Old 13th January 2009, 23:21   #421  |  Link
leeperry
Kid for Today
hi clsid, when you have time that'd be cool if you could add the Reclock deadlock fix to MPC if you don't mind
Old 26th January 2009, 06:02   #422  |  Link
Aleksoid1978
Aleksoid1978's Avatar
to clsid - maybe add support multimonitor for fullscreen playback(as i do it in the MPC-HC) ???
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 26th January 2009, 12:21   #423  |  Link
clsid
I am not going to add new features unless people submit a patch.
MPC-HC 2.2.1
Old 27th January 2009, 06:19   #424  |  Link
Aleksoid1978
Let me make a patch ???
Old 27th January 2009, 08:15   #425  |  Link
Aleksoid1978
here patch + fullsrc of changed and new files : http://tosei.ru/isoft/mpc/MM.RAR
Old 8th August 2009, 20:48   #426  |  Link
shae
What's the latest build that supports Win9x? Anything newer than 2008/10/5? (Mainly looking for something that solves the added audio delay.)
shae is offline   Reply With Quote
Old 8th August 2009, 20:49   #427  |  Link
tetsuo55
MPC-HC Project Manager
What happens when you try a newer build?
tetsuo55 is offline   Reply With Quote
Old 8th August 2009, 20:54   #428  |  Link
shae
VC runtime library error + crash.
Old 8th August 2009, 20:58   #429  |  Link
tetsuo55
Can you install these runtime redists?
2008 and 2005
If you can install them does MPC work?
Old 8th August 2009, 21:16   #430  |  Link
shae
I think it's statically linked, there's no MSVCRT imports (same imports as the older build which does work). The VC error isn't about a "missing function" or something like that, but an exception.
BTW, are these newer CRTs supposed to run on 9x at all? (I have 8.0/2005 DLLs, though I'm not sure if anything ever used them.)
Edit: v9 runtimes installer doesn't run because of a missing NT import. v8 does run.
Old 8th August 2009, 21:19   #431  |  Link
tetsuo55
I don't think you will get this to work, any special reason for still using 98?
Old 8th August 2009, 21:28   #432  |  Link
shae
I wasn't really expecting it to run, just wondered if there are newer 9x builds somewhere. :) 9x because it's an old computer.
Old 8th August 2009, 21:30   #433  |  Link
tetsuo55
I wasn't really expecting it to run, just wondered if there are newer 9x builds somewhere. 9x because it's an old computer.
if it has a 1000mhz+ cpu and 256+ memory you could upgrade it to a newer windows versions.
the minimum for windows 7 is 1,6ghz and 512mb (it was written with netbooks in mind)
Edit someone could probably compile the newest version with MSVC2005 and a platform SDK that still supports win98, but that person might have to fight his way through a ton of warnings and errors
Old 8th August 2009, 21:41   #434  |  Link
shae
if it has a 1000mhz+ cpu and 256+ memory you could upgrade it to a newer windows versions. the minimum for windows 7 is 1,6ghz and 512mb (it was written with netbooks in mind)
Well, that's for another thread. :) (Minimum requirements aren't really realistic, you know. 128MB "recommended" for XP, etc. Though XP will do fine with much less than 1GHz.) Anyway, thanks for the suggestions. Maybe a newer 9x build will surface sometime...
Old 9th August 2009, 00:08   #435  |  Link
Liisachan
李姗倩 Lǐ Shān Qiàn
Liisachan's Avatar
Sorry, wrong post of mine.
Anyway,
You can get unofficial builds here
http://www.xvidvideo.ru/content/category/1/3/4/
rev104, Jul 6 2009
Change-logs:
*104 Updated copyright year
*103 libpng to version 1.2.37
*102 VSFilter: blacklisted Google Desktop(v2.39.5.2)
*101 VSFilter: change registry key name of Style to Style2 to prevent issues with old versions
*100 FLV Splitter: fix support for NELLYMOSER_8HZ_MONO
*99 Better match standard DirectShow behavior for selecting the source filter.
*98 Updated libpng to version 1.2.35
*97 Minor changes
*96 Updated libfaad to version 2.7
*95 Bump VSFilter version number and copyright year.(v2.39.5.1)
*94 Fixes to VFR support in Avisynth TextSub function, thanks to Conan Tantei.
*93 Have VSFilter.dll report a sane version number in the VERSIONINFO resource, instead of the useless numbers telling nothing about the actual version numbers everyone else uses (including the DShow filter's own About property page.)(v2.39.5.0)
*92 Add VFR capability to the Avisynth 2.5 VSFilter TextSub() and MaskSub() functions.
Also make both TextSub() and MaskSub() take named parameters instead of only positional ones.
*91 Updated libpng to version 1.2.34
*90 Matroska splitter: Theora support
*89 MP4 splitter: AC3 support
MP4 splitter: small bugfix
Matroska splitter: E-AC3 support
*88 Ogg splitter: Theora support
*87 Fixed buffer overrun in RealText subtitle parser (Released)
Liisachan is offline   Reply With Quote
Old 9th August 2009, 07:10   #436  |  Link
JarrettH
Wow thanks, I didn't know about any of those changes since rev 89.
Old 15th February 2010, 01:08   #437  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Media Player Classic, svn 107
Changes log
Fix crash on Vista x64 due to recent Windows updates. (Patch made by addmx)
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
media player classic, mpc, vsfilter
