Old 10th September 2020, 00:46   #9081  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by Danette View Post
As far as I can tell, FDK-AAC has no executable in the downloaded files,
Of course, can't be downloaded by licenses.
You need compile it yourself.
so that’s out and Nero wants $40 …out again.
$40 ? You need NeroAacEnc.exe free from https://www.videohelp.com/software/Nero-AAC-Codec at ...megui\tools\eac3to folder
I tried changing it to Qaac, but it did not work (still 6 channels).
Work for me with qaac.exe and QTfiles folder from https://sites.google.com/site/qaacpage/
Old 10th September 2020, 01:23   #9082  |  Link
Danette
Thanks. I do have that old Nero encoder installed (didn't realize that's the most recent), but it didn't work with that old version, anyway.
I'm sure I could figure out how to compile, but my level of interest isn't high enough and I suspect it won't help anyway based upon the qaac failure. I did try several attempts with the qaac that's installed, but repeatedly failed.
I ended up just demuxing, rendering the audio with Audacity and encoded the video files with One-click. Everything is fine now, after muxing.
Danette is offline   Reply With Quote
Old 10th September 2020, 10:21   #9083  |  Link
tebasuna51
tebasuna51's Avatar
With NeroAacEnc.exe in ...megui\tools\eac3to folder you always can use MeGUI->Tools->HD Streams Extractor to downmix and recode to AAC like the image.
Include in +Options the parameter -downStereo (or downDpl) and optionally -normalize
Old 10th September 2020, 15:26   #9084  |  Link
hello_hello
As far as I can tell, FDK-AAC has no executable in the downloaded files, so that’s out and Nero wants $40 …out again. I tried changing it to Qaac, but it did not work (still 6 channels).
Try here:
https://forum.doom9.org/showthread.p...58#post1892458
Old 11th September 2020, 07:11   #9085  |  Link
LigH
LigH's Avatar
Downmix with a Dolby ProLogic matrix has the advantage that an A/V receiver may partially reproduce some surround impression if it supports it, but even if you only have stereo speakers it still doesn't get lost completely.
New German Gleitz board
Old 11th September 2020, 12:13   #9086  |  Link
tebasuna51
tebasuna51's Avatar
I check the One-Click feature and work fine for me with the 3 aac encoders.
Check if you have the proper files:
 Directorio de C:\Portable\megui\tools\eac3to
18/02/2010  11:54           868.352 neroAacEnc.exe
 Directorio de C:\Portable\megui\tools\fdkaac
09/12/2019  02:33           803.805 fdkaac.exe
 Directorio de C:\Portable\megui\tools\qaac
20/11/2018  15:30         2.006.528 qaac.exe
01/06/2019  17:26    <DIR>          QTfiles
 Directorio de C:\Portable\megui\tools\qaac\QTfiles
15/09/2015  14:25            62.736 ASL.dll
15/09/2015  14:25         7.238.416 CoreAudioToolbox.dll
15/09/2015  14:25         1.665.296 CoreFoundation.dll
15/09/2015  14:25        26.285.840 icudt55.dll
15/09/2015  14:25            75.024 libdispatch.dll
15/09/2015  14:25         1.681.680 libicuin.dll
15/09/2015  14:25         1.123.600 libicuuc.dll
11/06/2011  01:58           421.200 msvcp100.dll
11/06/2011  01:58           773.968 msvcr100.dll
15/09/2015  14:25           162.064 objc.dll
              10 archivos     39.489.824 bytes
and activated in the Options->External programs tab
Old 11th September 2020, 13:35   #9087  |  Link
LigH
LigH's Avatar
A tiny dummy replacement for the icudt55.dll does exist (see hydrogenaud.io).
Old 18th September 2020, 07:25   #9088  |  Link
agustin9
Hi, I keep getting this error
[Error] [18/09/2020 03:12:49] Standard error stream
-[Information] [18/09/2020 03:12:50] Invalid loglevel "level+error". Possible levels are numbers or:
-[Information] [18/09/2020 03:12:50] "quiet"
-[Information] [18/09/2020 03:12:50] "panic"
-[Information] [18/09/2020 03:12:50] "fatal"
-[Information] [18/09/2020 03:12:50] "error"
-[Information] [18/09/2020 03:12:50] "warning"
-[Information] [18/09/2020 03:12:50] "info"
-[Information] [18/09/2020 03:12:50] "verbose"
-[Information] [18/09/2020 03:12:50] "debug"
-[Information] [18/09/2020 03:12:50] "trace"
-[Error] [18/09/2020 03:12:50] x265 [error]: unable to open input file <->
Changing "level+error" to "error" and the full command works fine
EDIT:
Now works after updating ffmpeg. Why does Megui come with version 3.0.0 from 2016?
agustin9 is offline   Reply With Quote
Old 18th September 2020, 08:08   #9089  |  Link
LigH
LigH's Avatar
This version was possibly sufficient for the only specific reason it was needed for: Multiplexing MPEG-4 ASP from Xvid, IIRC...
Old 18th September 2020, 12:07   #9090  |  Link
tebasuna51
tebasuna51's Avatar
@agustin9
Use always 'development update server'
Old 21st December 2020, 06:03   #9091  |  Link
MrBonk
NVM seemed to have figured it out.
MrBonk is offline   Reply With Quote
Old 24th December 2020, 11:58   #9092  |  Link
Pringles
Pringles's Avatar
I'm having a performance issue with MeGui and a new computer build that is 7 times slower for AC3 encoding than my 10y old computer.
I'm drag n' dropping an mkv file with audio/video into the "Audio input" field, selected FFmpeg AC3 with these settings (nothing fancy) and that's about it.
With my new AMD 3900XT, B550, 64GB 3200MHz DDR4, SSD nvme, Win10 it takes about 8 minutes to process.
With my 10y old i7 2600K, P8P67, 16GB of RAM @ 1600MHz and 7200rpm HDD, Win7, it takes about 50 seconds:
I ran several performance benchmarks (Cinebench R20, Prime95, OCCT, memtest and userbenchmark) and it seems like everything is working like it should. Yet, it's 8 times slower with MeGui AC3 encoding.
Is the issue with MeGui or my computer? Can it be an Intel vs AMD thing?
Pringles is offline   Reply With Quote
Old 24th December 2020, 12:27   #9093  |  Link
jlw_4049
Is your core boosting during this time?
Sent from my SM-G986U1 using Tapatalk
jlw_4049 is offline   Reply With Quote
Old 24th December 2020, 12:47   #9094  |  Link
Pringles
Pringles's Avatar
It looks like it is if I'm not mistaken:
EDIT: tried the same encoding several times, it yields the same results -> 8 minutes
EDIT2: Tried your program and it's way faster so my understanding is that the issue comes from MeGui.
Old 24th December 2020, 14:01   #9095  |  Link
jlw_4049
EDIT3: but your program only encoded 59 minutes instead of the 2 hours for some reason
Is this only an issue with this file?
Im curious, could you potentially send me the file in question so I can mess with it later?
Old 24th December 2020, 14:27   #9096  |  Link
Pringles
Pringles's Avatar
Sorry I got mixed up with all the AC3 files I produced with MeGui and mixed up one MeGui aborted project with the result of your software which is working 100% fine and is way faster (about 30 seconds for this file).
Old 24th December 2020, 23:49   #9097  |  Link
jlw_4049
Glad mine is working good for you!
Old 20th January 2021, 22:31   #9098  |  Link
raymondjpg
Development Update Server is reporting FFMS uodate not available on server. Been a few days now.
--[Error] [21/01/2021 8:28:44 AM] Failed to download package FFMS: File cannot be found on the server.
--[Information] [21/01/2021 8:28:46 AM] Connected to server: http://megui.tmebi.de/test/
raymondjpg is offline   Reply With Quote
Old 21st January 2021, 06:53   #9099  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Update the update.xml file in update_cache subfolder as
        <ffms type="file" requiredbuild="2624" build="64">
            <filepath date="2021-01-17" version="20201123">ffms2-20201123-64.7z</filepath>
        </ffms>
Old 22nd January 2021, 05:31   #9100  |  Link
raymondjpg
        </ffms>
That worked thank you.
megui
