Old 21st August 2016, 10:34   #41  |  Link
Selur
Selur's Avatar
I thing the point is that https://gist.github.com/4re/8676fd350d4b5b223ab9 works and https://gist.github.com/chikuzen/6103665 doesn't
Whether another sharpener (minsharp, AWarpSharp2) might be better suited for whatever sharpening hydra3333 wants to perform shouldn't really matter,..
Old 21st August 2016, 13:05   #42  |  Link
Are_
finesharp 2016.08.21, updated for Vapoursynth R33, ~10% faster for 8bit input, no difference for 16bit.
Are_ is offline   Reply With Quote
Old 21st August 2016, 13:11   #43  |  Link
Selur
Selur's Avatar
Old 21st August 2016, 16:54   #44  |  Link
hydra3333
Thank you.
Originally Posted by ~SimpleX~ View Post
This script needs an upgrade, it uses avisynth functions instead of VS equivalents. Why do you even need finesharp? It's designed for realtime sharpening of upscaled (720 -> 1080) videos. Not quite suitable for video processing.
Was just comparing it to LSFmod's output, however with the default settings it appears to be a tad brutal for my needs. Oh well. I see some posts spelling is about as fine as my lazy efforts
Old 21st August 2016, 16:58   #45  |  Link
hydra3333
Originally Posted by Are_ View Post
fiensharp 2016.08.21, updated for Vapoursynth R33, ~10% faster for 8bit input, no difference for 16bit.
Thanks. R33 hasn't a formal release. Does it work with R32 ?
edit: no it doesn't.
T:\HDTV\WDTVlive\MP4-VS\1>"C:\SOFTWARE\Vapoursynth\VSPipe.exe" "T:\HDTV\WDTVlive\MP4-VS\1\test.mpg.2016.08.22.01.28.50.60.vpy" - --y4m   | "C:\SOFTWARE\ffmpeg\0-homebuilt-x64\x264-mp4.exe" - --stdin y4m --thread-input --frames 45810 --profile high --level 4.1 --preset slow --interlaced --tff --no-cabac --crf 14 --sar 64:45 --colormatrix bt470bg -o "s:\HDTV\WDTVlive\MP4-VS\1\test-temp.2016.08.22.01.28.50.60.h264"
Script evaluation failed:
Python exception: VapourSynth version should be 33 or greater.
Traceback (most recent call last):
  File "src\cython\vapoursynth.pyx", line 1491, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:26897)
  File "T:\HDTV\WDTVlive\MP4-VS\1\test.mpg.2016.08.22.01.28.50.60.vpy", line 469, in <module>
    main()
  File "T:\HDTV\WDTVlive\MP4-VS\1\test.mpg.2016.08.22.01.28.50.60.vpy", line 154, in main
    video = finesharp.sharpen(video,mode=1,sstr=1.0)
  File "C:\SOFTWARE\Vapoursynth\finesharp.py", line 109, in sharpen
    raise EnvironmentError('VapourSynth version should be 33 or greater.')
OSError: VapourSynth version should be 33 or greater.
Old 21st August 2016, 17:44   #46  |  Link
Are_
This version of finesharp would be too slow on vapoursynth 32
Old 24th August 2016, 10:30   #47  |  Link
hydra3333
OK, am trying x64 VS R33 (it released today)
Old 16th December 2017, 19:25   #48  |  Link
Selur
Selur's Avatar
Haven't used finesharp for a while, but calling:
# Imports
import os
import sys
import vapoursynth as vs
core = vs.get_core()
# Import scripts folder
scriptPath = 'G:/Hybrid/vsscripts'
sys.path.append(os.path.abspath(scriptPath))
# Loading Plugins
core.std.LoadPlugin(path="G:/Hybrid/vsfilters/Support/fmtconv.dll")
core.avs.LoadPlugin(path="G:/Hybrid/vsfilters/SourceFilter/DGDecNV/DGDecodeNV.dll")
# Import scripts
import finesharp as finesharp
# Loading H:\to convert\test.mkv using DGSource
clip = core.avs.DGSource("H:/Temp/mkv_7ddb2a359f7f3ecc066d816f3985a1f6_14604.dgi")
# sharpening using FineSharp
clip = finesharp.sharpen(clip=clip, mode=3)
# Output
clip.set_output()
(using VS R40)
I get:
Failed to evaluate the script:
Python exception: float() argument must be a string or a number, not 'vapoursynth.VideoNode'
  File "src\cython\vapoursynth.pyx", line 1830, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:36860)
  File "H:\Temp\tempPreviewVapoursynthFile19_09_28_896.vpy", line 17, in <module>
  File "G:\Hybrid\vsscripts\finesharp.py", line 155, in sharpen
    c2 = core.std.Median(clip).std.Convolution(clip, matrix=[1, 2, 1, 2, 4, 2, 1, 2, 1])
  File "src\cython\vapoursynth.pyx", line 1702, in vapoursynth.Function.__call__ (src\cython\vapoursynth.c:34634)
  File "src\cython\vapoursynth.pyx", line 530, in vapoursynth.typedDictToMap (src\cython\vapoursynth.c:12921)
TypeError: float() argument must be a string or a number, not 'vapoursynth.VideoNode'
The finesharp script I use is Rev 2016-08-21.
-> tested a bit more and when I'm not using 'mode=..' it works, but using mode = 2 or mode = 3 causes the crash. Did I miss something or did this never work?
Cu Selur
Old 16th December 2017, 19:51   #49  |  Link
Are_
Yeah, brainfart, try it again.
Old 17th December 2017, 08:54   #50  |  Link
Selur
Selur's Avatar
Found it, changing line 155, from
to
        c2 = core.std.Median(clip).std.Convolution(matrix=[1, 2, 1, 2, 4, 2, 1, 2, 1])
fixes the issue.
Thanks for fixing.
Cu Selur
Old 17th December 2017, 12:12   #51  |  Link
Are_
I meant I brainfarted while coding that part and already fixed it in the gist, sorry for the misunderstanding.
Old 30th October 2019, 17:23   #52  |  Link
poisondeathray
I get error with some sstr values like 0.1, 0.2
But 0.25, or 0.3, or 1, or 1.2 etc... will work
File "PATH\finesharp.py", line 133, in sharpen
cstr = float(cstr)
TypeError: can't convert complex to float
Using this version 2019-10-10
clip = core.std.BlankClip(width=640, height=480, format=vs.YUV420P8, fpsnum=24, fpsden=1, length=240, color=[128, 128, 128])
fs = finesharp.sharpen(clip, sstr=0.2)
Old 31st October 2019, 01:33   #53  |  Link
Are_
Avisynth version doesn't return an error there? (No windows right here so I can't check it).
I don't know anything about math, but at some point in the code cstr becomes a complex number, and that is a problem for the rest of the script.
I think the proper solution is to put a check somewhere to tell you not to go so low with sstr if cstr is not defined.
Old 31st October 2019, 01:39   #54  |  Link
poisondeathray
No error with avs version when using sstr=0.2 or 0.1
Old 3rd November 2019, 05:06   #55  |  Link
Are_
It should be "fixed" now.
All vapoursynth finesharp scripts had a typo, truth is avisinth also throws an error when sstr goes too low and you use a mode lower than 0.
Old 3rd November 2019, 05:32   #56  |  Link
poisondeathray
Thanks working now
