Old 5th November 2019, 21:40   #1  |  Link
AvengerOne
Script to scale videos with waifu2x.
It allows you to scale your videos using Waifu2x, without the need to export all images(10Gb-50Gb), as well as the possibility to detect duplicate frames, and save processing time.
Work with any command line program(Windows), such as:
waifu2x-conver-cpp, waifu2x-caffe, waifu2x-ncnn-vulkan. (This is supported by CUDA,CUDNN, GPU AMD, Vulkan)
"waifu2x.- Image Super-Resolution for Anime-style art using Deep Convolutional Neural Networks. And it supports photo"
https://github.com/nagadomi/waifu2x
Note: The code can be easily modified to work with any program, including gimp.
The script exports a single image, then it is processed with the program, and then the processed image is loaded.
Link Tutorial.
https://www.youtube.com/watch?v=kdbhFVZ4vIM
In the description of the YouTube video, comes a compressed file with all the necessary files (dlls)
#~ SAMPLE CODE
LoadPlugin("ffms2.dll")
LoadPlugin("CALL_25.dll")
NameVideo= "c:\My path\My Video.mp4"
FFIndex(NameVideo)
FFVideoSource(NameVideo,fpsnum=24000,fpsden=1001)
Scale=2
Noise=0
#~ directory Temp
InputImage="c:\temp\Temp.bmp"
OutputImage="c:\temp\Temp.png"
Space=" "
DirectoryProgram=""" "C:\Program Files\waifu2x-converter\" """
NameProgram="waifu2x-converter-cpp.exe"
PImageInOut = "-i" + Space + "'" +  InputImage + "'" + Space + "-o" + Space + "'" + OutputImage + "'" + Space
Parameters ="-m noise-scale -v 3 --noise-level" + Space + string(Noise) + Space + "--scale-ratio" + Space + string(Scale)
LineCommand= DirectoryProgram + Space + NameProgram + Space + Parameters + Space + PImageInOut
ConvertToRGB32()
ScriptClip("""ImageWriter(InputImage+"%n",start =current_frame, end =current_frame)""",after_frame = true)
#~ Same scale and color necessary
BilinearResize(last.Width*Scale,last.Height*Scale)
ScriptClip("""Call( "cmd /C title Frame:" + string(current_frame)+ "/" + string(last.FrameCount) + " & start /wait /B /D " + LineCommand, string(current_frame))""",after_frame = True)
ScriptClip("""ImageSourceAnim(OutputImage).BilinearResize(last.Width,last.Height)""",after_frame =true)
You can easily include the audio as well as video clippings.
AudioDub(last,A).trim(0,0)
AvengerOne is offline   Reply With Quote
Old 6th November 2019, 12:27   #2  |  Link
You might like to try CallCmd() instead of Call_25,
CallCmd() written to overcome problems inherent in Call_25.
CallCmd:- https://forum.doom9.org/showthread.php?t=166063
CallCmd() by StainlessS:- http://forum.doom9.org/showthread.php?t=166063
Based on Call by Nic:- http://forum.doom9.org/showthread.php?t=46506
CallCmd(clip,string "Command"="", string "Frames"="",string "Insert"="",int "Digits"=6,bool "Once"=true,int "Offset"=0,
  bool "Hide"=false,bool "Debug"=false,string "Open"="",string "Close"="",int "Synchronous"=7)
Command (default"")
 A command string that will be executed on each frame specified by the Frames arg. Can contain a single INSERT arg character
 which will be replaced by a string representing the frame number with optional OFFSET. If the command naturally contains the
 INSERT character then choose a different INSERT charcter or use two INSERT characters in the Command string to escape it
 (one of them will be removed in the executed command).
Frames (default "")
 String to specify the frames upon which the COMMAND arg is executed.
 Comments beginning with '#' can occur in the FRAMES arg, SEMICOLON Cannot be used in a comment.
 SEMICOLON ";" or NewLine [Chr(10)] is used as a frame specifier terminator.
 COMMA "," specifies a frame range where the 2nd range end number can be '0' meaning last frame, and eg '-4' meaning 4 frames.
 "0,0" Specifies ALL frames.
 Example:
    FRAMES="
      1           # This is a comment, calls on frame 1.
      3;5;7       # Calls on frames 3 and 5 and 7, SEMICOLON is SOFT End Of Line and terminates any COMMENT.
      8           # Call Frame 8 ; 10 # *** IMPORTANT *** And because of SEMICOLON also calls on Frame 10.
      14,16       # Calls on frames 14 to 16, COMMA specifies a frame range.
      18,20;22    # Calls on Frame range 18 to 20 and frame 22.
      24,-4       # Specifies frames 24 to 27, ie 4 frames starting at frame 24.
Insert (default "")
  Single character which will be replaced in the Command arg string by frame number + OFFSET arg.
  If the command naturally contains an INSERT character then choose a different INSERT arg charcter or use two INSERT characters
  in the Command string to escape the naturally occuring one (one of them will be removed in the executed command).
Digits (default 6)
  Minimum number of digits generated in inserted text that replaces the INSERT character in the COMMAND arg.
Once (default=true)
  If true then only executes frame commands once on each frame, if replayed, does not exec 2nd time.
Offset (default 0)
  Offset added to frame number when generating text inserted into a frame command replacing the INSERT character.
Hide (default false)
 If true, hide black console window on command execution.
Debug (default false)
 If true, sends debug info to DebugView Window.
 DebugView (Highly recommended, allows viewing of info and warnings from the plugins and other programs)
 http://technet.microsoft.com/en-gb/sysinternals/bb545027
Open (default "")
  Command executed on plugin start up (Constructor), before first frame.
  No string replacements, ie INSERT, DIGITS and OFFSET have no effect.
Close (default "")
  Command executed on plugin close down (Destructor), after last frame.
Synchronous (default 7, range 0 - 7)
  The Synchronous arg is a group of 3 bitflags,
    bit 0 if set means wait for process to terminate before returning from the 'Open' command.
    bit 1 if set means wait for process to terminate before returning from the 'Frames' commands.
    bit 2 if set means wait for process to terminate before returning from the 'Close' command.
      0 = All Asynchronous, ie dont wait at all.
      1 = Wait only on 'Open' command.
      2 = Wait only on 'Frames' commands.
      3 = Wait on 'Open' and 'Frames' commands.
      4 = Wait on 'Close' command.
      5 = Wait on 'Open' and 'Close' commands.
      6 = Wait on 'Frames' and 'Close' commands.
      7 = Wait on ALL commands (default).
   Beware, if you dont wait it is very possible that any future reliance upon output of command may fail due to the
   output file being in use. Also, if debug true and waiting for process to complete, then will also show the process return
   code on successful process creation (and completion) in DebugView, cannot do this if NOT waiting completion.
CallCmd, does NOT replace single quotes with double quotes in Command string, was source of problems in Call().
Instead wrap eg filenames containing spaces in double-quotes using perhaps:
 Function QuoteStr(String s) { return Chr(34) + s + Chr(34) }
or use triple and single double-quotes eg
  CallCmd(BlankClip,Close="""d:\nicecho.exe @d:\report.txt "Appending" """)
Executing on each playing, on every frame, hiding console window, sending debug info to debugview, and converting
command string on frame eg 0 to  "C:\PortableApps\ImageMagick\Mogrify.exe -flop C:\Temp\000000.tif"
  CallCmd(clip,"C:\PortableApps\ImageMagick\Mogrify.exe -flop C:\Temp\#.tif", "0,0",Insert="#",Once=false,Hide=true,Debug=true)
At Open, executes delete on wildcard files silently, without asking confirmation.
  CallCmd(Open="""cmd /c DEL /Q "C:\TEMP\test_*.tif" """)
To execute DOS type commands, in DOS console type "cmd /?" for cmd options, and eg DEL /? for delete options.
included Avsiynth v2.58, avs+ v2.6 x86, and Avs+ x64 dll's.
There is also RT_Call() in RT_Stats, simpler but could probably also be more usable than Call_25 and avoids its problems.
Post from CallCmd thread, where Vampirdom used a hack to try overcome Call_25 problems
Originally Posted by vampiredom View Post
I simply MUST try this ... I would love to get rid of my crazy Call25Helper.exe hack. Unfortunately, I have been really short on time to test out new things. I will try this out and get back to you. Thanks, Stainless.
Link into Original Call_25 thread:- https://forum.doom9.org/showthread.php?p=1547266
EDIT: There was mention of a copy to/from clipboard idea in above linked Call_25 thread, I implemented that some time ago too:- https://forum.doom9.org/showthread.php?t=176145
EDIT: There are also some threads where Martin53 had some unusual requirements for CallCmd(), and ways to achieve them, maybe do search if of interest.
EDIT: I quite often use CallCmd() to delete temp files on clip closure.
Old 6th November 2019, 20:31   #3  |  Link
AvengerOne
Thanks, I will try it.
anime, cuda, vulkan, waifu2x
