18th September 2008, 05:44 | #1 | Link |
MJPEG METASOFT codec on Vista 64
Hi.
I use to use the free Metasoft MJPEG codec since 2002 because it is very simple, fast, and the quality is OK. (http://www.metasoft.pl/pl/compressors.html) I installed Vista 64 on my workstation this year, and I have been looking for a way install this MJPEG codec on it, because the usual right click/install on the .inf file did not work, and I finally found how to install it on vista 64. so I wanted to share this experience with you. Here is how: The metasoft codec is composed of 2 files (MJPEG.dll, MJPEG.inf). 1. open a command prompt 2. go to the SysWOW64 folder (cd c:\Windows\SysWOW64) 3. type this command and replace [folder] with the path to the inf file: rundll32.exe setupapi.dll,InstallHinfSection DefaultInstall 0 [FOLDER]\MJPEG.inf That's all. I hope it helps. regards |
codec, metasoft, mjpeg, vista, x64 |
