Old 19th May 2024, 16:49   #4881  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Makes sense but there are a few problems.
Some people parse the info output so changing it would break things.
There's also no actual api function to obtain the set output indices so that needs to be added as well.
Create an issue and I'll probably do it in a bit.
Myrsloik is offline   Reply With Quote
Old 19th May 2024, 17:03   #4882  |  Link
Selur
Selur's Avatar
I do
will do, thanks!
Old 7th June 2024, 22:46   #4883  |  Link
NoX1911
NoX1911's Avatar
Originally Posted by Myrsloik View Post
Link is dead. Any alternative script collections?
NoX1911 is offline   Reply With Quote
Old 8th June 2024, 06:06   #4884  |  Link
Selur
Selur's Avatar
https://vsdb.top/ might be a good start (https://github.com/Selur/VapoursynthScriptsInHybrid has the scripts Hybrid uses)
Old 8th June 2024, 09:56   #4885  |  Link
Myrsloik
Myrsloik's Avatar
Fixed it so it points at vsdb.top, you can also simply use
vsrepo.py available
to get a fairly complete list.
Old 8th June 2024, 10:10   #4886  |  Link
NoX1911
NoX1911's Avatar
Ok, just thought there would be another collection of turnkey-ready vpy files. Its functions then.
Old 9th June 2024, 16:06   #4887  |  Link
amayra
Quality Checker
amayra's Avatar
out of curiosity i tried to find a way to play VPY script in android phone but i don't find any results
is that even possible ?
I love Doom9
amayra is offline   Reply With Quote
Old 10th June 2024, 07:49   #4888  |  Link
LigH
LigH's Avatar
VapourSynth is based on Python. Where Python runs, there is at least a chance.
I believe to remember that Selur's Hybrid works on several platforms (Windows and Linux at least) where OS independent operation is supported (Avisynth not so easily, but core and VapourSynth). Android may be a special Linux variant, yet it is distinct in several features, so porting Linux ready software may not be as trivial.
New German Gleitz board
Old 10th June 2024, 08:13   #4889  |  Link
Selur
Selur's Avatar
Can't really comment on Android, but especially on phones I see multiple problems:
a. what python version is installed (R68 only supports Python 3.8 and 3.12)
b. are all the libraries Vapoursynth uses are available on Android
c. are the plugins one wants to use be compiled for arm. (probably not)
d. does the mobile even have enough power to run this stuff.
=> I doubt running Vapoursynth (with some plugins) on ARM is feasible atm.
Old 10th June 2024, 08:19   #4890  |  Link
Myrsloik
Myrsloik's Avatar
To add to this:
a: Python 3.8 (possibly 3.6) or later is supported. It's only to keep down the number of configurations on windows I don't provide more.
b: Very few libraries are used so if you have python the answer is yes.
c: You always have to compile that for every platform. No worse than the average linux distro.
d: I talked to a guy a few years ago who made it work on ios. Don't think it was ever made public but you can definitely run simpler things. Keep in mind that modern phones are like super awesome gaming computers 10 years ago.
Old 20th June 2024, 18:12   #4891  |  Link
Selur
Selur's Avatar
I want to delete line 0-4 keep 5-9, delete 10-14, keep 15-19,...
(using tons of Crop and StackVertical calls seems like a bad idea)
Something like SeparateFields, but not splitting even and odd lines, but packages of 5 ?
(no problem if not, just playing with some ideas,..)
Old 20th June 2024, 18:32   #4892  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I think you could use a Python for loop for that to keep it quite simple.
Old 20th June 2024, 20:17   #4893  |  Link
Myrsloik
Myrsloik's Avatar
AddBorders to make the input a 2^n height
Call SeparateFields until every frame consists of only one field
StackVertical([SelectEvery(cycle=addborder_clip.height, offset=something), ...]) <= this bit you'll probably have to automatically generate somehow
Or jusr write a filter, that's so much easier.
speed, vaporware, vapoursynth
