Old 25th August 2008, 20:20   #1  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Green frame on second frame of d2v?
Hey, neuron2, I just noticed this recently.
I am using the version of DGindex that ships with MeGUI's autoupdate (1.5.2)
When I load the m2v file from this thread:
http://forum.doom9.org/showthread.ph...10#post1174310
And load a simple script like this:
DGDecode_mpeg2source("C:\Documents and Settings\****\Desktop\VTS_01_1.demuxed.d2v",info=3)
If I load that script into virtual dub and step through the first couple frames, I get a green frame with a black dot in the right hand corner. Can you replicate this?
The rest of the clip is fine, but the 2nd frame is just...green.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 25th August 2008, 22:07   #2  |  Link
HymnToLife
Ubuntu French Roast
HymnToLife's Avatar
The M2V seems corrupted, DGIndex throws me a warning near the end of the process (and I have the green franme too).
Copy Protection:  A clever method of preventing incompetent pirates from
		   stealing software and legitimate customers from using it.
From http://www.gnu.org/fun/jokes/software.terms.html
HymnToLife is offline   Reply With Quote
Old 25th August 2008, 22:12   #3  |  Link
Adub
Adub's Avatar
Yes, I get that to. However, is that what is causing the green frame? I wish I knew where the field order transition took place.
Site:Adubvideo
Old 27th August 2008, 22:15   #4  |  Link
It's a bad stream. What's to explain?
When you correct the field order transition it shows you the location.
Old 27th August 2008, 22:20   #5  |  Link
Adub
Adub's Avatar
Ah, okay. I thought that was the case, it's just that I had seen this somewhere else recently, but that was a corrupted stream as well.
But is this okay? Chances are that he created that stream using the cutting mechanism of DGindex and demux. Shouldn't this produce a valid file? Or am I wrong?
Site:Adubvideo
Old 27th August 2008, 22:23   #6  |  Link
Chances are?!
If you can produce a problem doing it, please make a thread about it. You're right, cutting with DGIndex should not produce a stream like that.
Don't get me wrong, I really appreciate your trouble reports and the useful feedback you've given me in the past!
Old 27th August 2008, 22:26   #7  |  Link
Adub
Adub's Avatar
Okay, I will try and make some tests of my own. I haven't seen any problems except for other peoples files, so it could be just their fault.
Edit:
Okay, I can confirm the green frame bug. At least, for what I understand it to be.
To reproduce, take a vob. Any will do, I used the same vob available in my "Really messed up Anime source. CHALLENGE!!" thread.
Use the selectors to create a region in the middle somewhere, doesn't matter.
Save and demux. Now, the d2v created here works fine. So delete this.
Load the newly created example.demuxed.m2v into dgindex and save a new d2v.
Load using just this:
DGDecode_Mpeg2source("example.demuxed.d2v")
Drop the script into Vdub, and you should encounter a green frame on one of the first couple frames.
Site:Adubvideo
Old 27th October 2008, 20:58   #8  |  Link
Adub
Adub's Avatar
Okay, i just encountered this again today. neuron2, can you confirm?
Site:Adubvideo
Old 27th October 2008, 21:04   #9  |  Link
I just ran into it myself today. I'll try to figure out what's happening this evening.
My workaround: freezeframe(1,1,0)
Old 27th October 2008, 21:07   #10  |  Link
Adub
Adub's Avatar
Great! I am glad that it at least has been confirmed.
Site:Adubvideo
Old 27th October 2008, 22:07   #11  |  Link
I never doubted you.
I had a copy of the source laying around at work, so I had a look. I found and fixed the problem and will release the fix tonight. I want to add a few other things as well as long as I'm making a release.
The problem was that I start processing the file once to count the number of leading B frames and then again to start the main indexing. But I started demuxing at the start of the first processing, so I ended up demuxing an extra partial copy of the first GOP. Now I start the demuxing before the main indexing pass begins.
Thank you for pointing this out.
Old 27th October 2008, 22:41   #12  |  Link
Adub
Adub's Avatar
Good to know that you were able to pinpoint the bug so fast! I look forward to the next version with eagerness then!
Site:Adubvideo
Old 28th October 2008, 01:59   #13  |  Link
Version 1.5.3
See here:
http://forum.doom9.org/showthread.ph...67#post1207367
Old 29th October 2008, 01:41   #14  |  Link
Adub
Adub's Avatar
Great, thank you very much. I am updating as we speak.
Site:Adubvideo
1.5.2, dgindex, green frame
