Old 27th May 2007, 19:25   #221  |  Link
Casimir666
Jitter test screenshots with an nVidia 6600GT :
XP / EVR : windowed mode (without D3D fullscreen option)
XP / EVR : D3D fullscreen on
XP / VMR9 : D3D fullscreen on
Vista / EVR : windowed mode (D3D fullscreen off)
Vista / EVR : D3D fullscreen on
Tired of tearing?
Try this Media Player Classic mod : http://mpc-hc.sourceforge.net
Casimir666 is offline
Old 27th May 2007, 19:51   #222  |  Link
Egh
Casimir666 is superior!!!!
Well just tested new build under gr8 nvidia 160.02 drivers.
Jitter:
1.Noticable under VMR9, both YV12 and RGB32 (from ffdshow). Not much difference in smoothness between those two.
2. EVR Custom presenter. LESS jitter compared to VMR9 for YV12, but MUCH MORE when ffdshow outputs in RGB32.
Colourspaces:
New build DOES WORK with EVR in RGB32!!!! In custom presenter only though it's enough (since i prefer to use internal subtitle renderer). It still crashes on default EVR when fed with RGB32 data.
Subtitles:
Not a bug but suggesting: would be better if you make "position subtitles to frame" as default setting.
Overall wonderful job. Pitty though you can't compare jitter with Haali renderer.
Also, is it possible for EVR custom presenter to make conversion like 601<->709 and especially TV<>PC range?
Egh is offline
Old 27th May 2007, 22:04   #223  |  Link
Casimir666
Originally Posted by Egh View Post
Subtitles:
I don't know this option? What is it use for?
Should be possible with shader i think ...
Tired of tearing?
Old 27th May 2007, 22:41   #224  |  Link
Casimir666
Colourspaces:
I have try with latest ffdshow Vista optimized, configure to do just YV12 -> RGB convertion and i have no jitter with EVR custom and no crash with EVR. What kind of video are you reading? You have something else activated on ffdshow?
Tired of tearing?
Old 28th May 2007, 03:53   #225  |  Link
Pyr0
Video N00b
Thanks for the new build Casimir666, i've been looking forward to the next release
I'm not sure if you will have had a chance to look into it (or even if you plan to al all)...
but would you happen to know why media player classic is not recognised by vista as an active application? (monitor screensaver/powersave kicks in while playing)
[edit] there's still a bug with left-clicking to pause starting the movie from the beginning again.
doesn't always happen, but seems to only happen when clicking on or near the lower black border of a video
Pyr0 is offline
Old 28th May 2007, 08:07   #226  |  Link
iron2000
Questioning User
Nice! The new build fixed my problems.
But now after using it I noticed that pictures are sharper in MPCHC, a bit too sharp, reavealing jaggy, pixelish lines.
iron2000 is offline
Old 28th May 2007, 10:32   #227  |  Link
Casimir666
Didn't seems to be possible to kick screensaver with Vista if it's password protected
http://msdn2.microsoft.com/en-us/library/ms646360.aspx
Power saving was missing i will add it.
Tired of tearing?
Old 28th May 2007, 10:43   #228  |  Link
CruNcher
CruNcher's Avatar
@Casimir666
This new Jitter Display is also nice for Debuging Decoders, detecting very small frame drops very efficient visualy , better then just to look @ the statistics numerical display, i could find this way perfect playback settings with Nvidias PureVideo Decoder and Driver and their Per Pixel Adaptive Deinterlacer but funny is the best for me is the 2d surrface not the 3d surface in terms of less jitter with VMR9 renderless, also the regular offscreen surface is more performant here (in 3D fullscreen mode with DXVA, much smoother playback) then with the 3d surface. Please add more statistics like Frame Number, DXVA mode, Colorspace, Bitrate, Sync, Cpu utilization but only mpcs counter not the whole system, filterchain in 3D fullscreen mode , hmm with Cyberlinks H.264 Decoder and 2d surface the jitter display doesn't work only the tearing test in 3d surface it does for Nvidias Mpeg-2 PureVideo it works in both so it seems also to be Decoder dependent if it works or not.
It is about Time
CruNcher is offline
Old 28th May 2007, 11:48   #229  |  Link
Pyr0
Video N00b
Thanks Casimir666
I don't actually have the screensaver enabled at all at the moment (and definitely not password protected), but I do use the power scheme set to switch off the monitor after being idle for 5 mins.
It's just really annoying to be watching a movie and the screen turns off
Pyr0 is offline
Old 28th May 2007, 13:00   #230  |  Link
Casimir666
Are you using YUV mixing option? If so try to remove it and leave just VMR9 mixer mode i think there is a bug with this option
Tired of tearing?
Old 28th May 2007, 13:32   #231  |  Link
Sirber
retired developer
Sirber's Avatar
@Casimir666
Thanks for the new release!
Detritus Software
Sirber is offline
Old 28th May 2007, 14:32   #232  |  Link
Kado
Otaku
Kado's Avatar
@Casimir666
I have no tearing with the new build using EVR but the subs still don't display properly using any renderer. Did my files reached you?
Looks promising these MPC builds.
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
Kado is offline
Old 28th May 2007, 16:26   #233  |  Link
Casimir666
Originally Posted by Kado View Post
@Casimir666
Yes i received : your sub are working on my XP but i've just discover they are not on my Vista. I'll have a look
Tired of tearing?
Old 28th May 2007, 16:34   #234  |  Link
Casimir666
Yes i've noticed : it's because i was trusting sample duration given by decoders, but they sometimes put crazy value (some even put 0! ) Next version will estimate framerate by itself.
Tired of tearing?
Old 28th May 2007, 17:39   #235  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Casimir666, I noticed a bug (?) with your MPC mod:
The problem happens with AVI files:
Sometimes MPC doesn't play the AVI from the beginning!
Instead it jumps to some random (?) position, right after I open the AVI file.
When I press "Stop" and then "Play" it plays from the beginning properly...
I tested both: MPC's internal AVI Splitter and Haali's Splitter. No difference!
There is no such problem with drevil_xxl's latest MPC build!
// EDIT
Sorry, forget about it. It was my mistake.
LoRd_MuldeR is offline
Old 28th May 2007, 17:52   #236  |  Link
Sirber
retired developer
Sirber's Avatar
Go in:
* Option
* Casimir666
uncheck "remember DVD position" and "remember file position"
Detritus Software
Sirber is offline
Old 28th May 2007, 18:00   #237  |  Link
sillKotscha
what's this for?
sillKotscha's Avatar
do I need ffdshow's postprocessing option enabled if I use EVR??...
because if I enable postprocessing in ffdshow and set it to automatic postprocessing than the picture is really blurred / to heavily post-processed... so I've disabled it
in other words - I don't need ffdshow's postprocessing anymore if I've enabled EVR ?...
thx, sill
latest mix sets: http://soundcloud.com/sill
sillKotscha is offline
Old 28th May 2007, 18:05   #238  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by Sirber View Post
Go in:
* Option
* Casimir666
I think this should be disabled by default, as it's rather confusing...
Old 28th May 2007, 18:49   #239  |  Link
Sirber
retired developer
Sirber's Avatar
same goes for D3D output. the player don't work very well with that enabled
Detritus Software
Sirber is offline
Old 28th May 2007, 19:39   #240  |  Link
Avish
Avish's Avatar
On XP, EVR doesn't seem to work with internal mpeg2 decoder... whenever I choose this combo, it automatically falls back to default video renderer. I tried several DVDs, same result.
i7-2600 | GA-B75-D3V | Tempest EVO | VX450 & XMS3 16GB | SanDisk Extreme 120GB | U2311H | MK520 | MSI GTX750 Ti Gaming | CM Hyper 212+ | APC 1KVA | Xonar DG | SoundSticks III | Win 7 x64
Avish is offline
dxva, h264, home cinema, media player classic, mpc-hc
