Old 5th June 2018, 10:55   #5401  |  Link
stefanelli73
Hi, I have noticed for some time a problem of playing my blu ray/uhd 1: 1 files, in the sense that if I go back and forth with a film the image freezes and jumps, while the audio continues to go normally, so I'm forced to stop the film and play it, but this does not happen with mkv....some solution?
stefanelli73 is offline   Reply With Quote
Old 5th June 2018, 12:15   #5402  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Upload file(s) for test.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 5th June 2018, 19:38   #5403  |  Link
73ChargerFan
73ChargerFan's Avatar
Originally Posted by mclingo View Post
is anyone else finding MPC-BE taking ages to start playing movie, even on a fresh install, its even worse when playing a movie over and RDP connection, VLC, MPC-HC and Windows 10 movies and TV all start the movie in a timely fashion where MPC can sometimes take 30 seconds to start the movie on RDP, 10-20 locally on my PC.
Once i've played it one locally however it tend to then by much quicker, however RDP it takes ages every time.
I've ask this before and didnt get a really satisfactory answers, or nothing suggested made any difference, all settings are default.
anyone any ideas before i ditch BE?
I have a similar issue. Audio plays immediately, video freezes maybe 1 second in, then whole UI freezes for about 15-30 seconds. Only on a fresh start of the player, not for subsequent videos. If I close the app, it may or not delay on restart. Same for local files, DVDs, and mkv files over the local network.
All latest updates: Windows 10 x64 pro, MPC-BE x64 (only changes to settings are to stream AC3 & DTS, and elevate process priority), AMD Pheonom II (never taxed when watching videos), nvidia 750gts, 8 gb ram. I use portable 7z version only, but I think the ini is kept in the registry because I never opted to have it stored in the file system.
Has been like this for about a year; I'm only mentioning it now because someone else has.
Is there a trace or debug w/ logging version I can try? I don't program anymore so I don't have a compiler.
73ChargerFan is offline   Reply With Quote
Old 6th June 2018, 10:48   #5404  |  Link
Magik Mark
Guys,
Where can I get instructions on using LAV filter as an External Filter?
Asus X99 Sabertooth - Xeon E5 2695 - Asus Strix GTX 960 4G - DDR4 16GB Predator - Pioneer KRP 600M (isf calibrated) - Yamaha A3030 - Windows 10 x64 - Kodi with DSplayer - Lav - MadVR - XYsubtitle
Magik Mark is offline   Reply With Quote
Old 6th June 2018, 11:26   #5405  |  Link
install lav.
add all 4 lavfilter filter as external filter with prefer: done.
disable all internal filter and have only lavfilter installed as a dshowfilter: done.
Old 6th June 2018, 11:39   #5406  |  Link
Magik Mark
Thanks huhn.
Is there a proper sequence? Which comes first, second, third & forth? Lav video, lav audio, lav splitter lav splitter source. Is this correct?
Old 6th June 2018, 12:29   #5407  |  Link
doesn't matter.
Old 6th June 2018, 16:13   #5408  |  Link
v0lt
install lav.
There is no need to do the third point if the second is done.
v0lt is online now   Reply With Quote
Old 6th June 2018, 16:15   #5409  |  Link
yes just to different ways to get the same result.
Old 6th June 2018, 16:31   #5410  |  Link
Klaus1189
install lav.
v0lt is right. If you don't disable the internal ones and imagine you have a special kind of file, that LAV Filters doesn't support, then the internal filters are used to play them.
not 100% same result, because you have alternative filters which can do the job.
Klaus1189 is online now   Reply With Quote
Old 6th June 2018, 16:46   #5411  |  Link
an argument about interpreting of or or and. you only need step 2 or 3 that'S you are done of each of them.
mpc be will always fall-back to internal decoder if nothing else is found.
Old 7th June 2018, 15:36   #5412  |  Link
Gravitator
How to make the player save the mode "Stretch to the screen size"?
Gravitator is offline   Reply With Quote
Old 7th June 2018, 16:58   #5413  |  Link
v0lt
@Gravitator
View->Options->Video->Framing->Default mode
Old 7th June 2018, 18:05   #5414  |  Link
Gravitator
@Gravitator
Спасибо.
I propose to add in the player the mode of frame-by-frame comparison of several video files?
Old 7th June 2018, 20:06   #5415  |  Link
v0lt
Originally Posted by Gravitator View Post
Спасибо.
It's nice to hear thanks in Russian. But we will not do anything like that. I advise you to compare video files using AviSynth.
Old 8th June 2018, 11:24   #5416  |  Link
Klaus1189
updated german translation based on r3710
Old 9th June 2018, 09:07   #5417  |  Link
beter
Update for translation of Chinese Traditional/Simplified and Dutch.
I have also included the Japanese one, as Socket774 is inactive for a year. If it is better leaving it to Socket774, just ignore the Japanese file.
https://www.sendspace.com/file/tsofl9
beter is offline   Reply With Quote
Old 9th June 2018, 12:34   #5418  |  Link
v0lt
@Klaus1189
Thanks. Updated in r3713.
@beter
Thanks. Updated in r3718.
Old 11th June 2018, 11:21   #5419  |  Link
Gravitator
Why do not we see the software (the lack of a hardware) HEVC-10bit decoder via a video card? On the CPU this question is not worth ...
Old 13th June 2018, 18:40   #5420  |  Link
Klaus1189
What?
