Old 3rd October 2014, 20:50   #41  |  Link
spawnbsd
Great plugin, but any idea when we'll see 16bit support ?
spawnbsd is offline   Reply With Quote
Old 3rd October 2014, 21:06   #42  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Dunno. This year, if I'm not too lazy.
On that topic, how does everyone feel about adding support for 16 bit input to Analyse by simply shifting it to 8 bit? Filters like the Degrains and Compensate will work with 16 bit input directly, of course.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 3rd October 2014, 21:44   #43  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Originally Posted by feisty2 View Post
little pickle here, Mystery Keeper, what should I do if I want mdegrainn (tr=6) instead of mcompensate
Then, of course, you would need to write the function that takes array of clips. But I think that's better than generating special multivector clips.
...desu!
Mystery Keeper is offline   Reply With Quote
Old 3rd October 2014, 21:45   #44  |  Link
Mystery Keeper
Beyond Kawaii
Should be alright. At least that would be a start. Personally, I'm looking forward to DCT.
...desu!
Old 3rd October 2014, 21:50   #45  |  Link
Are_
I don't see anything wrong with that.
Are_ is offline   Reply With Quote
Old 3rd October 2014, 22:09   #46  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Heck, you could probably get away with 4-bit for the most part. Obviously, dithering down would just introduce unwanted noise, but truncating should work fine. I look forward to it, someday!
Old 4th October 2014, 05:26   #47  |  Link
feisty2
I'm Siri
feisty2's Avatar
Mystery Keeper, I mean, the reason that large time radius mcompensate could be done this way is mcompensate only takes one vector clip once, if you have n vector clips, there would be n mcompensates, but mdegrain takes a lot of vector clips once basing on the time radius, so, I donno how to do the same thing to mdegrain like mcompensate
feisty2 is offline   Reply With Quote
Old 4th October 2014, 15:05   #48  |  Link
cretindesalpes
cretindesalpes's Avatar
Don’t waste your time at this, moreover it would be misleading. We can explicitly convert the high-bitdepth clips to 8 bits for analysis. Anyway, I think there is a definite benefit to run the analysis on 10–12 bits. I often remap the luma channel to increase the contrast is some specific ranges (generally the dark parts), and keeping 8 bits crunches other ranges, reducing the accuracy of the analysis on fine textures.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding
cretindesalpes is offline   Reply With Quote
Old 4th October 2014, 21:14   #49  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Damn. No easy way out of it, huh.
Old 5th October 2014, 22:22   #50  |  Link
chainik_svp
jackoneill
I really don't want to suggest anything but the code in SVPflow is really cleaned comparing to original MVTools
Just compare a few numbers - as you already know all the magic is in "PlaneOfBlocks" cpp/h, and they're ~80 KB of code(*) in MVTools (and in your build too) BUT only 42 KB in SVPflow.
(*) huge commented blocks are also included
Also original MVTools loosing >= 20% of performance just for nothing...
SVPflow motion interpolation
chainik_svp is offline   Reply With Quote
Old 5th October 2014, 22:51   #51  |  Link
Mystery Keeper
Beyond Kawaii
Originally Posted by chainik_svp View Post
jackoneill
So would you kindly port it to VapourSynth?
...desu!
Old 5th October 2014, 23:03   #52  |  Link
chainik_svp
Since we (SVP) need ffdshow support I'm thinking only of AVS+ 64bit right now.
But if "porting" is just a few interface functions then why not...
In fact it's not great to have so many branches of MVTools:
- original version
- the one with MT built-in
- SVP's build of original version plus (external) GPU rendering
- completely refactored SVPflow
- this VS version
and all the version but SVPflow share the very same code for MV search algorithm
Old 5th October 2014, 23:18   #53  |  Link
Mystery Keeper
Beyond Kawaii
chainik_svp, put algorithm into static library and link it to the different projects?
...desu!
Old 5th October 2014, 23:26   #54  |  Link
chainik_svp
this's how SVPflow is working
rendering part with GPU support (and some more features) is "hidden"
"MAnalyse" part is in a separate GPL library
since SVPflow is the only branch changing something in the MVTools' math I really think it should be the base for any other versions
Old 5th October 2014, 23:35   #55  |  Link
Mystery Keeper
Beyond Kawaii
chainik_svp, keep in mind that VapourSynth is multithreaded (GPU use becomes complicated), cross-platform and both 32 and 64-bit versions are used. Though 32-bit version is only needed when script uses AviSynth plugins.
...desu!
Old 9th October 2014, 12:58   #56  |  Link
jackoneill
unsigned int
jackoneill's Avatar
v4 is out, with more barely tested changes.
* Fix the use of an uninitialised variable in Recalculate (kind of important).
* Add some more SAD functions. Block sizes of 8x4, 16x2, 32x16, and 32x32 should now be just as fast as in the original Avisynth plugin.
* Allow YUV422P8 input. The filters only needed to accept such clips, because the required code was already there.
Old 10th October 2014, 16:56   #57  |  Link
Are_
Wow, I'm having about ~20% speed improvement on my linux box, or I'm doing something wrong or you did a really good job there.
Old 10th October 2014, 18:51   #58  |  Link
jackoneill
unsigned int
jackoneill's Avatar
If you compiled the latest from git it's probably that change the SVP folks made. I finally copied it. v5 will have it.
Old 7th November 2014, 14:38   #59  |  Link
Aurelio
Great work!
Any plans to port also MFlowFps and MBlockFps?
Aurelio is offline   Reply With Quote
Old 7th November 2014, 21:29   #60  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Originally Posted by Aurelio View Post
Great work!
Yes, there are plans.
