Old 27th September 2010, 22:30   #1  |  Link
Kyuubixcel
Desperately Need Help!
Ive been having this problem with virtualdub/mod and avisynth where it never happened before until now I havent installed any new codecs and I uninstalled/reinstalled and downgraded avisynth and virtualdub/mod same for the codecs too....but whenever I try to encode this appears in it >_>
http://www.sendspace.com/file/8n8wwy
If someone can tell me the problem pleeeease help
Kyuubixcel is offline
Old 28th September 2010, 02:30   #2  |  Link
manono
Why are you sending a 95MB AVI for us to have a look at? The problem can't be detected using a smaller size? Are you receiving some sort of an error message when starting an encode? In addition to supplying a smaller AVI, can you also give more information? An error message, a pic showing the problem, the AviSynth script you're using?
manono is offline
Old 30th September 2010, 00:50   #3  |  Link
Kyuubixcel
there is no errors ive seen in avisynth it just comes automatically while playing/rendering the video and even if I make the avi smaller it doesnt fix anything.
The code I use is this:
DirectShowSource("C:\Users\Person\Downloads\Tree Of Might\Dragon.Ball.Z.The.Tree.Of.Might.1990.720p.BluRay.x264-CiNEFiLE.mkv")
BlackEdge()
vmToon(strength=255)
and I uploaded it to Youtube http://www.youtube.com/watch?v=g-aVtTngOLQ
also I undid all the filters and it seemed to work fine but the moment I add any type of filter it will just mess up or have some gray thing during rendering.
Old 30th September 2010, 01:32   #4  |  Link
Nightshiver
Quality Freak
That is an illegally downloaded file.
Nightshiver is offline
Old 30th September 2010, 21:03   #5  |  Link
Kyuubixcel
no its not I bought the DVD's and was putting it up for download and called it that
Old 30th September 2010, 21:47   #6  |  Link
AlekseiV
You bought a 720p DVD?
AlekseiV is offline
Old 30th September 2010, 22:35   #7  |  Link
Nightshiver
Quality Freak
You are wrong, Kyuu. CiNEFiLE is a pirate release group, and so is that file.
Old 30th September 2010, 23:12   #8  |  Link
Groucho2004
Dude, you're hilarious. Haven't seen a good joke in a while.
Groucho2004 is offline
Old 1st October 2010, 08:43   #9  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
You can discuss your pirated material elsewhere.
Regards, sh0dan // VoxPod
sh0dan is offline
avisynth, bug, problem, virtualdub, virtualdubmod
