Old 24th April 2022, 21:22   #1  |  Link
DavidRTurner
How to extract PGS subs from BD when video is over multiple M2TS files?
For BD discs, I want to create MP4s with soft subs for my media box.
When a BD sub track is NOT in PGS format, I use MKV Toolnix to create MKS files for the subs from a full-video M2TS file. And then do the same for extras/features/etc. I then use Subtitle Edit to handle the sub files & create SRTs and then create the MP4s by matching the SRTs to the M2TS files.
But when the main video is split across multiple M2TS files, I have had to extract them individually, and then join them together. This is a pain, and often causes sync issues.
I can use HandBrake/VidCoder to extract the video & PGS subs because they can read the playlist of the individual files, but the subs are hard-coded. Don't want that, especially when there are 2nd/3rd audio tracks & subs.
Is there software that will extract subs from multiple-file M2TS videos? Presumably by using a MPLS playlist file?
*I'll nip this suggestion in the bud; I know I can download subs from various websites for movies. I want to do this from the BluRay itself.
DavidRTurner is offline   Reply With Quote
Old 24th April 2022, 23:32   #2  |  Link
Rumbah
Eac3To can do that.
Rumbah is offline   Reply With Quote
Old 25th April 2022, 08:50   #3  |  Link
Ritsuka
HandBrake hard-codes the PGS subs only the selected output format is MP4, if you select MKV it won't (automatically hard-code them).
Ritsuka is offline   Reply With Quote
Old 25th April 2022, 08:54   #4  |  Link
varekai
varekai's Avatar
tsMuxer will do it, input, point on corresponding .mpls and select pgs, demux... easy peasy.
varekai is offline   Reply With Quote
Old 26th April 2022, 09:10   #5  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
And DGDemux does demux following .mpls
Emulgator is online now   Reply With Quote
Old 27th April 2022, 14:46   #6  |  Link
DavidRTurner
I'm horrified I never knew this, as I've only used it for MP4s. I never explored the presets so I never came across the MKV option.
But it works; so I don't have to change software.
Thanks very much!!!
Old 27th April 2022, 14:47   #7  |  Link
DavidRTurner
Thanks - not as peasy as I'd like (i.e. having to find the right playlist file first), but it's an option I know of now.
Old 27th April 2022, 14:48   #8  |  Link
DavidRTurner
Originally Posted by Rumbah View Post
Eac3To can do that.
Had some trouble with eac, but I can see that it WOULD work if I gave it some more effort. Thanks.
bluray, srt, subtitles
