5th April 2020, 21:12 | #681 | Link |
@B1gD4ddy So the answer is in my previous answer: I believe the TV cannot trigger DV because of the general HDMV descriptor: HDMV descriptor on top of DV descriptor is not standard. But if we remove the general HDMV descriptor then PGS, ac3+eac3 and ac3+thd won't work anymore. This is the limitation of the TS container.
6th April 2020, 00:37 | #684 | Link | |
so there is still a possible solution to my problem that could be integrated into tsmuxer with that checkbox and profile change?
he managed to create a 4/6 (Dolby Vision version 1.0, dvhe 04.06, BL+EL+RPU /SMPTE ST2086, HDR10 compatible) m2ts file from an uhd with tsmuxer instead of the usual 7/5 (Dolby Vision, Version 1.0, dvhe.07.05, EL+RPU, 8 compatible / SMPTE ST 2086, HDR10 compatible) m2ts files tsmuxer creates. how can i replicate that? i wanna test it. Last edited by B1gD4ddy; 6th April 2020 at 01:16. |
6th April 2020, 06:59 | #685 | Link | |
Please read https://www.makemkv.com/forum/viewto...p?f=12&t=18602 In brief: - Demux all tracks with ffmpeg or tsMuxer - Mix the two profile 7 BL+EL hevc tracks into one profile 4/6 BL+EL single track with yusesope tool - Remux the profile 4/6 single track in mp4 with Dolby mp4muxer - Remux the DV mp4 + audio tracks with mp4box (.mp4) or tsMuxer (.ts) or ffmpeg Edit: basically the enhancement I've proposed will avoid all the above to directly output the profile 6 .ts with tsMuxer Last edited by a5180007; 6th April 2020 at 07:07. |
6th April 2020, 07:11 | #686 | Link |
Correct me if I am mistaken:
m2ts files are part of the bluray and therefore there must be HDMV descriptors, but ts files if there are no PGS or there are DV should be without HDMV descriptors
tsmuxerCLI |
6th April 2020, 07:26 | #687 | Link | |
I agree it would have been more logical to limit hdmv compatibility to m2ts, as users always have the choice between .ts and .m2ts. Edit: you can re-open the issue if you also think it should be working this way. Last edited by a5180007; 6th April 2020 at 07:30. |
6th April 2020, 07:54 | #688 | Link | |
tsmuxerCLI |
6th April 2020, 08:09 | #689 | Link |
Limit hdmv compatibility not with .m2ts, but with .ts, because users always have a choice, but not between .ts and .m2ts, but between including PGS in .ts, then it will have HDMV descriptors or including DV in .ts, then there will be no HDMV descriptors in .ts
tsmuxerCLI |
6th April 2020, 09:49 | #690 | Link |
Life's clearer in 4K UHD
Out of interest...
Are the descriptors that are used with the AVCHD (camcorder and disc) .mts transport stream any different to the ones used for .ts and .m2ts?
6th April 2020, 10:38 | #691 | Link | |
Compared I'm UHD Bluray created in tsMuxeR GUI git-99b4679 and in tsMuxeR GUI git-2ff96ce (latest version) and be here difference in CLPI and M2TS file. A either write if will correctly playback UHD Bluray ISO created in tsMuxeR GUI git-99b4679? Thank for answer Staina |
6th April 2020, 15:36 | #693 | Link | ||
Edit: this is the way I see it working. Last edited by a5180007; 6th April 2020 at 22:16. |
7th April 2020, 03:00 | #694 | Link |
There seems to be an issue with SRT subtitles processed in tsmuxer. They show up black. PGS to PGS is fine.
Also, DV TS (dual layer profile 7.06) does not work anymore with the x700 using the latest 2020-04-07--02-11-14.zip |
7th April 2020, 06:28 | #695 | Link | |
Also anyone knows why added pgs in tsmuxer get dsynced when muxing to bluray folder? |
7th April 2020, 06:46 | #696 | Link | |
The HDMV descriptor has been removed for the DV track -I would have thought that the DV SoC did not need this descriptor, and that it was creating the pixellisation bug issue . I will push it back. |
7th April 2020, 16:37 | #700 | Link | |
Last two builds (didnt try more) definitely render black subtitles when the source has SRT subs. 2020-03-30--02-11-36.zip & 2020-04-07--02-11-14.zip |
