Old 7th October 2018, 09:02   #5741  |  Link
Grimsdyke
Seem to have been fixed in 4024 and 4025. Thx !!
Now if it also could get fixed that MPC-BE automatically assumes that the content with the longest duration is also the main feature then I would be a happy camper.
All the best
Grimsdyke is offline   Reply With Quote
Old 7th October 2018, 09:11   #5742  |  Link
Klaus1189
Yes, I can confirm, it is fixed.
Thank you v0lt
Klaus1189 is online now   Reply With Quote
Old 7th October 2018, 18:19   #5743  |  Link
steakhutzeee
steakhutzeee's Avatar
Originally Posted by Klaus1189 View Post
IMHO yes, I never used that feature before today.
@devs: correct me if, I am wrong.
Thank you
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM
steakhutzeee is offline   Reply With Quote
Old 10th October 2018, 18:32   #5744  |  Link
steakhutzeee
Asked this question in the past. Try again now bacause maybe something changed
There is chance to reproduce a bluray with mpc-be? Files with structure: BDMV/CERTIFICATE/etc.?
Thanks!
Old 10th October 2018, 22:37   #5745  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Open BD support, but without menu.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 10th October 2018, 23:42   #5746  |  Link
steakhutzeee
Thanks! So if I have a BluRay with all those folders, what the file I have to start?
I can select audio and subs track the usual way I think right?
And how to access the extras?
Thanks for your time
Old 11th October 2018, 00:41   #5747  |  Link
ryrynz
ryrynz's Avatar
File -> Open DVD/Blu-ray
Navigate to BDMV directory, 'select folder' button.
Old 11th October 2018, 00:56   #5748  |  Link
BetA13
Guru3D
BetA13's Avatar
hy,
just a quick question:
second Line from Bottom, "Dither", is this a new option? it wasnt there before i updated.. Where can i control it?
THX and greetings...
BetA13 is offline   Reply With Quote
Old 11th October 2018, 04:22   #5749  |  Link
v0lt
@BetA13
This is not an option; it is processing the image while reducing the bit depth. It was always (in MPC-HC is also the same).
v0lt is offline   Reply With Quote
Old 11th October 2018, 17:05   #5750  |  Link
Klaus1189
You selected 16-bit Floating Point here, at 8-bit Integer or 10-bit Integer it's disabled.
Old 11th October 2018, 19:52   #5751  |  Link
BetA13
Guru3D
BetA13's Avatar
Originally Posted by v0lt View Post
@BetA13
now i understand, Danke Klaus
So teh OSD now shows this info, didnt do it before, and i know its a dummy question but, isnt a higher floating point better?
Or should i set it to 10? Lets say for best quality..?
Thanks a lot guys..
Old 12th October 2018, 04:17   #5752  |  Link
v0lt
@BetA13
If you do not see positive differences, then it will be better not to change anything in the settings.
Old 12th October 2018, 17:52   #5753  |  Link
BetA13
Guru3D
BetA13's Avatar
Thanks for the reply
i did test around a bit and to me, 16bit does look better.. in some scenes, expecially animated cartoons etc, the banding is less then with 8bit.
So, i leave it at 16bit for now since it looks better to my eyes..
Thank you for the help...
have a nice evening guys..
Old 13th October 2018, 10:14   #5754  |  Link
alex1399
Hi,guys. I've found some MP4 container with a text track in Timed Text Format, sbtl Muxing mode, tx3g Codec ID,Default and not Forced. The timestamps seems to be messed up in MPC-BE, so I convert it into ass format. The playback is perfect. Then, I add the LAV Splitter Source in external filter to replace MPC MP4/MOV Source. The playback is perfect, too.
Is sample clip required for more investigation?
alex1399 is offline   Reply With Quote
Old 13th October 2018, 10:39   #5755  |  Link
Aleksoid1978
Yes - upload same samples for test.
Old 13th October 2018, 11:01   #5756  |  Link
alex1399
Here it goes. https://www110.zippyshare.com/v/oQdqXxYz/file.html
The wrong situation is that some subtitles disappeared suddenly, some subtitles prolong too much, and others strange just like the sample clip.
Old 13th October 2018, 12:18   #5757  |  Link
Aleksoid1978
Ok, thanks.
Old 13th October 2018, 14:07   #5758  |  Link
Aleksoid1978
alex1399
Who say then LAV Source/ffmpeg/libavfilter correctly handle text subtitles in MOV/MP4 ? As i see - it's ignore sample duration and calculate : sample end time = next sample start time. I think it's incorrect. Internal Source use sample start time + duration to calculate end time.
Old 13th October 2018, 14:39   #5759  |  Link
sneaker_ger
But ffmpeg is correct, isn't it?
                        [stts: Decoding Time to Sample Box]
                            position = 3175014
                            size = 80
                            version = 0
                            flags = 0x000000
                            entry_count = 8
                            entry[0]
                                sample_count = 1
                                sample_delta = 33334
                            entry[1]
                                sample_count = 1
                                sample_delta = 3934000
                            entry[2]
                                sample_count = 1
                                sample_delta = 1466000
                            entry[3]
                                sample_count = 1
                                sample_delta = 2300000
                            entry[4]
                                sample_count = 1
                                sample_delta = 600000
                            entry[5]
                                sample_count = 1
                                sample_delta = 3360000
                            entry[6]
                                sample_count = 1
                                sample_delta = 3300000
                            entry[7]
                                sample_count = 1
                                sample_delta = 0
                        [stsc: Sample To Chunk Box]
                            position = 3175094
                            size = 28
                            version = 0
                            flags = 0x000000
                            entry_count = 1
                            entry[0]
                                first_chunk = 1
                                samples_per_chunk = 1
                                sample_description_index = 1
                        [stsz: Sample Size Box]
                            position = 3175122
                            size = 52
                            version = 0
                            flags = 0x000000
                            sample_size = 0 (variable)
                            sample_count = 8
                            entry_size[0] = 2
                            entry_size[1] = 2
                            entry_size[2] = 11
                            entry_size[3] = 41
                            entry_size[4] = 2
                            entry_size[5] = 47
                            entry_size[6] = 44
                            entry_size[7] = 2
I think it's a regression. Didn't happen with older MPC-BE. (Of course I just overwrote my old MPC-BE with the new nightly without writing down the revision. )
/edit:
At least 1.5.1 (build 2985) doesn't have the problem.
Old 13th October 2018, 16:22   #5760  |  Link
alex1399
I see, there are something tricky in the ffmpeg conversion. It should be four dialogs in the clip, but turns out to have 8 chunks. The four dialogs are:00:00:03,934 --> 00:00:05,400, 00:00:05,400 --> 00:00:07,700, 00:00:08,300 --> 00:00:11,660, and 00:00:11,660 --> 00:00:14,960.
Please read the subtitle packets info of the uncut video here https://www21.zippyshare.com/v/18bGYCpZ/file.html.
Despite that additional 0.033334 packets, the mov_text in ffmpeg simply adds many dummy packets so that each packet's end time = next packet's start time and each packet's start time + duration time = end time.
The start time is valid. The duration of each packet is ignored by LAV spliiter. I agree that the end time should be more robust against the case that next sample start time is larger than or not equal to current sample end time. If MPC-BE have worked well, maybe the duration handler of MP4/MOV Source was altered in the current version.
People using other player are complaining, too. I definitely need more information whether it is ffmpeg fault or not.
