Old 17th February 2025, 10:03   #221  |  Link
stimco
btw, did you move the progress bar in order to check out the preview ? Sometimes, the 1st frames are blanked. Thats why you see nothing.
I gave you an example with LSMASH.
everything is ok there.
the frame is the same.
the problem really exists.
https://ibb.co/wrW5KRcg
https://ibb.co/jPN1h0tB
stimco is offline   Reply With Quote
Old 17th February 2025, 10:28   #222  |  Link
Kurt.noise
Remove the content from the update_cache sub-folder and retry to download ffms and see whats happening.
Did you get also the issue using another source file ?
Kurt.noise is offline   Reply With Quote
Old 17th February 2025, 12:47   #223  |  Link
stimco
did... nothing changed.
-[Information] FileIndexer
--[Information] [17.02.2025 13:42:26] MediaInfo
---[Information] File: F:\Avengers_IW.2018.UHD.Blu-Ray.Remux.mkv
---[Information] General
----[Information] Format: Matroska
----[Information] FileSize: 51429928616
----[Information] PlayTime: 02:29:21.953
---[Information] Video
----[Information] ID: 1
----[Information] StreamOrder: 0
----[Information] CodecID: V_MPEGH/ISO/HEVC
----[Information] Format: HEVC
----[Information] FormatInfo: High Efficiency Video Coding
----[Information] Width: 3840
----[Information] Height: 2160
----[Information] FrameCount: 214872
----[Information] FrameRate: 23.976
----[Information] FrameRate_N: 24000
----[Information] FrameRate_D: 1001
----[Information] FrameRateMode: CFR
----[Information] FrameRateModeString: Constant
----[Information] Duration: 02:29:21.953
----[Information] Bits Depth: 10
----[Information] AspectRatio: 1.778
----[Information] AspectRatioString: 16:9
----[Information] PixelAspectRatio: 1.000
----[Information] Delay: 0
----[Information] Default: Yes
----[Information] Forced: No
-[Information] Log for job1 (idx, Avengers_IW.2018.UHD.Blu-Ray.Remux.mkv -> Avengers_IW.2018.UHD.Blu-Ray.Remux.mkv.ffindex)
--[Information] [17.02.2025 13:42:28] Started handling job
--[Information] [17.02.2025 13:42:28] Preprocessing
--[Information] [17.02.2025 13:42:28] Job command line: "C:\Users\stimco\Desktop\1\tools\ffms\ffmsindex.exe" -f "F:\Avengers_IW.2018.UHD.Blu-Ray.Remux.mkv" "F:\Avengers_IW.2018.UHD.Blu-Ray.Remux.mkv.ffindex"
--[Information] [17.02.2025 13:42:28] Process started
--[Information] [17.02.2025 13:42:28] Standard output stream
---[Information] [17.02.2025 13:43:35] Writing index... done.
--[Information] [17.02.2025 13:42:28] Standard error stream
--[Information] [17.02.2025 13:43:35] MediaInfo
---[Information] File: F:\Avengers_IW.2018.UHD.Blu-Ray.Remux.mkv.ffindex
----[Information] FileSize: 1086901
--[Information] [17.02.2025 13:43:35] Postprocessing
---[Information] [17.02.2025 13:43:38] Deleting intermediate files
--[Information] [17.02.2025 13:43:38] Job completed
https://ibb.co/qMrr66Z1
LSMASH OK ... https://ibb.co/5WTq3HD2
Old 17th February 2025, 13:43   #224  |  Link
Kurt.noise
Then stay with lsmash...or do you prefer ffms ? Its quite similar.
You did not tell me if issue occured also with another source.
Old 17th February 2025, 13:51   #225  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
About that black preview, sometimes I get it too (with lsmash), usually hitting "Preview AVS script" button fixes it, or I restart indexing again to fix.
VoodooFX is offline   Reply With Quote
Old 17th February 2025, 13:54   #226  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
I remember having this issue with ffms quite a while ago. That's what made me switch to DGIndexNV.
But anyhow, use the goto function and don't enter any new frame number, just hit ok. That restarts your script and usually fixed the black frame issue for me.
LeXXuz is offline   Reply With Quote
Old 17th February 2025, 17:44   #227  |  Link
stimco
I don’t understand.. how it doesn’t work and to hell with it.
This is a problem with the last two versions. maybe you can fix it.
I like FFMS better. And I don't want to change that.
The log indicates that the source was different source.
Believe me, I checked it 20 times.
Maybe the creator of FFMS can fix this.
Old 18th February 2025, 03:58   #228  |  Link
Kurt.noise
What can I say...I tested the same input as yours and that worked correctly on my side :
[Information] Log
-[Information] Versions
--[Information] MeGUI: 6.6.6.6 20250210 x64 (DEBUG)
--[Information] MeGUI Debug Data: available
--[Information] Update Check: Disabled
--[Information] System Information
---[Information] Operating System: Microsoft Windows 11 Professionnel 24H2 x64 (10.0.26100.3194)
---[Information] .NET Framework: 4.8.1
---[Information] Redistributables
----[Information] Microsoft Visual C++ 2010 x86:  10.0.40219
----[Information] Microsoft Visual C++ 2015-2022 x64:  14.42.34433
----[Information] Microsoft Visual C++ 2015-2022 x86:  14.42.34433
---[Information] DPI: 100% (96/96)
---[Information] Monitor 1
----[Information] Resolution: 1920x1080
----[Information] Primary Screen: True
---[Information] Monitor 2
----[Information] Primary Screen: False
--[Information] Component Information
---[Information] Haali Media Splitter: not installed
---[Information] Haali DSS2: not installed
---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (24-03-2024)
---[Information] MediaInfo: 24.12.0.0 (11-12-2024)
---[Information] SevenZipSharp: 0.64.3890.29348 (24-03-2024)
---[Information] 7z: 9.20 (24-03-2024)
--[Information] AviSynth Information
---[Information] AviSynth Wrapper
----[Information] Version: 1.0.3000.1
----[Information] Date: 25-11-2024
----[Information] Interface: 6
----[Information] File Version: 3.7.3
----[Information] File Date: 08-02-2025
----[Information] File Name: AviSynth+ 3.7.3 (r4177, master, x86_64)
----[Information] File Path: c:\windows\system32\avisynth.dll
----[Information] AviSynth Version: AviSynth+ 3.7.3 (r4177, master, x86_64)
----[Information] AviSynth+: true
----[Information] AviSynth MT: true
-[Information] Update detection
--[Information] [18/02/2025 03:39:40] Automatic update is disabled
--[Information] [18/02/2025 03:39:40] Using cached update config and server: http://megui.org/auto/fork/
--[Information] [18/02/2025 03:39:40] No package requires an update
--[Information] [18/02/2025 03:39:54] MediaInfo
---[Information] File: E:\Video\The.mkv
----[Information] FileSize: 756091318
----[Information] PlayTime: 00:02:00.736
----[Information] FrameCount: 2892
----[Information] Duration: 00:02:00.621
----[Information] Delay: 17
--[Information] Log for job1 (idx, The.mkv -> The.ffindex)
--[Information] [18/02/2025 03:40:04] Started handling job
--[Information] [18/02/2025 03:40:04] Preprocessing
--[Information] [18/02/2025 03:40:04] Job command line: "E:\megui\bin\x64\Debug\tools\ffms\ffmsindex.exe" -f "E:\Video\The.mkv" "E:\Video\The.mkv.ffindex"
--[Information] [18/02/2025 03:40:04] Process started
--[Information] [18/02/2025 03:40:04] Standard output stream
---[Information] [18/02/2025 03:40:06] Writing index... done.
--[Information] [18/02/2025 03:40:04] Standard error stream
--[Information] [18/02/2025 03:40:06] MediaInfo
---[Information] File: E:\Video\The.mkv.ffindex
----[Information] FileSize: 13319
--[Information] [18/02/2025 03:40:06] Postprocessing
---[Information] [18/02/2025 03:40:09] Deleting intermediate files
--[Information] [18/02/2025 03:40:09] Job completed
Indexing is done flawlessly and I'm able to create avs script from the AVS Creator. And btw, looking at your logfile, indexing is done correctly too.
So, your problem seems to be somewhere else...
Try the ffms from there (replace the content in ffms subfolder) : https://codeberg.org/StvG/ffms2/rele...ffms2_r2390.7z
Old 18th February 2025, 06:53   #229  |  Link
stimco
Yes, the file is indexed, but there is no video in the window for trimming, the screen is dark.
I previously used MeGUI 6.6.6.6 - 20240823 there were no such problems. But now, even if you run this version, after installing the latest updates, a problem will appear here.
Below I’ll leave it as a working version without glitches. MeGUI 6.6.6.6 - 20240823 is the basis and is based on its old updates.
https://ru.files.fm/u/crfruwz2kt
Old 18th February 2025, 07:24   #230  |  Link
stimco
I took MeGUI 6.6.6.6 - 20250210 .exe and placed it in the old version of MeGUI 6.6.6.6 - 20240823 and everything works. But if you download updates from the new version, then everything... does not work.
Old 18th February 2025, 09:13   #231  |  Link
LeXXuz
LeXXuz's Avatar
BUG(?):
Nvidia Deinterlacer not selectable/not working in AVS script creator.
(Also not working in 1-Click Encoder for ages)
Source is a clip from an SD interlaced source MPEG2 elementary stream, indexed with DGIndexNV.
Old 18th February 2025, 09:48   #232  |  Link
Kurt.noise
stop the fud.
Old 18th February 2025, 09:49   #233  |  Link
Kurt.noise
Originally Posted by LeXXuz View Post
BUG(?):
what the dgi looks like ? iirc, this is enabled from the specific content of the file.
Old 18th February 2025, 09:52   #234  |  Link
LeXXuz
LeXXuz's Avatar
Good point. Well, here is the header of the index file:
DGMPGIndexFileNV25 DGIndexNV 255.0.0.0 X64
C:\Program Files\MeGUI-x64\tools\dgindexnv\
E:\WORK\test.m2v 852748705
DEVICE 0
DECODE_MODES 0,0,0,0,0
STREAM 0 0
RANGE 0 0 852748704 0
DEMUX
DEPTH 8
CHROMA_LOCATION 0
ASPECT 12 11
COLORIMETRY 2 2 2
IS_444 0
SEQ 0
SEQEXT 0
GOP 1
0:FRM B 3 1 0 0
1:FRM B 3 1 0 0
2:FRM I 3 1 0 0
3:FRM B 3 1 0 0
4:FRM B 3 1 0 0
5:FRM P 3 1 0 0
6:FRM B 3 1 0 0
7:FRM B 3 1 0 0
8:FRM P 3 1 0 0
9:FRM B 3 1 0 0
10:FRM B 3 1 0 0
11:FRM P 3 1 0 0
12:FRM B 3 1 0 0
13:FRM B 3 1 0 0
14:FRM P 3 1 0 0
SEQ 16828
SEQEXT 0
GOP 0
End of file:
SIZ 720 x 576
DISP 0,720,0,576
FPS 25000 / 1000
CODED 36363
PLAYBACK 36363
0.00% FILM
ORDER 1
Old 18th February 2025, 11:51   #235  |  Link
tebasuna51
tebasuna51's Avatar
How you know when it is interlaced from the dgi file?
I have some samples with same dgi look than the LeXXuz dgi (..., 0% FILM, ORDER 1), some with "Partially interlaced" after the 'Analyse' but also with full "Interlaced" and the 'Nvidia deinterlaced' is always no selectable.
I include manually ", deinterlace=1" in DGSource line and work fine always.
Old 18th February 2025, 12:06   #236  |  Link
LeXXuz
LeXXuz's Avatar
My guess is DG may have changed something in the syntax of the dgi files over the years, so MeGUI can't recognize it. That is if it only makes that option available when it finds a certain flag inside the file. Like I said, that option is broken for a very long time in MeGUI.
Anyhow, I think this wouldn't be a good approach at all. Index files could be flagged wrongly as progressive and still have the need for deinterlacing. I think the deinterlace option should be available at any time.
Old 18th February 2025, 12:15   #237  |  Link
tebasuna51
tebasuna51's Avatar
...Index files could be flagged wrongly as progressive and still have the need for deinterlacing. I think the deinterlace option should be available at any time.
Also some flagged like interlaced (MBAFF) with 0 blocks interlaced than don't need deinterlace at all.
Old 18th February 2025, 12:21   #238  |  Link
stimco
stop the fud.
you think that by being rude you will prove something.
There is a problem, but you don't give a fuck.
Understood.
success.
Old 18th February 2025, 14:34   #239  |  Link
Kurt.noise
Yes, I think it's a good idea. Will do that.
Understood.
success.
No but I cannot reproduce your issue with the same input. So, what should I do then ? did you try what I suggested previously (replace the content with the other) ?
Old 23rd February 2025, 08:29   #240  |  Link
Maxxr
only happened with the new version, any solution, look image below:
Maxxr is offline   Reply With Quote
