Old 30th January 2017, 05:04   #61  |  Link
feisty2
I'm Siri
feisty2's Avatar
Originally Posted by Myrsloik View Post
Now you see why asm is kinda your friend.
There's a pile of pitfalls here you missed. And some you found.
1. You compile the whole file with avx2/whatever instrction set you selected. That means avx2 instructions may be emitted for you plain C++ code too. Solve it by placing the avx2 code in a separate file and use different compiler settings.
2. You can't put sse and avx intrinsics in the same file either. For example subps can get turned into vsubps to reduce register copies. So then the sse path needs avx too...
3. Cpuid is horrible in intrinsics, that's why I use asm. Lrn2yasm. Or write code that requires gcc or clang where convenient intrinsics are available. Clang is even available as a simple dropin for visual studio nowadays.
1. got it
2. got it
3. the thing is I can't set it up... yasm doesn't seem to have an installer like clang that gets everything done automatically, also the manual setting-up documentation on the yasm website is obsolete, the visual studio folders it mentioned don't even exist anymore! I could switch to clang but that won't solve the xgetbv problem cuz it's not defined in clang's immintrin.h... and back to square one, I have to set up yasm first which is impossible.
If I got new ideas, will post here: https://github.com/IFeelBloated
feisty2 is offline   Reply With Quote
Old 30th January 2017, 06:39   #62  |  Link
sl1pkn07
Pajas Mentales...
Originally Posted by feisty2 View Post
yeah
blankclip is okay, long as it's not crashing.
Ok, but how? Xd
[AUR] Vapoursynth Stuff
sl1pkn07 is offline   Reply With Quote
Old 30th January 2017, 11:37   #63  |  Link
feisty2
I'm Siri
feisty2's Avatar
Originally Posted by sl1pkn07 View Post
Ok, but how? Xd
I separated the source code into 2 files.
just compile "Source.cpp" with "-march=native" and "Source_AVX_FMA.cpp" with "-march=haswell" and it should work, you don't have to edit the source code this time, I added the conditional compilation macros and it would pick "cpufeatures_gnu.hpp" automatically if you're on GCC
test script
import vapoursynth as vs
core = vs.get_core()
clp = core.std.BlankClip(width=1920, height=1080, format=vs.GRAYS, length=20000)
clp = core.ftf.FixFades(clp)
clp.set_output()
Old 30th January 2017, 13:00   #64  |  Link
sl1pkn07
Pajas Mentales...
http://stackoverflow.com/questions/6...nstruction-set
if help you
Old 30th January 2017, 13:09   #65  |  Link
feisty2
I'm Siri
feisty2's Avatar
I know how to do that SIMD extension detecting at runtime and it's already there in the source code, I don't need any help
I'm asking if it's working cuz I'm not sure about that..
Old 30th January 2017, 13:58   #66  |  Link
sl1pkn07
Pajas Mentales...
Failed to evaluate the script:
Python exception: No attribute with the name ftf exists. Did you mistype a plugin namespace?
Traceback (most recent call last):
File "src/cython/vapoursynth.pyx", line 1712, in vapoursynth.vpy_evaluateScript (src/cython/vapoursynth.c:34991)
File "/home/sl1pkn07/aplicaciones/vapoursynth-test/fixtelecided-test.vpy", line 4, in
File "src/cython/vapoursynth.pyx", line 1306, in vapoursynth.Core.__getattr__ (src/cython/vapoursynth.c:28067)
AttributeError: No attribute with the name ftf exists. Did you mistype a plugin namespace?
all:
	  g++ -c -std=c++14 -fPIC -march=native -O2 -pipe -fstack-protector-strong -D_FORTIFY_SOURCE=2 -I. -I/usr/include/vapoursynth -o fixtelecinedfades.o Source.cpp
	  yasm -f elf -m amd64 -DARCH_X86_64=1 -o cpu.o cpu.asm
	  g++ -shared -fPIC -Wl,-O1,--sort-common,--as-needed,-z,relro -o libvsfixtelecinedfades.so fixtelecinedfades.o cpu.o
Old 2nd February 2017, 17:50   #67  |  Link
feisty2
I'm Siri
feisty2's Avatar
all:
then I think I won't be able to help you with that... sorry
I'm really just not familiar with all that gnu stuff and
1. there's the runtime simd extension detection so the unsupported forcibly-compiled functions won't matter cuz they will never get called.
2. you compiled "Source.cpp" which contains functions that will actually get called with "-march=native", so there should be no unsupported instructions in those functions.
so logically I can't see why your binary failed to work, maybe you should ask others that are more familiar with the whole gnu world..
Old 3rd February 2017, 04:26   #68  |  Link
feisty2
I'm Siri
feisty2's Avatar
anyways, if you really wanna use this plugin,
manually comment out:
line3
line123
line124
line156 - line161
in "Source.cpp",
line10 - line14 in "Shared.hpp"
and compile it and it should work..
Old 6th February 2017, 20:57   #69  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Python exception: No attribute with the name _____ exists. Did you mistype a plugin namespace?
If you get this error and you know you have the plugin, try to load it manually to find out what's wrong with it:
core.std.LoadPlugin("/your/plugin/here.so")
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 6th February 2017, 20:58   #70  |  Link
sl1pkn07
Pajas Mentales...
@jackoneill the steps for build the plugin whit yasm is correct?
edit:
Python exception: Failed to load /usr/lib/vapoursynth/libvsfixtelecinedfades.so. Error given: /usr/lib/vapoursynth/libvsfixtelecinedfades.so: undefined symbol: _Z24fixfadesGetFrame_AVX_FMAiiPPvS0_P14VSFrameContextP6VSCorePK5VSAPI
File "/home/sl1pkn07/aplicaciones/vapoursynth-plugin-fixtelecinedfades-git/fixtelecined-test.vpy", line 3, in
File "src/cython/vapoursynth.pyx", line 1604, in vapoursynth.Function.__call__ (src/cython/vapoursynth.c:33131)
vapoursynth.Error: Failed to load /usr/lib/vapoursynth/libvsfixtelecinedfades.so. Error given: /usr/lib/vapoursynth/libvsfixtelecinedfades.so: undefined symbol: _Z24fixfadesGetFrame_AVX_FMAiiPPvS0_P14VSFrameContextP6VSCorePK5VSAPI
Old 6th February 2017, 21:41   #71  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Gah, you made me look at the code.
You forgot to compile Source_AVX_FMA.cpp.
Old 6th February 2017, 21:45   #72  |  Link
sl1pkn07
Pajas Mentales...
but that is not only for AVX CPU compilant?
Source.cpp -> older CPU
Source_AVX_FMA.cpp -> newer CPU
because Source_AVX_FMA.cpp needs build with -march=haswell, amd my cpu is not capable (don't have AVX or FMA3)
Old 6th February 2017, 22:24   #73  |  Link
jackoneill
unsigned int
jackoneill's Avatar
If the author did everything right, the code from that file will only be used if the CPU has FMA3. You still have to compile it.
Old 7th February 2017, 08:25   #74  |  Link
sl1pkn07
Pajas Mentales...
ok. done
Old 7th February 2017, 08:36   #75  |  Link
feisty2
I'm Siri
feisty2's Avatar
ok. done
is it working now?
Old 7th February 2017, 08:38   #76  |  Link
sl1pkn07
Pajas Mentales...
i think yes, but i need make more test
if all is ok, then i think you can merge the Source{,_AVX_FMA}.cpp again
sorry :S
Old 7th February 2017, 08:53   #77  |  Link
feisty2
I'm Siri
feisty2's Avatar
sorry :S
no, I can't(shouldn't).
if I do merge Source.cpp and Source_AVX_FMA.cpp into one file, you'll have to compile that file with -march=haswell, and the compiler will probably generate unsupported instructions for the C++ functions..
Old 7th February 2017, 09:19   #78  |  Link
feisty2
I'm Siri
feisty2's Avatar
sorry :S
I think you should make a PR on GitHub so I can merge those GNU compiling files into the repo
Old 7th February 2017, 09:25   #79  |  Link
sl1pkn07
Pajas Mentales...
Then need making more refraction in Source.cpp, because as @jackoneill said,build Source.cpp with march=native and build Source_AVX_FMA3.cpp with march=haswell and merge both in the library, the plugin now load without problem. build
Old 7th February 2017, 09:33   #80  |  Link
feisty2
I'm Siri
feisty2's Avatar
Then need making more refraction in Source.cpp, because build It with march=native and build source_avx_fma3.cpp with march=haswell and merge both in the library the plugin now load without problem. Like @jackoneill said
what do you mean by "more refraction in Source.cpp"?
