#2 | Link |
Errors can probably be added on the google forum. I create non-professional codecs in GCC. On Windows there is Visual Studio and others that have assembler and simd support.
Codec WebP2 works without AOM codecs. So all other AOM add-ons ie AVIF, DV1D, GAV1 will also not work under GCC. |
#3 | Link |
Yes, compile errors with details should be reported there:
https://bugs.chromium.org/p/webp2/issues/list These pre-compiled binaries links can be posted here, indeed. |
#4 | Link |
Btw, for definiteness here are some command line examples if you want to test encoding / decoding:
cwp2 cat.png -o cat.wp2 -d cat.wp2.png -q 44 avifenc --min 40 --max 40 -s 2 cat.png cat.avif avifdec cat.avif cat.avif.png cwebp cat.png -o cat.webp -q 16 dwebp cat.webp -o cat.webp.png ==== |
#5 | Link |
![]() Join Date: Jan 2006
So, this is an enhanced encoder for the VP8 "WebP" format?
Do we care about WebP? I've not really seen exciting real-world implementations that were enough better than JPEG to merit the extra work, or close enough to HEIF H.264 that building a JavaScript implementation of that leveraging HW H.264 decoders wouldn't make more sense at scale. And AVIF is certainly going to outperform WebP while addressing the same licensing goals. |
#7 | Link | |
I see WebP quite ofent in internet.
Chrome/Firefox/Edge support WebP. Such popular sites in Latin America as www.mercadolibre.com uses WebP. Quote:
WebP has its advantages on certain range of bitrates https://www.reddit.com/r/AV1/comment...if_comparison/ Last edited by IgorC; 23rd November 2020 at 23:06. |
#8 | Link | |
And yes, it's used a lot. |
#9 | Link | |
dwp2.exe -v image_21447.wp2 -mt -o image_21447_64bit.jpg Time to decode picture: 0.415s Decoded image_21447.wp2. Dimensions: 1563 x 1558. Transparency: no. Could not save to 'image_21447_64bit.jpg' Error: unsupported feature Status: WP2_STATUS_UNSUPPORTED_FEATURE Code:
dwp2.exe -v image_21447.wp2 -mt -o image_21447_64bit.webp Time to decode picture: 0.399s Decoded image_21447.wp2. Dimensions: 1563 x 1558. Transparency: no. Could not save to 'image_21447_64bit.webp' Error: unsupported feature Status: WP2_STATUS_UNSUPPORTED_FEATURE Strange settings help av1enc. 'O' is not output and 'D' is not decode. What does not working 'o' and 'd' mean? Code:
av1enc.exe -444 -size 1563x1558 -O image_21447_64bit.png aom_codec_decode() failed. Error compressing to AV1 To produce the avif with png you must add the 'D'. Why? Code:
av1enc.exe -avif -420 -size 1563x1558 -D image_21447_64bit.avif -O image_21447_64bit.png 674650 35.965336 (99.000000 35.446957 39.947750 34.281830) [ 2.22 bpp ] [ 1563 x 1558 ] [73.223 / 0.632 secs] Saved decoded image image_21447_64bit_dec.png Saved encoded file: image_21447_64bit.av1 (674650 bytes) <-- ???? Code:
av1enc.exe -avif -444 -size 1563x1558 -D image_21447_64bit.avif -O image_21447_64bit.png ERROR: Failed to encode: Decoding of color planes failed Error while computing the distortion. File decoding RAW converted as TIFF RAW_CANON_EOS_5DS.cr2 8688x5792 Long waiting time. On my old computer thread 4 it is about 10 minutes. Code:
cwp2.exe RAW_CANON_EOS_5DS.tiff -summary -lossless -mt -o RAW_CANON_EOS_32bit.wp2 Assertion failed: std::abs(progress_ + kProgressEnd - 1.f) < 0.001f, file progress_watcher.cc, line 52 Last edited by Jamaika; 24th November 2020 at 08:35. |
#11 | Link | ||
Sorry, i'm not an avifenc/avifdec specialist, just tried it quickly on Unix.
If you are interesting in non-8bit input/output, you can have a look at some tools in the 'extras' directory. For instance 'ewp2'. They can handle Y4M format. Quote:
You may want to recompile at HEAD to fix it (commit df4ec90a2befb79ed45cf8810e8ac93da7a47297). Yes. By default, cwp2 will copy EXIF, XMP and ICC metadata. |
#12 | Link |
WebP 2 df4ec90, MinGW 64, GCC 10.2.0
dwp2 Code:
[ 90%] Building CXX object CMakeFiles/dwp2.dir/examples/dwp2.cc.obj C:/msys64/home/Scope/libwebp2/examples/dwp2.cc: In function 'std::string {anonymous}::PrintSummary(const WP2::BitstreamFeatures&, size_t, bool)': C:/msys64/home/Scope/libwebp2/examples/dwp2.cc:207:37: error: unknown conversion type character 'z' in format [-Werror=format=] 207 | str += SPrintf("file size: %zu\n", input_data_size); | ^ [ 91%] Building CXX object CMakeFiles/extras.dir/extras/extras.cc.obj cc1plus.exe: all warnings being treated as errors make[2]: *** [CMakeFiles/dwp2.dir/build.make:82: CMakeFiles/dwp2.dir/examples/dwp2.cc.obj] Error 1 make[1]: *** [CMakeFiles/Makefile2:261: CMakeFiles/dwp2.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... Code:
Performing C++ SOURCE FILE Test WP2_HAVE_FLAG___SSE4_2__ failed with the following output: Change Dir: C:/msys64/home/Scope/libwebp2/build/CMakeFiles/CMakeTmp Run Build Command(s):C:/msys64/usr/bin/make.exe cmTC_f9854/fast && /usr/bin/make -f CMakeFiles/cmTC_f9854.dir/build.make CMakeFiles/cmTC_f9854.dir/build make[1]: Entering directory '/home/Scope/libwebp2/build/CMakeFiles/CMakeTmp' Building CXX object CMakeFiles/cmTC_f9854.dir/src.cxx.obj /C/msys64/mingw64/bin/g++.exe -DWP2_HAVE_FLAG___SSE4_2__ -o CMakeFiles/cmTC_f9854.dir/src.cxx.obj -c /C/msys64/home/Scope/libwebp2/build/CMakeFiles/CMakeTmp/src.cxx C:/msys64/home/Scope/libwebp2/build/CMakeFiles/CMakeTmp/src.cxx: In function 'int main()': C:/msys64/home/Scope/libwebp2/build/CMakeFiles/CMakeTmp/src.cxx:4:9: error: invalid use of 'this' in non-member function 4 | this is not valid code | ^~~~ make[1]: *** [CMakeFiles/cmTC_f9854.dir/build.make:85: CMakeFiles/cmTC_f9854.dir/src.cxx.obj] Error 1 make[1]: Leaving directory '/home/Scope/libwebp2/build/CMakeFiles/CMakeTmp' make: *** [Makefile:140: cmTC_f9854/fast] Error 2 Source file was: int main(void) { #if !defined(__SSE4_2__) this is not valid code #endif return 0; } |
#14 | Link |
If I'm wasting my time I'm a bit of a piss off the creators.
![]() Converting DNG to WEBP2 with metadata ICC, XMP, EXIF Code:
TIFFFetchNormalTag: Warning, Incorrect value for "RichTIFFIPTC"; tag ignored. Dimension: 5212 x 3468 animation: no quality hint: 15 preview: no preview color: 102, 85, 51 rotated by: 0 degrees clockwise transfer: 0 ICC: no <-- ??? XMP/EXIF: no <-- ??? output size: 31860621 (14.10 bpp) [RAW_CANON_EOS_32bit.wp2] Last edited by Jamaika; 25th November 2020 at 07:44. |
#15 | Link | |
Best is to open an issue on the bug tracker, with all the infos. But it looks like a libtiff issue, honestly... |
#16 | Link |
Everything is here. The rest for those willing.
New codecs, untestet with bugs fixed 25.11.2020 https://www.sendspace.com/file/dbx3jx Added: https://chromium.googlesource.com/co...8ac93da7a47297 https://gitlab.com/libtiff/libtiff/-...81479c267febaa https://github.com/m-ab-s/aom/commit...339afb1c3baaf5 https://github.com/AOMediaCodec/liba...ee872c78c0bdb9 https://github.com/libjpeg-turbo/lib...e2cc49cde3b1ac https://github.com/webmproject/libwe...085206947e98f2 https://github.com/dcnieho/FreeGLUT/...c90462ad0c6f50 https://github.com/glennrp/libpng/co...4b0666549b18e6 https://github.com/madler/zlib/commi...44df991c499252 GCC 10.2.1 http://msystem.waw.pl/x265/mingw-gcc1021-20200926.7z Last edited by Jamaika; 25th November 2020 at 09:02. |
#18 | Link |
WebP 2 7c0dceb, MinGW 64, GCC 10.2.0
[ 89%] Built target ansz C:/msys64/home/Scope/libwebp2/examples/example_utils.cc: In function 'std::string WP2::PrintSummary(const WP2::BitstreamFeatures&, size_t, bool)': C:/msys64/home/Scope/libwebp2/examples/example_utils.cc:157:20: error: unknown conversion type character 'l' in format [-Werror=format=] 157 | str += SPrintf("file size: %" PRIu64 "\n", (uint64_t)input_data_size); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ cc1plus.exe: all warnings being treated as errors make[2]: *** [CMakeFiles/example_utils.dir/build.make:82: CMakeFiles/example_utils.dir/examples/example_utils.cc.obj] Error 1 make[1]: *** [CMakeFiles/Makefile2:463: CMakeFiles/example_utils.dir/all] Error 2 make: *** [Makefile:160: all] Error 2 CMakeError.log Code:
Performing C++ SOURCE FILE Test WP2_HAVE_FLAG___SSE4_2__ failed with the following output: Change Dir: C:/msys64/home/Scope/libwebp2/build/CMakeFiles/CMakeTmp Run Build Command(s):C:/msys64/usr/bin/make.exe cmTC_f12f3/fast && /usr/bin/make -f CMakeFiles/cmTC_f12f3.dir/build.make CMakeFiles/cmTC_f12f3.dir/build make[1]: Entering directory '/home/Scope/libwebp2/build/CMakeFiles/CMakeTmp' Building CXX object CMakeFiles/cmTC_f12f3.dir/src.cxx.obj /C/msys64/mingw64/bin/g++.exe -DWP2_HAVE_FLAG___SSE4_2__ -o CMakeFiles/cmTC_f12f3.dir/src.cxx.obj -c /C/msys64/home/Scope/libwebp2/build/CMakeFiles/CMakeTmp/src.cxx C:/msys64/home/Scope/libwebp2/build/CMakeFiles/CMakeTmp/src.cxx: In function 'int main()': C:/msys64/home/Scope/libwebp2/build/CMakeFiles/CMakeTmp/src.cxx:4:9: error: invalid use of 'this' in non-member function 4 | this is not valid code | ^~~~ make[1]: *** [CMakeFiles/cmTC_f12f3.dir/build.make:85: CMakeFiles/cmTC_f12f3.dir/src.cxx.obj] Error 1 make[1]: Leaving directory '/home/Scope/libwebp2/build/CMakeFiles/CMakeTmp' make: *** [Makefile:140: cmTC_f12f3/fast] Error 2 Source file was: int main(void) { #if !defined(__SSE4_2__) this is not valid code #endif return 0; } Last edited by Scope; 25th November 2020 at 19:34. |
#19 | Link |
I would also add this in vwp2.cc:
#if defined(__unix__) || defined(__CYGWIN__) } else if (key == 'x' || key == 'X') { Modify(wp2dbg_value_, 2u, key == 'x'); setenv("WP2DBG", (wp2dbg_value_ == 0) ? "0" : "1", 1); if (!EncodeAndDecode()) return; AddInfo(SPrintf("export WP2DBG=%d", wp2dbg_value_)); #endif Code:
#if defined(__unix__) || defined(__CYGWIN__) for (size_t i = 0; i < std::max((size_t)1, env_vars.size()); ++i) { #endif ... #if defined(__unix__) || defined(__CYGWIN__) if (!env_vars.empty()) { setenv(env_vars[i].first.c_str(), env_vars[i].second.c_str(), 1); if (env_vars.size() > 1) { // Only append it to the file name if there are several env vars. suffix = "_" + env_vars[i].first; if (!env_vars[i].second.empty()) suffix += "_" + env_vars[i].second; } } #endif ... #if defined(__unix__) || defined(__CYGWIN__) if (!env_vars.empty()) { unsetenv(env_vars[i].first.c_str()); } #endif ... #if defined(__unix__) || defined(__CYGWIN__) } #endif Last edited by Jamaika; 25th November 2020 at 19:59. |
