Old 16th January 2011, 14:02   #1  |  Link
Wilbert
SACD ripping
Apparently it is possible to rip your SACD using a PS3:
http://www.hydrogenaudio.org/forums/...howtopic=86151
I don't have a PS3 nor a SACD myself, so i can't try it. Any takers?
Old 16th January 2011, 16:06   #2  |  Link
Ghitulescu
Ghitulescu's Avatar
It should be possible, in theory, as the PS3 just emulates an SACD player, this means that RAW data reaches the cell proc and thus can be "deturned" to a file.
Old 16th January 2011, 16:51   #3  |  Link
Wilbert
Apparently it is possible in practice too.
Old 19th January 2011, 22:52   #4  |  Link
Jens S
Jens S's Avatar
There's more discussion about it here
Jens S is offline   Reply With Quote
Old 20th January 2011, 08:19   #5  |  Link
ChiDragon
ChiDragon's Avatar
The link you posted goes to this thread.
ChiDragon is offline   Reply With Quote
Old 20th January 2011, 10:32   #6  |  Link
Gser
ZOMG! A thread within a thread within a thread. *MIND EXPLODES*
Gser is offline   Reply With Quote
Old 20th January 2011, 11:16   #7  |  Link
Ghitulescu
Ghitulescu's Avatar
A recursive thread. That must be a world premiere.
Old 22nd January 2011, 22:23   #8  |  Link
lchiu7
I have a PS3 with SACD support so this was interesting. But Sony have made the process more complicated by removing the ability to boot up another OS on the PS3 which you need to do in order to get access to the drive data.
You can avoid this issue by not upgrading the firmware but that means you lose access to the PSN which my son would not like :-(. And the other hacks out there to get over it seem pretty complicated.
So possibly the answer is is to get an earlier model PS3 that has SACD support, never upgrade the firmware on it and use that for SACD ripping.
I have a decent SACD library so while it would be good to get the data onto the server, I just live with playing the content on the PS3 or my Oppo BD player. If I want to listen on a portable player, then it's easy enough to rip the red book layer since there is no real audible benefit from lossless or HD audio on a portable media player or in the car (well IMHO).
lchiu7 is offline   Reply With Quote
Old 23rd January 2011, 03:45   #9  |  Link
Jens S
Jens S's Avatar
Oops. Sorry about that. I meant to write:
More discussion about that here
I thought for a moment you meant I had made a circular reference but it was really a recursive one. Must have been a copy/paste mess-up. My apologies.
Old 23rd January 2011, 14:03   #10  |  Link
Wilbert
Some utilities: http://www.hydrogenaudio.org/forums/...dpost&p=672033 and http://www.hydrogenaudio.org/forums/...dpost&p=670042
That might change again since the PS3 is completely hacked.
Old 23rd January 2011, 23:24   #11  |  Link
lchiu7
Originally Posted by Wilbert View Post
I was aware of that. But for me anyway, the effort of going to all this hassle so I can rip a SACD just isn't worth the benefit. After all I can play SACD's on my PS3 and also on my Oppo BD player and if I want content on portable media, the red book layer is easily extracted.
Still it's an interesting possibility.
Old 24th January 2011, 02:38   #12  |  Link
vfalks
easier methods are actively in the works.
1. a method for ripping using the common computer DVD drive. For proof that this already works, see some extracted files here. The extracted DSD track files are jumbled with the 80-bit encryption though, but we're reverse-engineering the encryption to take care of that. Hopefully ready quite soon.
2. a native (and signed) PS3 app might also be written (which is possible now that the master key for PS3 has been discovered and leaked), which means that with any SACD PS3 model, all you'll have to do is download and install the 'PS3 SACD Ripper' app, pop the disc in and click "rip" . No complicated linux or hacked firmware or jailbreaking needed at all...
pretty good huh
v
vfalks is offline   Reply With Quote
Old 25th January 2011, 14:11   #13  |  Link
Ghitulescu
Ghitulescu's Avatar
What is the procedure to follow?
Born in the USB (not USA)
Old 25th January 2011, 14:59   #14  |  Link
Midzuki
Unavailable
Midzuki's Avatar
^ SACD-Explorer
Midzuki is offline   Reply With Quote
Old 25th January 2011, 16:49   #15  |  Link
vfalks
when it is fully functional (decryption included), it will be shared. no use until then since it only produces unusable audio tracks.
oh no, it's Midzuki ...good to see ya
Old 25th January 2011, 17:18   #16  |  Link
Ghitulescu
Ghitulescu's Avatar
Excellent, not that I have so many SACDs, but because it says again loud and clear: Studios, don't waste money in copy-preventing-protections, better treat us, the consumers, more fair.
Old 25th January 2011, 22:16   #17  |  Link
Midzuki
Unavailable
Midzuki's Avatar
A "non-functional" release would convince the impatient ones that those screenshots are not showing false information
Have we ever met ? Or corresponded ??
And oh, BTW, what is the E.T.A. for sacd-author and foo_input_sacd ???
Old 5th February 2011, 13:29   #18  |  Link
xkodi
all of those SACD-is-hacked statements look like just an outrageous speculation, because as you can read here:
http://www.computeraudiophile.com/co...-PS3-Linux-yes
that guy tries to convince us that:
>obtaining raw dumps of an SACD on a linux PS3
as simple as #dd if=/dev/sr0 of=sacd.dump
will create unencrypted image (dump) of the SACD layer, because only then his tool:
http://sacd-ripper.googlecode.com
can work, but come on are we supposed to be that stupid to believe such thing and are Sony that stupid to make it that way and just running in Linux PS3:
will magically decrypt all SACD protections like "Pit Signal Processing", etc.
sorry, but i don't believe it, i appreciate the effort and at least the tool here:
seems to be able to work with not-encrypted SACD images, but once again there is no such thing as not-encrypted SACD image in the real-life world and it's even more ridiculous to claim such thing can be obtained from heavily encrypted SACD disc with just using "dd" (i.e. raw read) in Linux PS3 and announce SACD-is-hacked.
xkodi is offline   Reply With Quote
Old 7th February 2011, 16:41   #19  |  Link
vfalks
thanks for your appreciation.
since I myself know this is happening (I'm updated with the details but don't think I should share until it's completed: what's the point anyway), I can just ignore sounds of doubts for now - I have no reason to prove what I know....yes i know he made it sound like it was complete when first announcing it....but that doesn't mean he's a fake, lol. it's being completed now
Old 7th February 2011, 21:49   #20  |  Link
lchiu7
Count me in as not a doubter but somebody very interested in how this pans out. While I might not rip my SACD's and put them on the server since I have both a PS3 and a Oppo SACD player so can play the content in either of my HT rooms, it's a very interesting exercise.
