Go Back   Doom9's Forum > Programming and Hacking > Translations
Old 14th September 2004, 22:11   #1  |  Link
forsakenlad
Junior Member
Frontpage
Guys when I first downloaded the site I realized that the site was not authored in Frontpage. And I spent days converting it to Frontpage compatible. (Like turning all the layers into tables and stuff). Now the layout in Frontpage is perfect. If anyone needs to translate and likes to use Frontpage. I can send them the original english-frontpage version.
BTW: The turkish mirror will be on the net in about 3-4 days.
(Doom9, is there any way that you can make that leech window not show up when someone clicks a download link from my site)
forsakenlad is offline   Reply With Quote
Old 15th September 2004, 07:38   #2  |  Link
Doom9
clueless n00b
Make sure you get a turkish.doom9.org vhost for your mirror and the anti-leech is not going to be a problem.
BTW, I didn't use any layers as far as I know.. but my CSS are way more efficient than using tables, in fact Frontpage adds a lot of proprietary crap to HTML that only IE understands and that's not a good thing.
Doom9 is offline   Reply With Quote
Old 15th September 2004, 12:04   #3  |  Link
forsakenlad
Junior Member
Yeah you are right. I think it was because of my crappy site downloader. Anyway I saved the site with IE and the layers were gone. Sorry for that...
(BTW: Should I use SQL or Access for the forum?)
Old 15th September 2004, 12:23   #4  |  Link
Doom9
clueless n00b
SQL is a query language, not a DB server so I presume you mean MS SQL server vs. Access. Definitely the former then.
Old 15th September 2004, 12:28   #5  |  Link
forsakenlad
Junior Member
Yeah thats what i meant. I'll use the former one then. Thanx
