models for some bins depends on the values of previous bins (e.g. the bins of mb_type). So, CABAC can not easely pipelined.
Some encoders deliberately switch to CAVLC mode when performance peak in CABAC encoding/decoding expected.
Thus a smart CABAC->CAVLC converter should switch to CAVLC only if video content might cause performance peak.
Shevach is offline   Reply With Quote
Old 17th September 2009, 15:25   #20  |  Link
roozhou
Could someone write a CABAC <-> CAVLC bitstream filter for ffmpeg?
roozhou is offline   Reply With Quote
