Old 14th April 2017, 11:39   #21  |  Link
Originally Posted by hello_hello View Post
Ahhhhh.... the penny has dropped. Ta.
HH, As Feisty said,
but, the effect of the entire line is to round UP to the next higher multiple of XMod (if not an exact multiple of XMod already).
StainlessS is online now   Reply With Quote
Old 15th April 2017, 09:45   #22  |  Link
hello_hello
StainlessS,
I gave myself dummy of the week award for not realising, especially as I just finished revamping my own cropping and resizing script which also included similar adjustments to achieve a particular mod.
Old 15th April 2017, 10:11   #23  |  Link
HeHeHeHeHe
My nearly all time favorite of my posts, is in response to this:- https://forum.doom9.org/showthread.p...20#post1729220
See the following few posts.
Old 16th April 2017, 22:36   #24  |  Link
I have modified OP a little, posting here first before sister thread:- https://forum.doom9.org/showthread.php?t=174527
simply because it was the "Headline" post here.
Mods,
Added args
    Int "src_left", Int "src_top", Int "src_width", Int "src_height",
    \ Bool "Pad_Rec601"
Selectable coords of input clip, [as per Crop()]
and output padding color for YUV Black, either 0 (default or 16 rec601).
Changed padding output to black.
Perhaps some scripters/scriptors/scriptess's could check it out, I'm not 100% certain that I've done it correctly. (thanks).
EDIT: xMod, yMod now default to the source clip natural colorspace alignment requirement rather than 2.
Now requires both RT_Stats and mt_tools v2.0.
EDIT Added check on xMod, yMod
    Assert(0 < xMod && xMod % DefXmod == 0, RT_String("%sIllegal xMod(%d, DefXMod=%d)",myName,xMod,DefXmod))
    Assert(0 < yMod && yMod % DefYmod == 0, RT_String("%sIllegal yMod(%d, DefYMod=%d)",myName,yMod,DefYMod))
EDIT: Added update to sister thread without thread bump.
EDIT: Oops, fixed cockup. Added in BLUE. EDIT: As we are resizing, it will not be Interlaced, will it !
    DefXmod = RT_ColorSpaceXMod     DefYmod = RT_ColorSpaceYMod(Laced=False)    # Natural ColorSpace alignment for input clip
Old 5th August 2017, 21:13   #25  |  Link
Gser
Originally Posted by MysteryX View Post
Personally I like the result of SSim very much -- but it does amplify mosquito noise. I'd suggest that in such case, mosquito noise should be removed first anyway.
Does anyone see other downsides to it? (besides performance)
Also, what Sharpness/Soft settings did you use for SSim? Perhaps using the Soft variant would reduce the mosquito amplification. I believe the ideal downsizer should have the same blurring metrics as the source. With your settings, SSim is just slightly too sharp. Also it would be good to compare Bicubic with suggested B and C settings.
MadVR has an anti-bloating feature that work wonderfully with SSim downscaling. I wonder if it is possible it add it to AvisynthShader. PS. Thanks a lot for your work, literally the only implementation I've seen of SSim for avisynth.
Gser is offline   Reply With Quote
downsize, padding, resize
