Old 2nd August 2021, 11:07   #1  |  Link
Troc
Troc's Avatar
Filter requires RGBS?
I'm using Vapoursynth to try a denoiser. A friend who uses Hybrid says it works wonders, however I was looking to use it in conjunction to Virtualdub2.
The filter is this:
https://github.com/HolyWu/vs-dpir
My script:
from vapoursynth import core
from vsdpir import DPIR
#video = core.ffms2.Source(source=r"G:\_Anime\CH73 DVD\Disc1\Episode1.mkv")
ret = DPIR(core.ffms2.Source(source=r"G:\_Anime\CH73 DVD\Disc1\Episode1.mkv"), "task: str='denoise'", "device_type: str='cuda'")
video.set_output()
I get an error that goes like this:
"raise vs.Error('DPIR: Only RGBS format is supported')
vapoursynth.Error: DPIR: Only RGBS format is supported
What am I supposed to do? I tested converting the file into various types of RGB in Virtualdub2 but the same error happened every time. There's no results for this error in Google and no info on what RGBS video is - outside of some pictures of SCART converters that can't be what I'm looking for. How do I solve this? Do I just give up and learn how to use Hybrid?
Troc is offline   Reply With Quote
Old 2nd August 2021, 11:27   #2  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
You need to convert the video to the RGBS format first:
vs.core.resize.Bicubic(video, format=vs.RGBS)
and you'll probably need to convert it back at the end:
vs.core.resize.Bicubic(video, format=vs.YUV420P8, matrix_s="709")
Myrsloik is offline   Reply With Quote
Old 2nd August 2021, 12:06   #3  |  Link
Troc
Troc's Avatar
vs.core.resize(video, format=vs.RGBS)
Alright, I edited the code to include this, so it looks like this now:
import vapoursynth as vs
vs.core.resize("G:\_Anime\CH73 DVD\Disc1\Episode1.mkv", format=vs.RGBS)
I get the following error: TypeError: 'vapoursynth.Plugin' object is not callable
I added the "import vapoursynth as vs" since before I did that, it said "vs is not defined" and I figured it was short for vapoursynth. However this second error I don't understand. Was I supposed to put the core resize as a part of the DPIR source or the earlier source?
Old 2nd August 2021, 12:16   #4  |  Link
Myrsloik
Myrsloik's Avatar
Brainfart. I updated my reply. See the documentation for resize here:
http://www.vapoursynth.com/doc/functions/resize.html
Old 2nd August 2021, 12:59   #5  |  Link
Troc
Troc's Avatar
Alrighty, I fixed the resize part and got a new error. Progress is good. New error:
File "src\cython\vapoursynth.pyx", line 2069, in vapoursynth.Function._call_
vapoursynth.Error: Index: Can't open 'VideoNode
Format: YUV420P8
Width: 720
Height: 480
Num Frames: 35845
FPS: 24000/1001
Flags: NoCache isCache'
The same error happened with my RGB conversions, only changing the Format. Am I close to a breakthrough here?
Old 2nd August 2021, 15:00   #6  |  Link
Selur
Selur's Avatar
I have never seen that error before, but here's an example on how I use DPIR in a portable Vapoursynth:
# Imports
# getting Vapoursynth core
core = vs.core
# Loading Plugins
core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2.dll")
# source: 'G:\TestClips&Co\files\test.avi'
# current color space: YUV420P8, bit depth: 8, resolution: 640x352, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: progressive
# Loading source using FFMS2
clip = core.ffms2.Source(source="G:/TestClips&Co/files/test.avi",cachefile="E:/Temp/avi_6c441f37d9750b62d59f16ecdbd59393_853323747.ffindex",format=vs.YUV420P8,alpha=False)
# making sure input color matrix is set as 470bg
clip = core.resize.Point(clip, matrix_in_s="470bg",range_s="limited")
# making sure frame rate is set to 25
clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1)
# Setting color range to TV (limited) range.
clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1)
# adjusting color space from YUV420P8 to RGBS for VsDPIRDenoise
clip = core.resize.Bicubic(clip=clip, format=vs.RGBS, matrix_in_s="470bg", range_s="limited")
# denoising using DPIRDenoise
clip = DPIR(clip=clip, strength=5.000, device_index=0)
# adjusting output color from: RGBS to YUV420P10 for x265Model
clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P10, matrix_s="470bg", range_s="limited")
# set output frame rate to 25.000fps
# Output
clip.set_output()
may be that helps.
Cu Selur
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
dpir, errors, rgbs, vapoursynth
