16th August 2014, 06:43 | #661 | Link | |
From principle: if the VapourSynth substitutes AVI, and can be opened using VFW functions of Windows, then it could work. (This is the way how Asisynth works.) Hence: Is VapourSynth engine 32-bit or 64-bit? Probably corresponding version of FRIM Encoder needs to be used. Can this VapourSynth script be opened using Windows Media Player? If yes, then FRIM Encoder could (possibly) open it as well. Maybe some tuning via ffdshow will be needed (32-bit or 64-bit respectively) |
16th August 2014, 10:48 | #662 | Link | |
And yes, the script is openned with WMP freely. I'll do some checks and report back |
19th August 2014, 07:44 | #663 | Link | |
d:\TOOLS\MyDCPConverter>Tools\FRIMEncode -avi -sbs 2 -i F:\TEMP\TRAIN-DRAGON-2_T LR-G-3D_S_RU-XX_RU-00_51_2K_TCF_20140417_DWA_IOP-3D_BD3D.vpy -viewoutput -o::mvc F:\TEMP\TRAIN-DRAGON-2_TLR-G-3D_S_RU-XX_RU-00_51_2K_TCF_20140417_DWA_IOP-3D.avc F:\TEMP\TRAIN-DRAGON-2_TLR-G-3D_S_RU-XX_RU-00_51_2K_TCF_20140417_DWA_IOP-3D.mvc -w 1920 -h 1080 -f 24 -vbr 28000 40000 -u 1 FRIM Encoder version 1.23 (build: Mar 19 2014) - based on Intel(R) Media SDK Media SDK impl SOFTWARE (d:\TOOLS\MyDCPConverter\Tools\libmfxsw32.dll) Media SDK version 1.8 Memory type System Input format YUV420 Output video AVC Source picture: Resolution 1920x1088 Crop X,Y,W,H 0,0,1920,1080 Destination picture: Resolution 1920x1088 Crop X,Y,W,H 0,0,1920,1080 Frame rate 24.000 Bitrate control VBR avg,maximum 28000,40000 GOP structure: GOP length 24 I-/P-frame distance 4 IDR-frame interval 0 GOP type Opened Num of slices 6 Target usage 1 (quality) Processing started Frame number: 72 Processing finished in 17.04 seconds Last edited by alexxdls; 19th August 2014 at 07:47. |
25th September 2014, 06:00 | #665 | Link | |
You can check all options: FRIMEncode -help However, keep on mind that Look-Ahead is not HRD (Hypothetical Reference Decoder) compliant method - per Intel documentation. |
9th October 2014, 03:22 | #667 | Link |
Frim with Intel Media SDK 2014 not working..
Due to an disc cleanup error I deleted my earlier version of the SDK (2013) I had downloaded earlier this year. I have written a routine to compress a DL 3d movie to a bdr25, it was working great. It did not create a proper 3d copy using the SDK 2014. I did manage to find a copy of SDK 2013 R2 (media SDK 1.7) that does seem to be working OK again.
Was this something I could have done wrong or has there been some subtle changes with 2014?? |
9th November 2014, 12:49 | #670 | Link | |
Just install new version. New libraries (together with newer libmfxhw64.dll) will be installed probably to "c:\Program Files\Intel\Media SDK\" . Then when calling FRIMDecode/Encode -hw (or default) will use the one which is installed. |
9th November 2014, 21:28 | #671 | Link | |
10th November 2014, 01:02 | #672 | Link | |
Thanks |
10th November 2014, 09:08 | #673 | Link | |
10th November 2014, 20:13 | #674 | Link |
I'm trying to extract the two 3D views from an MVC elementary stream into two separate yuv files and I can't seem to get FRIMDecode to produce anything. It runs for awhile, then crashes. I used MakeMKV to get the stream off the BD, then mkvextract to pull just the .264 file from the MKV.
If I run FRIMDecode (32-bit), the program runs for about 20-30 mins, then Windows reports a "This program has stopped working" dialogue box, and it closes. If I run FRIMDecode (64-bit), the program runs for about 20-30 mins and I get this error: Code:
E:\MVC>FRIMDecode -i::mvc Input.h264 -o Output_L.yuv Output_R.yuv ERROR: undeveloped feature (-3), src\pipeline_decode.cpp (114) ERROR: undeveloped feature (-3), src\pipeline_decode.cpp (785) ERROR: Cannot start decoding process. *EDIT* One last note, the Output_L.yuv and Output_R.yuv files never get made, so I'm really unsure what FRIM is doing for the 20-30 mins it runs. Last edited by blatantsubtext; 10th November 2014 at 20:16. |
12th November 2014, 20:05 | #678 | Link |
So I did some tests and it turns out that you CAN use mkvextract to get the MVC stream out of a MakeMKV-created MKV file:
mkvextract -f tracks "input.mkv" 0:output_mvc.264 --fullraw While this does add one more step and one more intermediate file, I personally think this is better than the AnyDVD + TsMuxer method, if only that MakeMKV is about US$50 cheaper than AnyDVD HD (regular price €79=~US$98). |
23rd February 2015, 12:37 | #680 | Link | |
Hi, so far I didn't have a time to explore the latest Intel Media SDK. But I plan to do it in the future and possibly bring additional bitrate control methods (e.g. LA HRD). Anyway, I presume that Intel keeps backward compatibility, so you can try to replace libmfxsw32.dll with the latest one, and everything should/could work (with some fixed bugs, of course ). Please try and report back to other users... |
encoders, mvc |
