Old 21st October 2019, 19:40   #141  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by ChaosKing View Post
Pushed remapframes.
There is no f3kdb repo with releases. But we have neo_f3kdb which is basically f3kdb + two more modes
Right, I completely forgot that. Then it's pointless.
Myrsloik is offline   Reply With Quote
Old 27th October 2019, 11:12   #142  |  Link
ChaosKing
What is the correct/preferred way again for package file names?
1# MyMoDulE.json <=> MyMoDulE.py
2# mymodule.json <=> MyMoDulE.py
Most script packages follows 1# but some also 2#.
I would like to correct the script packages to 1#
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
Old 27th October 2019, 11:16   #143  |  Link
ChaosKing
I noticed it because VSRepoGUI shows a link to every git package and some are not working bcs it is assumed that Module Name = File Name. Otherwise I don't know how to direct link as the url is case sensitive.
Old 27th October 2019, 12:23   #144  |  Link
Myrsloik
Myrsloik's Avatar
Simple rules:
For plugins it's always the namespace which is lowercase.
For scripts it's generally the lowercased main script filename. In case of collisions with a plugin name you append _script.
Maybe I accidentally merged something that doesn't follow this pattern in which case you're welcome to fix it.
Old 3rd November 2019, 16:01   #145  |  Link
shader
I successfully installed neo_f3kdb in VS 64bit portable on Win10. neo-f3kdb.dll is now in pluginsfolder.
But when I run "vsrepo.py installed" all installed plugins are listed except that one.
shader is offline   Reply With Quote
Old 3rd November 2019, 16:36   #146  |  Link
ChaosKing
Did you run your command with -p for portable?
vsrepo installed looks in %appdata%\VapourSynth\plugins64
vsrepo -p installed looks in plugins64
Old 3rd November 2019, 18:59   #147  |  Link
shader
@ChaosKing You got it!!!
In %appdata%\VapourSynth\plugins64 there was an old vspackages.json without neo f3kdb inside.
I just used -p for install and update, but forgot it when running installed.
