Old 15th November 2011, 15:51   #1  |  Link
VideoFanatic
Is it possible to Fix Bad Reception Artefacts with AviSynth??
I have a 720 x 480 interlaced video sample HERE (10MB in size)
There are wavey line artefacts caused by a bad TV reception. Is it possible to remove those artefacts with AviSynth? If so, could you please suggest a script. Thanks
VideoFanatic is offline   Reply With Quote
Old 15th November 2011, 17:46   #2  |  Link
Mounir
a combo of fft3d + neat should help i believe
Good news is these interferences are on the Y component only (checked with neat's component viewer), bad news is there is a lot , in the Mid frequencies at that (6,9.6,9,1) for high,mid, low freqs respectively
Otherwise there is the multiple capture technique which "may" help
the script
# need to capture the video 2 or more times
vid1 = AVISource("C:\my1stcapture.avi", fourCC="HFYU", pixel_type="YUY2")("file1.ext")
vid2 = AVISource("C:\my2ndcapture.avi", fourCC="HFYU", pixel_type="YUY2")("file2.ext")
Merge (vid1, vid2)
Probably a combination of all these for perfect result will be best:
1st medium denoising each capture then merge them
Mounir is offline   Reply With Quote
Old 15th November 2011, 17:49   #3  |  Link
VideoFanatic
Could you suggest a script for those please.
Old 15th November 2011, 18:23   #4  |  Link
Reuf Toc
You can try Defreq or FFTQuiver.
These plugin are made to remove interfering frequencies (the little waves). Sorry no script suggestion...
Reuf Toc is offline   Reply With Quote
Old 15th November 2011, 18:53   #5  |  Link
johnmeyer
Defreq is the only plugin I know of that attempts to deal with the wavy lines. However, since the lines are coming and going in your clip, and their angle and spacing changes a lot, I doubt very much that you are going to be able to get much help even from that plugin because it assumes a constant angle and distance for the interference lines.
artefacts, artifacts, avisynth, bad reception
