20th January 2021, 03:16 | #61 | Link | |
See My Avisynth Stuff Last edited by real.finder; 20th January 2021 at 03:18. |
20th January 2021, 03:18 | #62 | Link | |
Useful n00b
Still, I accept your apology. Thank you. And I will say it again: DGIndex 2.0.0.3 blows away the other forked indexers. Last edited by videoh; 20th January 2021 at 03:24. |
20th January 2021, 03:32 | #63 | Link | |
20th January 2021, 03:33 | #64 | Link | |
23rd January 2021, 02:27 | #65 | Link | |
I'll try do it tomorrow, no really I will. Time for Bed.
24th January 2021, 01:15 | #67 | Link |
It on its way, but still got some things to do, sorry for the delay.
24th January 2021, 06:29 | #68 | Link |
Danette,
See SendSpace below this post. I've updated both DGIndex_Batcher and MeGUI_AutoEncode_Batcher, have not used either for some time, MeGUI changed "Settings" dialog to "Options", which broke MeGUI batcher, fixed [should work on pre build 2896 also]. Made a few additions to the DGIndex AVS template. As So [just demo really]. Code:
# Standard DGIndex Infos VideoFileName = "__vid__" AudioFileName = "__aud__" AudioDelay = Value("__del__") # DGIndex_Batcher Infos # Stuff from DGIndex Information Window will be inserted into below '__stuff__' insertion markers. DGI_Field_Order = "__Field_Order__" DGI_Stream_Type = "__Stream_Type__" DGI_Profile = "__Profile__" DGI_Frame_Size = "__Frame_Size__" DGI_Display_Size= "__Display_Size__" DGI_Aspect_Ratio= "__Aspect_Ratio__" DGI_Frame_Rate = "__Frame_Rate__" DGI_Video_Type = "__Video_Type__" DGI_Sequence = "__Sequence__" DGI_Frame_Struct= "__Frame_Struct__" DGI_Frame_Type = "__Frame_Type__" DGI_Colorimetry = "__Colorimetry__" Mpeg2Source(VideoFileName) AudioExt = GetFileExtension(AudioFileName) Aud= (AudioExt==".ac3") ? NICAC3Source(AudioFileName,channels=2,DRC=0) \ : (AudioExt==".mpa"||AudioExt=="mp1"||AudioExt==".mp2"||AudioExt==".mp3") ? NicMPG123Source(AudioFileName,Normalize=False) \ : (AudioExt==".wav") ? RaWavSource(AudioFileName) \ : (AudioExt==".dts") ? NicDTSSource(AudioFileName) \ : 0 #Assert(!isInt(Aud),"NO AUDIO") (!isInt(Aud)) ? AudioDubEx(Aud).DelayAudio(AudioDelay).Trim(0,0) : NOP # Trim, chop/add audio to length (!isInt(Aud) && AudioRate() <> 44100) ? ResampleAudio(44100) : NOP S= \ "Field Order = " + DGI_Field_Order + "\n" + \ "Stream Type = " + DGI_Stream_Type + "\n" + \ "Profile = " + DGI_Profile + "\n" + \ "Frame Size = " + DGI_Frame_Size + "\n" + \ "Display Size = " + DGI_Display_Size + "\n" + \ "Aspect Ratio = " + DGI_Aspect_Ratio + "\n" + \ "Frame Rate = " + DGI_Frame_Rate + "\n" + \ "Video Type = " + DGI_Video_Type + "\n" + \ "Sequence = " + DGI_Sequence + "\n" + \ "Frame Struct = " + DGI_Frame_Struct + "\n" + \ "Colorimetry = " + DGI_Colorimetry SubTitle(S,lsp=0,font="Courier New") FAR = (DGI_Aspect_Ratio=="16:9 [3]") ? 16/9.0 : (DGI_Aspect_Ratio=="4:3 [2]") ? 4/3.0 : 1 Eval( (FAR!=1) ? "MeGUI_DarX=Round(FAR*1000) MeGUI_DarY=1000" : "" ) Return Last ########## Function GetFileExtension(string fn) { rfn=fn.RevStr i=rfn.FindStr(".") Return (i==0) ? "" : rfn.LeftStr(i).RevStr } Let me know how it goes and if probls, I'll not update the first post until I hear if its working ok, is tedious and time consuming to test everything, especially as I eg dont have Vista to re-check its probs, nor illegal field transition DVD's handy and the like. EDIT: zip contains both batchers, + source. Final test on full DVD, 5 VOB's, using the DGIndex template and passing though to MeGUI Batcher and did full encode also, although at Ultra Fast setting.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 24th January 2021 at 06:42. |
24th January 2021, 14:57 | #71 | Link |
Useful n00b
I don't see a signature. Where is it?
If for some reason signatures do not show for all users, it's better not to put your links there! I have no idea why signatures are not displayed for me. Google it, I'm not the only one reporting no signatures showing. Last edited by videoh; 24th January 2021 at 15:30. |
24th January 2021, 16:36 | #73 | Link |
Thank you gonca and vh,
Post was only intended for danette. EDIT: Seems to work OK on old DGIndex and new one.
24th January 2021, 22:58 | #75 | Link |
When DGIndex 2.0.0.3 is set to normal playback speed, DGIndex Batcher 1.20 processes files about 5% faster than when DGIndex 1.5.8 was set to maximum playback speed and DGIndex Batcher 1.18 was used. I ran 37 files (each file is a 25 minute TV episode), several times, and found this to hold.
However, when DGIndex 2.0.0.3 is set to maximum speed, DGIndex Batcher 1.20 freezes after 1-2 episodes, most often during processing of the first episode. I tried many times and rebooted my Win 7 computer, as well. |
24th January 2021, 23:07 | #76 | Link |
Did not even know it had a playback speed thingy.
Probably Batcher is waiting for something that has already happened, I'll take a look. Thanks. EDIT: So you are saying that it creates d2v file faster when on fast playback ? or does it hang when its doing the preparatory preview scan to get info from the Information window. EDIT: Do you have it doing the insert Infos whotsit, ie preview scan? [as in, insert into Template thingy] EDIT: Also, you're doing ordinary Mpegs, not joining vobs from DVD ? EDIT: It works OK without the fast Preview scan option set in DGIndex ? EDIT: What exact setting do you have in the GUI ? EDIT: Does the preview finish entirely, [ie real small clip, and fast machine] when it stalls ? Is it stalling on eg VIDEO_TS.VOB or VTS_01_0.IFO, ie on VERY SHORT menu ?
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 25th January 2021 at 02:09. |
25th January 2021, 02:59 | #77 | Link |
Yes, the playback speed is under “Options”. I’ve also run a number of different tests comparing the two versions.
As far as a comparison of DGIndex 2.0.0.3 to DGIndex 1.5.8 goes, I don’t see where there is a speed improvement in DGIndex viewing itself. When I run a preview, DGIndex 1.5.8 consistently runs 20% faster - repeat: the old version is faster. The “save project” function is 30% faster on DGIndex 1.5.8 vs. DGIndex 2.0.0.3. Is the speed improvement delivered at the d2v processing point in Avisynth as a result of an improved d2v file (which would be great)? When I run DGIndex 2.0.0.3 / DGIndex Batcher 1.20 on the 37 files, I get a 5% faster time than when using DGIndex 1.5.8 / DGIndex Batcher 1.18. How this can be, in view of the above paragraph, I have no idea. The time, and the time difference, is the same no matter what speed setting I use in both versions. However, when I use the “maximum” speed setting in DGIndex 2.0.0.3, that causes the crash in DGIndex Batcher 1.20. When I use the “maximum” speed setting in DGIndex 1.5.8, there is no crash in DGIndex Batcher 1.18. When I use the “normal” or “slow” speed settings in DGIndex 2.0.0.3, there is no crash in DGIndex Batcher 1.20. After thinking about this, since there seems to be little difference in the time it takes to process files with DGIndex Batcher 1.20 vs. DGIndex Batcher 1.18, I don’t see any reason to have either version of DGIndex’s playback speed set at “maximum.” In fact, I’m not clear on what benefit there is to moving up from DGIndex 1.5.8 to DGIndex 2.0.0.3 (unless there is a resultant d2v file processing uptick). If anyone can clarify, I’d be very interested. Answering the other questions you asked: - Join sets must start from 1, insert info and correct field order transition are checked (same as in DGIndex Batcher 1.18). - When it hangs, it does so just as the second scan of a file begins. Sometimes it gets through several files ok, before it hangs on the next file. - Did I answer the question on the exact GUI setting? - I’m processing MPEG files only. Last edited by Danette; 25th January 2021 at 03:03. |
25th January 2021, 04:49 | #78 | Link |
Make sure that you have all settings identical in both versions of DGIndex.
I've been making some Mpeg files [re-encoded from MP4], I'll test some tomorrow. Here, small mod to the template script, does not show Info subtitles if Batcher Insert Info is not turned on. Make this change to subtitle Line Code:
S= \ "Field Order = " + DGI_Field_Order + "\n" + \ "Stream Type = " + DGI_Stream_Type + "\n" + \ "Profile = " + DGI_Profile + "\n" + \ "Frame Size = " + DGI_Frame_Size + "\n" + \ "Display Size = " + DGI_Display_Size + "\n" + \ "Aspect Ratio = " + DGI_Aspect_Ratio + "\n" + \ "Frame Rate = " + DGI_Frame_Rate + "\n" + \ "Video Type = " + DGI_Video_Type + "\n" + \ "Sequence = " + DGI_Sequence + "\n" + \ "Frame Struct = " + DGI_Frame_Struct + "\n" + \ "Colorimetry = " + DGI_Colorimetry (DGI_Field_Order != "__Field_Order__") ? SubTitle(S,lsp=0,font="Courier New") : NOP # Dont Show Subs if Infos not inserted
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 25th January 2021 at 04:53. |
25th January 2021, 15:12 | #80 | Link |
D,
Find DGIndex_Batcher_DEBUG.7z on SendSpace, Debug Version, produces a Log file in same directory as exe. Can you run it, and when freeze, press "SHIFT/CTRL/ALT/PAUSE, to exit batcher. PAUSE on one of my keyboards requires pressing of a BLUE Fn key [so on that keyboard is 5 keys]. [PAUSE on its own pauses the batcher, and shows "Batcher Paused" type floating ToolTip, and again Un-Pauses it.] Post the log somewhere please. EDIT: Its almost certainly not "Frozen", its waiting for something to happen, I need to know what its waiting for.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 25th January 2021 at 15:25. |
batcher, dgindex |
