#2 | Link |
Apparently so,
quite often, in this [where this is posted, ie MPEG-4 ASP] forum, there are way - way more forum visitors than anywhere else on the D9, so yes, ASP/XVID/DIVX is still quite popular, but I cannot say nor understand why. EDIT: Right now, in forum "MPEG-4 AVC / H.264" there are 10 Viewing, in this MPEG-4 ASP forum, there are 87 Viewing, it beats me why it is still so popular, especially given the very significant quality difference for a given filesize. [I guess many still use hardware players from pre-Android era].
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 18th June 2021 at 11:55. |
#3 | Link |
李姗倩 Lǐ Shān Qiàn
I use Xvid as a quick way to get the list of scene-change frames (as the list of keyframes). Keyframes from x264 are not so simple as those used in Xvid (a scene-change may not be a keyframe). The list is then used to programmatically detect subtitle end-time overruns (bleed) and underruns, start-time overruns and underruns.
I also use Xvid for test-encoding and checking when typesetting a moving sign, because it's quicker. For similar reasons, I sometimes use Xvid.avi for typesetting in general, rather than e.g. using x264.mkv via ffms2.dll. Xvid is quicker and not using much memory. Although, personally I no longer use Xvid as the codec for final encoding, it's still convenient for me for various purposes. There are many countries in the world, and some people are still using older CPU for various reasons. Such users may prefer Xvid.avi, as newer codecs might be too CPU-intensive for them. |
#4 | Link | |
I used to XVID a lot in my encodes until I learned of better methods and even then I did not change that easily. I am slowly transitioning to other codecs for my encodes but I still have a fondness of XVID due to low disk space and general ease-of-use. I used it for my encodes in the past but I am starting to move on to other encoders as I want to "keep up with the times."
#5 | Link | |
#6 | Link | ||
Right now 19 in AVC forum and 67 in ASP forum, nearly always the same.
A few months ago [maybe] PoisonDeathRay pointed out something like 650 online in ASP forum, its uncanny ![]() EDIT: OK, maybe more than a couple of months ago [2018] Quote:
EDIT: Arh, you already said that. Quote:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 19th June 2021 at 19:29. |
#7 | Link |
Broadcast Encoder
That's odd... but hey, apparently there are still people using it for... compatibility purposes?
I don't know... Besides, I thought MPEG-2 was far more common than Xvid, not just for DVDs that are still being produced for some odd reason, but also for all the SD 480i or 576i TV channels out there that are still on air and also HD/FULL HD standards like XDCAM which just don't wanna die... It feels weird to talk about these things in 2021, but hey, they're still a thing... ![]() |
#8 | Link |
李姗倩 Lǐ Shān Qiàn
It's not uncommon for a subbing group to do double or triple releases - the same content both as HD x264 and as SD xvid, for example. Which means, significantly many people still prefer xvid versions. I don't really know why, but I know this as a fact first hand - the download count may be like 2:1 or 3:1. (I suspect some of them are "file collectors", getting both versions "just in case").
Xvid may not be better in visual quality but it does have its forte. It's lightweight, tried and tested, player-side is always ready. Have you ever tried for example x264 with output color space 422 or 444 or even RGB? I don't think player-side is always ready yet if you use not-so-common options. Of course that does not mean newer codecs are bad - they're good and loved. But do we have to disrespect xvid just because we use newer codecs? Like, MP3 is still popular, even though there are Vorbis, AAC, Opus. |
#9 | Link | |||
Broadcast Encoder
Still, I understand the "legacy" thing and the fact that most groups have been doing SD releases in Xvid since... well... forever and they're still doing it, so... fair enough. ![]() Quote:
#10 | Link |
李姗倩 Lǐ Shān Qiàn
Okay, MP3 may not be a great example here. (However, although people say MP3 is bad and that is true in some sense, when double-blind-tested, maybe 99% of them can't ABX Lossless vs. MP3 @ 160, even @ 128. At least I can't...) Anyway, back when DivX was rather common, and coming with a bunch of unwanted bloatware, Xvid devs were stoically providing free (as in freedom), clean codec, even though there were potential legal/patent complications too. At least that's how I remember it. Newer codecs are great, yes, but we don't need to be disrespectful, especially given that Xvid is still useful in some limited areas...
#12 | Link | |
![]() When I was young and going to school, my portable music player looked very much like this: ![]() Mind you that's way more fancy than the one I owned because FM radio didn't exist and the Cue function was, if I remember correctly, a manually implemented feature involving holding the play button half way down while fast-forwarding and hoping it wouldn't end in tears. The only psychoacoustic model I was aware of when I went to school involved a portable player's lack of Dolby B to make pre-recorded cassettes sound brighter. Ahhh... how I fondly remember performing regular maintenance on my player's storage medium with a hexadecimal pencil. ![]() Seriously though.... The folks at hydrogen audio are confident the LAME MP3 encoder is transparent using the default VBR mode, despite MP3's limitations, https://wiki.hydrogenaud.io/index.ph...coder_settings which makes me happy because my current MP3 player doesn't support AAC and a quick google indicates Cowon's latest players still don't support it. I assume they've decided to save themselves the licence fee. You've inspired me to start a new thread on portable players though, as I'm considering the possibility of contemplating upgrading mine, but rather than sidetrack this thread any further I'll start a new one in the General forum. Last edited by hello_hello; 21st June 2021 at 14:52. |
#13 | Link | ||
![]() When I was a kid, my mother had [in the kitchen] a 5 band radio that had FM, and could pick up airplanes, taxi's, police, and even TV audio. EDIT: Quote:
EDIT: When I was about 12, my little brother turned a joke into a pretend competition letter [in a kids comic], star letter prize was a nifty leather cased, 3 band transistor radio. [long/short/medium wave, no FM] He said his little borther [Ie, me, his big brother] had come home from his first day at school crying, when asked why he [I] said that he was told he was gonna get free school dinners, but he only got one. [free <-> three - he won, I shoulda had half ownership I think] EDIT: Some years later, the same brother ended up fixing TV's and Radios for a company which did servicng for a big well known corporation [was owned by same corp]. The major share of repairs was on radios, and they charged £18.00 + parts as standard charge. The vast majoirty of problems was dud battery, so he spent a lot of the day just inserting new batteries and charging £18.00 + the price of the batteries. Easy money. [quite a sum about 1975] EDIT: Also, you could use a BIC biro pen instead of a hexagonal pencil to swizzle a cassette. EDIT: And the first mobile phone call was about 75 years ago [demo'ed June 17 1946, first hand held in 1973]:- https://metro.co.uk/2021/06/21/mobil...time-14790880/ EDIT: One guy I went camping with when about 14YO, had a battery operated record player, never seen one like it before nor since. EDIT: Not sure, I think the record player worked kinda like a bread toaster [just for singles, not LP's].
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 21st June 2021 at 20:57. |
#14 | Link |
I still use Fhg MP3 with BeHappy and Adobe Audition. Because? because at 128 kbps CBR is preferable to Lame, but I admit that the latter should be more efficient according to what hello_hello says. My preference for CBR is from the times of VirtualDubMod and muxing avi video with mp3 audio, this program recommends not using MP3 VBR but MP3 CBR to prevent a desynchronization, but I recently took an mp4 video and converted it into avi xvid and the audio with lame converted it to three audios: CBR, ABR and VBR. These three equal XVID videos I tested on my LG DVK-9713N and curiously I noticed that the videos with ABR and VBR audio did not get out of sync, which made me think that if I had encoded in VBR in a series that I edited a while ago in XVID the audio would have been better, since, imagine, it was 56 kbps CBR, anyway it was an extreme compression test, it is a series of 56 chapters to 28 chapters per 4.7 GB DVD.
Edit: that radio photo reminded me of my defunct Silver Crown recorder, those 80's... Last edited by GMJCZP; 21st June 2021 at 19:23. |
#15 | Link | |
Derek Prestegard IRL
![]() Join Date: Nov 2003
I know there's a pool of legacy devices (especially outside of the biggest / wealthiest countries), but this will continue to dwindle down. |
#16 | Link | |
Life's clearer in 4K UHD
The adoption of DAB+ (HE-AAC) has been very slow and sloppy here, primarily due to the quantity of early DAB radio adoptees who's devices don't support DAB+...
#17 | Link | |
I don't think my portable player had an FM receiver, but the first... cough... Hi Fi system I owned did. Remember when a Hi Fi system was made up of individual components? You bought an amplifier, a tuner, a turntable, a cassette player etc, but at some stage manufactures started combining them into "3-in-1" units. They eased us into it though by putting everything in a single box and designing it so it still looked like individual components, but wasn't. My first Hi Fi system was one of those. It did have an FM receiver but for the first year or so there weren't any FM stations broadcasting. Apparently EON FM launched sometime during the year I turned 16. I would have said it was a couple of years later, but Wikipedia says it wasn't. https://en.wikipedia.org/wiki/Timeli...adio#1980-1989 Last edited by hello_hello; 22nd June 2021 at 11:35. |
#18 | Link | |||||
Broadcast Encoder
Wow... I think about FM as something that has always been there... You guys must have been amazed by the sound quality when you moved from LW and MW to AM and FM ehehehehehehe Quote:
I mean, we're here talking about H.266 VVC getting ready soon-ish and there are people still encoding in XVID... It definitely makes you wonder... |
#19 | Link | |||
FranceBB,
HH, Quote:
I guess in Australa, take up was delayed as FM is more suited to short range, and Australia being Australia, would find longer range more useful. Quote:
EDIT: Radio Caroline and Radio Luxemburg being two, I think. Caroline:- https://en.m.wikipedia.org/wiki/Radio_Caroline Luxemburg:- https://en.m.wikipedia.org/wiki/Radio_Luxembourg Pirate Radio:- https://en.m.wikipedia.org/wiki/Pirate_radio
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 22nd June 2021 at 14:30. |
#20 | Link |
Broadcast Encoder
I didn't know LBC was so old!
I've been listening to Nick Ferrari for politics every now and then and also to Mr James O' Bryan Mystery Hour to which I also participated once in 2015 to say "It's a question, James" xD |
