Old 25th October 2015, 23:49   #3721  |  Link
burfadel
Originally Posted by Zachs View Post
This is strange. v1.22.0 was mainly about the playlist supporting URLs. When it crashes, do you get an error message?
No, just the standard crash error message that I was quick enough to capture
and then:
Old 25th October 2015, 23:53   #3722  |  Link
Zachs
Suptitle, MediaPlayer.NET
Originally Posted by burfadel View Post
Is it possible for you to compile a few different test MPDN extensions omitting some of the different commits between v1.21.4 and v1.22.0 to see which commit is causing the issue?
You can try grabbing the source code version from GitHub. You can get the incremental updates from https://github.com/zachsaw/MPDN_Exte....21.4...1.22.0
Can you try v1.22.0 (source version) and see if that fails as well? If it does, replace playlist*.* with the ones from v1.21.4.
Zachs is offline   Reply With Quote
Old 25th October 2015, 23:54   #3723  |  Link
Zachs
and then:
You should be able to get the error message from EventViewer.
Old 26th October 2015, 00:07   #3724  |  Link
Anima123
I got this from EvenViewer:
Faulting application name: MediaPlayerDotNet.exe, version: 2.45.0.3555, time stamp: 0x5627415f
Faulting module name: VideoFrameServicesNative.dll, version: 0.0.0.0, time stamp: 0x55c2b55f
Exception code: 0xc0000005
Fault offset: 0x0000000000004370
Faulting process id: 0x14f4
Faulting application start time: 0x01d10f7964c41c3c
Faulting application path: C:\Program Files\MPDN\MediaPlayerDotNet.exe
Faulting module path: C:\Program Files\MPDN\Native\x64\VideoFrameServicesNative.dll
Report Id: b063df52-7b6c-11e5-8272-f81654b0da87
Faulting package full name:
Faulting package-relative application ID:
EventData as following:
   2.45.0.3555
   5627415f
   0.0.0.0
   55c2b55f
   c0000005
   0000000000004370
   14f4
   01d10f7964c41c3c
Edit: And the .Net Runtime Error as following:
Application: MediaPlayerDotNet.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
Stack:
   at B.c.a(IntPtr, UInt32, UInt32, IntPtr, UInt32, IntPtr, UInt32, IntPtr, UInt32)
   at Mpdn.D3D9VideoRenderer.VideoRenderer.A(IntPtr)
   at Mpdn.D3D9VideoRenderer.VideoRenderer.A(Int64, IntPtr, System.Collections.Generic.IList`1<IntPtr>, System.Collections.Generic.IList`1<System.Drawing.Size>, System.Collections.Generic.IList`1<SharpDX.RectangleF>, Boolean)
   at B.K.c(B.I)
   at B.K.f(Boolean)
   at B.K.A(System.Action`1<Boolean>)
   at B.K.s()
   at MediaPlayerDotNet.MainForm.A(System.Drawing.Size)
   at MediaPlayerDotNet.MainForm.A(Boolean, Boolean, Boolean)
   at MediaPlayerDotNet.MainForm.OpenMedia(System.String, Boolean, Boolean, Boolean)
   at MediaPlayerDotNet.MainForm.C(System.Object, System.EventArgs)
   at System.Windows.Forms.ToolStripItem.RaiseEvent(System.Object, System.EventArgs)
   at System.Windows.Forms.ToolStripMenuItem.OnClick(System.EventArgs)
   at System.Windows.Forms.ToolStripItem.HandleClick(System.EventArgs)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(System.Windows.Forms.MouseEventArgs)
   at System.Windows.Forms.ToolStrip.OnMouseUp(System.Windows.Forms.MouseEventArgs)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(System.Windows.Forms.MouseEventArgs)
   at System.Windows.Forms.Control.WmMouseUp(System.Windows.Forms.Message ByRef, System.Windows.Forms.MouseButtons, Int32)
   at System.Windows.Forms.Control.WndProc(System.Windows.Forms.Message ByRef)
   at System.Windows.Forms.ToolStrip.WndProc(System.Windows.Forms.Message ByRef)
   at System.Windows.Forms.ToolStripDropDown.WndProc(System.Windows.Forms.Message ByRef)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr, Int32, IntPtr, IntPtr)
   at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG ByRef)
   at System.Windows.Forms.Application+ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr, Int32, Int32)
   at System.Windows.Forms.Application+ThreadContext.RunMessageLoopInner(Int32, System.Windows.Forms.ApplicationContext)
   at System.Windows.Forms.Application+ThreadContext.RunMessageLoop(Int32, System.Windows.Forms.ApplicationContext)
   at A.k.A(System.String[])
Anima123 is offline   Reply With Quote
Old 26th October 2015, 00:12   #3725  |  Link
Zachs
Thank you!
Does this occur when you have preload next file disabled?
EDIT: Reproduced the error. Only happens when you have reset window size when closing media enabled.
EDIT2: Can you guys confirm if disabling the option fixes the issue?
Old 26th October 2015, 00:38   #3726  |  Link
burfadel
Thank you!
Yes, works fine with the reset windows size when closing disabled! Strange that it only occurred with extensions v1.22.0 and not v1.21.4 (under the previous MPDN version)?
The event view log for me shows basically the same as anima123:
Fault bucket 120342797506, type 4
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: MediaPlayerDotNet.exe
P2: 2.45.0.3555
P3: 5627415f
P4: VideoFrameServicesNative.dll
P5: 0.0.0.0
P6: 55c2b55f
P7: c0000005
P8: 0000000000004370
P9:
P10:
Old 26th October 2015, 00:41   #3727  |  Link
Zachs
Excellent!
Fixed in next release.
Old 26th October 2015, 00:46   #3728  |  Link
burfadel
Excellent!
I also just found that enabling 'Reclock' under 'Audio Script' causes the same crash, the details are the same in the event viewer as the other crash.
Old 26th October 2015, 00:48   #3729  |  Link
Zachs
With or without reset window size?
Old 26th October 2015, 00:56   #3730  |  Link
Anima123
Without 'reset window size closing media', I got these error messages when trying to playback a video file:
TITLE: SharpDX Error
An unexpected error 'SharpDX.SharpDXException' has occurred.
ADDITIONAL INFORMATION:
HRESULT: [0x80004005], Module: [General], ApiCode: [E_FAIL/Unspecified error], Message: Unspecified error
 (SharpDX)
BUTTONS:
&Abort
And yes, I am using 'Reclock' together with Sanear Audio Renderer.
Edit: disable 'Reclock' does not make the error go away.
Edit2: reboot windows 8.1 seems to fix this error, you might want to ignore this post.
Old 26th October 2015, 01:05   #3731  |  Link
burfadel
Without reset window size. It causes the exact same error details in the same file as with the reset window size option, so I guess if you fixed that it might have also fixed this issue?
The other thing I noticed with disabling the reset window size option is that manually changing media files seems to be very snappy, smooth, and seamless now. It could just be psychological, but I am sure that changing between files seems to be improved.
EDIT:
It seems that selecting any option under Audio Script causes the same crash (same details), whether it is reclock, DynamicRangeCompressor, Script Chain, or Script Group. This crash even occurs when nothing is enabled under script chain or script group, simply selecting it will cause the crash. I suspect though that if the error is fixed with the reset window size that these other issues may also hopefully be fixed (seeing as the crash is in the same file with the same crash details).
Old 26th October 2015, 01:14   #3732  |  Link
Zachs
The same stack trace as well?
Old 26th October 2015, 01:29   #3733  |  Link
burfadel
Here are the crash results for each of the four audio render options:
Fault bucket , type 0
Cab Id: 0
Problem signature:
P2: 2.45.0.3555
P3: 5627415f
P5: 0.0.0.0
P6: 55c2b55f
P7: c0000005
P9:
P10:
I only pasted it once because all four crash reports are absolutely identical (well apart from the report ID further down, which makes sense since it's a different crash event).
and the associated .NET error (same for all of the crashes, include the reset window size option):
Stack:
   at B.K.c(B.I)
   at B.K.f(Boolean)
   at B.K.s()
   at MediaPlayerDotNet.MainForm.A(Double)
   at MediaPlayerDotNet.MainForm.A(Mpdn.IMedia, Boolean, Boolean, Boolean)
   at MediaPlayerDotNet.MainForm.OpenMedia(Mpdn.IMedia, Boolean, Boolean, Boolean)
   at Mpdn.Extensions.PlayerExtensions.Playlist.PlaylistForm.OpenMedia(Boolean)
   at Mpdn.Extensions.Framework.PlayerExtension`2[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].PlayerKeyDown(System.Object, Mpdn.PlayerControlEventArgs`1<System.Windows.Forms.KeyEventArgs>)
   at System.EventHandler`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].Invoke(System.Object, System.__Canon)
   at Mpdn.PlayerControl.OnKeyDown(System.Windows.Forms.KeyEventArgs ByRef)
   at MediaPlayerDotNet.MainForm.A(System.Object, System.Windows.Forms.KeyEventArgs)
   at System.Windows.Forms.KeyEventHandler.Invoke(System.Object, System.Windows.Forms.KeyEventArgs)
   at System.Windows.Forms.Control.OnKeyDown(System.Windows.Forms.KeyEventArgs)
   at System.Windows.Forms.Control.ProcessKeyEventArgs(System.Windows.Forms.Message ByRef)
   at System.Windows.Forms.Form.ProcessKeyPreview(System.Windows.Forms.Message ByRef)
   at System.Windows.Forms.Control.ProcessKeyMessage(System.Windows.Forms.Message ByRef)
   at System.Windows.Forms.Control.WmKeyChar(System.Windows.Forms.Message ByRef)
I notice the line Mpdn.D3D9VideoRenderer.VideoRenderer.A(IntPtr), even though I have the presentation API set as Direct3D 11. When I press Ctrl+J for the stats when the video's are playing it does say Direct3D 11. Is that right?
Old 26th October 2015, 01:41   #3734  |  Link
Zachs
Ah disable "Resize window to fit when opening media" too and see if it still crashes.
If it doesn't then it's the same issue that I've fixed.
And yes D3D9VideoRenderer is really just because MPDN started out as just a D3D9 renderer and when I added D3D 10 and 11, I just left it as it is.
Old 26th October 2015, 01:52   #3735  |  Link
burfadel
The 'reset window size when closing media' causing the crash regardless of any other setting, and 'resize window to fit when opening media' causes the crash when any of the options is selected under the audio renderer, but is fine if 'none' is selected.
So I guess the issue is fixed with the next build, so all good!
Old 26th October 2015, 11:53   #3736  |  Link
Zachs
Should be fixed now in v2.45.1.
Old 26th October 2015, 12:27   #3737  |  Link
burfadel
Yes it seems to be! That's including the audio render options etc as well.
Thanks
Old 26th October 2015, 17:13   #3738  |  Link
burfadel
There is a new issue, however it seems to be related to the previous issue. It only occurs when 'Reset window size when closing media' is selected as well as an Audio renderer option. When you change from windowed mode to exclusive mode, more often than not when going back to exclusive mode the picture will stop, but the audio will continue. You just need to move the progress slider and it seems to correct itself. Well, apart from the one time when I was testing it when the whole program froze, but the audio continued! I had to use the task manager to close it. Sorry, no event viewer information this time as the program didn't actually crash. Just a video playback freeze.
Only an issue with that option and any audio renderer option selected (I use the reclock option). If either are selected on their own there doesn't seem to be an issue.
Old 26th October 2015, 21:21   #3739  |  Link
djsolidsnake86
image quality is better thant using mpc hd with madvr?
djsolidsnake86 is offline   Reply With Quote
Old 26th October 2015, 23:18   #3740  |  Link
Dreamland
I think MPDN is the best player for quality video ! great!
Dreamland is offline   Reply With Quote
direct3d, mpdn, nnedi3, opencl, reclock
