Old 18th February 2019, 12:48   #4521  |  Link
There is a little bit of inconsistency between function names, some use xxxxExist, and some xxxExists.
Exist                     "s"
FunctionExists            "s"
InternalFunctionExists    "s"
VarExist                  "s"
RT_ uses RT_FunctionExist() which was chosen to match the then existing Exist() function.
StainlessS is offline
Old 18th February 2019, 12:48   #4522  |  Link
real.finder
Originally Posted by ChaosKing View Post
A check with AddAutoloadDir whould detect Avisynth Neo also as Avisynth+ (it basically is avs+ with cuda stuff) while AvsPlusVersionNumber returns 0. VersionString() returns on avs neo: "Avisynth Neo 0.1 (r2882, Neo, i386)"
It this case a check with AddAutoloadDir would be prefered.
https://github.com/nekopanda/AviSynthPlus/releases
ok, so I did this, it will be in next SMDegrain update, nekopanda already did the damage so forget about my old post
function IsAvsNeo()
      FindStr(VersionString, "AviSynth Neo")  != 0
function IsAvsPlus()
      FindStr(VersionString, "AviSynth+")  != 0 || IsAvsNeo
function AvsPlusVersionNumber()
    IsAvsNeo ? eval(MidStr(VersionString(),20,4)) : IsAvsPlus ? eval(MidStr(VersionString(),17,4)) : 0
can you test it to see if it report the number correctly?
See My Avisynth Stuff
real.finder is offline
Old 18th February 2019, 14:23   #4523  |  Link
ChaosKing
Yes it works, I made a small mistake. Correct is: "AviSynth Neo"
IsAvsPlus and IsAvsNeo returning true for AviSynth Neo.
ChaosKing is offline
Old 18th February 2019, 14:41   #4524  |  Link
real.finder
and the revision number?
Old 18th February 2019, 14:51   #4525  |  Link
ChaosKing
returns 2822
Old 18th February 2019, 15:11   #4526  |  Link
real.finder
Originally Posted by pinterf View Post
The old bug is back, but now it's dither_lut16 is the culprit.
It seems that under Win10 (?) configuration it understands only the decimal separator of the current input local.
Just replace the decimal point to commas in yexpr parameter and it will work fine. (the used ReplaceStr is built-in in AVS+)
function Dither_Luma_Rebuild (clip src, float "s0", float "c",int "uv", bool "lsb", bool "lsb_in", bool "lsb_out", int "mode", float "ampn", bool "slice"){
src
lsb ? (lsb_in ? Dither_lut16  (yexpr=ReplaceStr(e,".",","),expr="x 32768 - 32768 * 28672 / 32768 +",y=3, u=uv, v=uv)                 : \
                Dither_lut8   (yexpr=ReplaceStr(e,".",","),expr="x 128 - 32768 * 112 / 32768 +"    ,y=3, u=uv, v=uv))                : \
                avs26 ? mt_lut(yexpr=e,expr="x range_half - range_half * 112 scaleb / range_half +",y=3, u=uv, v=uv) : \
                        mt_lut(yexpr=e,expr="x 128 - 128 * 112 / 128 +"        ,y=3, u=uv, v=uv)
btw, will this make the systems that use dot has wrong outputs?
so, the final solution for this? rebuild dither.dll with vc15 ?
Old 18th February 2019, 16:07   #4527  |  Link
pinterf
Dunno, probably yes. Do those lines really improve anything or it is just kept and copied over many years? Could Zopti (Formerly Avisynth optimizer) help deciding it? No, I'm not volunteering for it . Still working on the "Layer" stuff.
pinterf is offline
Old 18th February 2019, 16:14   #4528  |  Link
real.finder
they doing good job in dark area
btw, don't tell me that masktools lut (and avs+ expr) has this problem too!
if it only the dither one did this update here fix the problem?
Old 18th February 2019, 16:33   #4529  |  Link
pinterf
No, as far as I know masktools is working properly. There have been problems with dither tools' decimal separator, which I'm not sure it it was fixed or not.
pinterf is offline
Old 18th February 2019, 16:47   #4530  |  Link
real.finder
ok, can someone test? someone that has regional setting use comma for decimal separator
edit: simple test
ColorBars(pixel_type="yv12")
a=Mt_makediff(Dither_Luma_Rebuild(),coloryuv(levels="TV->PC"),u=3,v=3)
b=Mt_makediff(Dither_Luma_Rebuild(lsb=true),coloryuv(levels="TV->PC"),u=3,v=3)
StackVertical(a.Subtitle("luma rebuild vs avs tv to pc"),b.Subtitle("luma rebuild lsb vs avs tv to pc"),Mt_makediff(a,b,u=3,v=3).Subtitle("lsb vs 8bit"))
in case of avs tv to pc vs luma rebuild (whether with or without lsb) there are small difference here and there, so anyone test better post image of it
Old 18th February 2019, 17:39   #4531  |  Link
ChaosKing
How should one test it exactly? just call Dither_Luma_Rebuild() ?
Old 18th February 2019, 17:48   #4532  |  Link
real.finder
I know that someone will ask that, see my edit I just made above
Old 18th February 2019, 18:29   #4533  |  Link
ChaosKing
Old 18th February 2019, 18:34   #4534  |  Link
real.finder
https://i.imgur.com/bZfmVX9.jpg
it's same I got, my system use dot (Iraq)
btw, what avs you use and what dither.dll?
Old 18th February 2019, 19:09   #4535  |  Link
ChaosKing
Win10 x64 german which uses comma as decimal separator, avs+ 2772, 32bit dither.dll (CRC32: 20008b02) is from here http://ldesoras.free.fr/prod.html#src_ditheravsi
Old 18th February 2019, 20:35   #4536  |  Link
real.finder
so that mean the problem already fixed? it was bug in win10 that fixed in later updates or what? let's see what pinterf and tormento said
Old 18th February 2019, 21:48   #4537  |  Link
ChaosKing
Idk I never encountered this problem in avs.
Old 18th February 2019, 22:28   #4538  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Got a filter development problem.
In GetFrame, I can do this:
PVideoFrame __stdcall warp::GetFrame(int n, IScriptEnvironment* env) {
  PVideoFrame dst = env->NewVideoFrame(vi);
  byte* dst_p = dst->GetWritePtr();
As it's an interleaved RGB clip, this works as expected.
But what I want to do is this:
void some_function(PVideoFrame dst) {
  some_function(dst);
This doesn't work. GetWritePtr() in the function returns 0.
What's the problem and how can I fix it?
Edit: it looks like I have to pass a pointer to the smart pointer, even though the smart pointer itself has the same value inside and outside of the function. Any brief explanation of this would be gratefully received.
wonkey_monkey is offline
Old 19th February 2019, 00:04   #4539  |  Link
Make dst a reference, think that should work.
void some_function(PVideoFrame &dst) {
EDIT: If not reference, it makes a copy of PVideoFrame for calling some_function, and as is a copy is no longer writeable.
Old 19th February 2019, 00:27   #4540  |  Link
wonkey_monkey
I checked the actual value of PVideoFrame (assuming it actually is some kind of pointer) and it was the same inside the function. I guess there's another layer of abstraction that ruins this idea.
Anyway, see my edit, as I did manage to figure that out and it now works. Thanks though!
