Old 29th January 2017, 16:40   #41  |  Link
sl1pkn07
Pajas Mentales...
nope
https://sl1pkn07.wtf/paste/view/b2ac319f
let me time to test with yasm, idk how manage it
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline   Reply With Quote
Old 29th January 2017, 16:56   #42  |  Link
feisty2
I'm Siri
feisty2's Avatar
that's weird...
please modify the source code manually and report back..
line 139:
replace
_mm256_store_ps(reinterpret_cast<float *>(&YMMField), _mm256_add_ps(reinterpret_cast<const __m256 &>(srcp[y][x]), YMMField));
with
_mm256_store_ps(reinterpret_cast<float *>(&YMMField), _mm256_add_ps(*reinterpret_cast<const __m256 *>(&srcp[y][x]), YMMField));
feisty2 is offline   Reply With Quote
Old 29th January 2017, 17:08   #43  |  Link
sl1pkn07
Pajas Mentales...
https://sl1pkn07.wtf/paste/view/883d7e05
Old 29th January 2017, 18:28   #44  |  Link
feisty2
I'm Siri
feisty2's Avatar
Originally Posted by sl1pkn07 View Post
I googled that error and apparently the source code was not what caused it.
there's something wrong with your compiling settings
That's the usual message for intrinsics that you haven't told the compiler the target supports.
see: http://stackoverflow.com/questions/3...-epi32-m128i-t
damn, now I get how nice that Visual Studio compiler is (from the user's point of view), I never had any sort of shit like this with Visual Studio...
Old 29th January 2017, 18:31   #45  |  Link
sl1pkn07
Pajas Mentales...
maybe is because my processor don't have AVX/FMA3 (Xeon x5650)
Old 29th January 2017, 18:36   #46  |  Link
feisty2
I'm Siri
feisty2's Avatar
maybe is because my processor dont have AVX/AVX2? (Xeon x5650)
you could try with "-march=haswell" and see if it does the trick
Old 29th January 2017, 18:37   #47  |  Link
sl1pkn07
Pajas Mentales...
my processor is westmere/ep (+/- nehalem)
with -msse4.1
https://sl1pkn07.wtf/paste/view/9516661b
EDIT: with -march=haswell build ok. but i think is incompatible with my processor
Old 29th January 2017, 18:45   #48  |  Link
feisty2
I'm Siri
feisty2's Avatar
with -msse4.1
doesn't matter, it will call the C++ functions automatically if the AVX functions fail.
Old 29th January 2017, 18:46   #49  |  Link
sl1pkn07
Pajas Mentales...
is not better use "if detect, compile it" instead of force compiling?
Old 29th January 2017, 18:53   #50  |  Link
feisty2
I'm Siri
feisty2's Avatar
unfortunately, I don't know how to "if detect, compile it"...
is the forcibly-compiled binary running ok on your computer since there's the C++ function backup?
Old 29th January 2017, 18:59   #51  |  Link
sl1pkn07
Pajas Mentales...
something like:
#ifdef VAPOURSYNTH_H
static void VS_CC VapourSynthPluginViInit(VSMap *in, VSMap *out, void **instanceData, VSNode *node, VSCore *core,
    const VSAPI *vsapi) {
    NLMVapoursynth *d = (NLMVapoursynth*) * instanceData;
    vsapi->setVideoInfo(d->vi, 1, node);
#endif //__VAPOURSYNTH_H__
(taken from knlmeans code)
but with CPU capabilities
EDIT: better example
EDIT: that is called conditionals? (sorry, im not coder, idk what is a real name of this)
Old 29th January 2017, 19:21   #52  |  Link
feisty2
I'm Siri
feisty2's Avatar
something like:
(taked from knlmeans code)
The past tense of "take" is "took", perfect tense "taken"
Anyways, it's called conditional compilation and I know how to do it theoretically but still can't do it, because it involves whole lot of compiler-specific macros that are not part of the C++ standard...
And since your compilation worked, I assume you figured out how to get yasm to work?
And does the compiled binary run correctly? (Checking if the "opt" parameter actually works)
Old 29th January 2017, 19:48   #53  |  Link
sl1pkn07
Pajas Mentales...
about yasm
something like this?
diff --git a/Source.cpp b/Source.cpp
index 5409d6e..3dbd174 100644
--- a/Source.cpp
+++ b/Source.cpp
@@ -1,12 +1,13 @@
-#include "VapourSynth.h"
-#include "VSHelper.h"
-#include "cpufeatures.hpp"
+#include <VapourSynth.h>
+#include <VSHelper.h>
 #include <cmath>
 #include <cstring>
 #include <algorithm>
 #include <immintrin.h>
 #include <malloc.h>
+extern "C++" int CPUFeatures();
 struct FixFadesData final {
 	const VSAPI *vsapi = nullptr;
 	VSNodeRef *node = nullptr;
(you can avoid the first change)
but i get https://sl1pkn07.wtf/paste/view/f32ca689
(takEN (XD) from https://github.com/vapoursynth/vapou...ore/x86utils.h (with this help http://wiki.osdev.org/C%2B%2B_to_ASM_linkage_in_GCC)
about of test, give me time
Old 29th January 2017, 19:54   #54  |  Link
feisty2
I'm Siri
feisty2's Avatar
Include "cpufeatures_gnu.hpp" and remove that "extern "C++" int CPUFeatures();" thing
Old 29th January 2017, 20:00   #55  |  Link
sl1pkn07
Pajas Mentales...
em, is the same as i tried before (only work with -march=haswell)(?)
or you mean convert the cpu.asm to object with yasm* and include it in the linker step?
yasm -f elf -m ${_m} -DARCH_X86_64=${_darch} -o cpu.o cpu.asm
can you share a clip/video sample? or how doing it with blankclip()
Old 29th January 2017, 23:31   #56  |  Link
JoeyMonco
Posts: n/a
But compiler-specific cpuid functions are part of standard? Since when?
Old 30th January 2017, 00:02   #57  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Now you see why asm is kinda your friend.
There's a pile of pitfalls here you missed. And some you found.
1. You compile the whole file with avx2/whatever instrction set you selected. That means avx2 instructions may be emitted for you plain C++ code too. Solve it by placing the avx2 code in a separate file and use different compiler settings.
2. You can't put sse and avx intrinsics in the same file either. For example subps can get turned into vsubps to reduce register copies. So then the sse path needs avx too...
3. Cpuid is horrible in intrinsics, that's why I use asm. Lrn2yasm. Or write code that requires gcc or clang where convenient intrinsics are available. Clang is even available as a simple dropin for visual studio nowadays.
Myrsloik is offline   Reply With Quote
Old 30th January 2017, 05:19   #58  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Why do conditional compilation at all when you can compile function for every instruction set and use CPU information to select the proper function in runtime?
...desu!
Mystery Keeper is offline   Reply With Quote
Old 30th January 2017, 05:40   #59  |  Link
feisty2
I'm Siri
feisty2's Avatar
yeah
blankclip is okay, long as it's not crashing.
no they are not, but I can google this individual function and learn to use it, I can't however google thousands of compiler-specific macros and memorize them all.
Old 30th January 2017, 05:59   #60  |  Link
JoeyMonco
Posts: n/a
yeah
Thousands? Uhh no. There is __GNUC__ and __clang__ and _MSC_VER_.
http://stackoverflow.com/questions/2...ang-with-macro
That was the first link in googling "how to detect gcc vs msvc"
