Old 29th September 2012, 01:17   #241  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by kolak View Post
Vfw came so fast, but what about software, which does open files by extention? Even if it works with vfw it will fail as extension won't be avi. Making script seen by other apps as "fake" avi (or mov) would be great. This would make it 99% compatible with all apps.
Are 8bit+ color spaces/outputs coming? Again v210 would be great as this is most compatible 10bit format.
I should make a use of this donatation button
For the fake avi stuff you need another layer like that old vfapi stuff or avfs. I could try to quickly port avfs and make it vsfs if the current solution isn't good enough.
I looked at v210 but it's packing made me nauseous just to look at. I suppose I'll add it sooner or later but it's a shame it turned out to be the most popular. Microsoft defines very sane and clean planar formats officially too. What a shame... over 8 bit output will come. But it's a bit lower in priority since to my knowledge x264 is the only thing that truly benefits from it. Correct me if I'm wrong.
Myrsloik is offline   Reply With Quote
Old 29th September 2012, 01:24   #242  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by lansing View Post
stilll no luck, still crashed
import vapoursynth as vs
import sys
core = vs.Core(accept_lowercase=True)
# plugins
core.avs.LoadPlugin(r"C:\Program Files (x86)\AviSynth 2.5\plugins\DGDecode.dll")
# load source
src = core.avs.MPEG2Source(d2v=r"test.d2v")
last=src
Then I'm not sure why it fails. Try running the program from the command-line. Maybe you'll see a warning or error printed before it crashes. You can also try blankclip and see if that works.
Old 29th September 2012, 01:47   #243  |  Link
Reel.Deel
VS VFW works fine for me. Thanks Myrsloik.
I'm assuming it will be up to VDub to support drag and drop for vpy or am I wrong?
Old 29th September 2012, 01:50   #244  |  Link
Myrsloik
Myrsloik's Avatar
Correct. Vdub needs to be updated to know about the .vpy extension. Feel free to go and push for its inclusion in the next vdub version. Along with support for the sane high bitdepth planar formats.
Old 29th September 2012, 01:57   #245  |  Link
Reel.Deel
Will do.
Old 29th September 2012, 03:23   #246  |  Link
lansing
can you elaborate how to run it the command line way?
Old 29th September 2012, 07:21   #247  |  Link
Myrsloik
Myrsloik's Avatar
Start menu\open command prompt
Cd virtualdub path
Virtualdub
Done.
Another thing you should try first though is only having absolute paths in your script. The other thing is running your script in python and see if it works at all with the paths you have.
Old 29th September 2012, 08:18   #248  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Works fine so far thank you so much! Now I can do some real stuff with it!
But I have somewhat unrelated question.
Should I load ffms2 as std or avs plugin? Using latest ffms2 build it is loaded via std yet says it "doesn't have function FFVideoSource". I think I missed something. How should I call it then?
Old 29th September 2012, 08:40   #249  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
Should I load ffms2 as std or avs plugin? Using latest ffms2 build it is loaded via std yet says it "doesn't have function FFVideoSource". I think I missed something. How should I call it them?
http://forum.doom9.org/showpost.php?p=1590957&postcount=1650
my repositories
Chikuzen is offline   Reply With Quote
Old 29th September 2012, 08:46   #250  |  Link
active1
maybe someone should add the .vpy extension support in x264 too (is it possible to do it?)
EDIT: sorry, it works
EDIT: lol, no it's not working, sorry
that's what happend:
avs [info]: trying FFmpegSource2... indexing... failed
avs [info]: trying DSS2... not found
avs [info]: trying DirectShowSource... succeeded
avs [info]: 848x480p 0:0 @ 10000000/417013 fps (cfr)
the x264 loaded the test.vpy script through directshowsource
active1 is offline   Reply With Quote
Old 29th September 2012, 08:53   #251  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Yeah, definitely missed that. Thanks! It works now.
EDIT: one more question, it is not possible to open 10bit video now? It says something about vfw but I can't read it,anything that reads .vpy crashes too fast.
edit2: by the way 10bit useful not only for x264. me, and I believe not only me use it for more professional stuff. some things like 10bit dnxhd are pretty much standard for delivering intermediate files. thankfully after all we got nicely hacked ffms2 for avisynth with high bitdepth and different subsampling support ^__^
Old 29th September 2012, 13:08   #252  |  Link
kolak
vsfs would be great- avfs works very well as it presents script as "normal uncompressed avi", so every app is happy with it. It also works stable.
v210 is definitely the most universal format for 10bit and I think they made it packed to save bits.
Is it possible to have some 10bit working color space in one format (easy to implement and to work with) and have v210 implemented in vsfs only as final output? If this is easier than it would also work.
v210 spec can be found here:
https://developer.apple.com/quicktim...h019.html#v210
Old 29th September 2012, 13:31   #253  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
It is the most "universal" format for 10bit in MOV (and thus possibly with the pro tools). Please leave that stuff out of Vapoursynth and pipe its 10bit output to ffmpeg/avconv or something, they can convert the bits into the correct thing, and they can mux it into mov correctly. Myrsloik knows of the format and it's not something he most probably will support any time soon, because it is a major PITA to do so.
Also the v210 "support" in VirtualDub is as far as I know something that doesn't work anywhere else, so that can, if you pardon my french, go suck itself. v210 is only "standard" in mov. I would much rather see the support for the saner, proper 10bit formats be added in VDub instead of a random format not meant for in-program use, but for creating an actual mov file for transport for loading it into something else. And for that, we have ffmpeg/avconv to do it for you. You just have to feed them the 10bit YCbCr.
Thank you.
[I'm human, no debug]
JEEB is offline   Reply With Quote
Old 29th September 2012, 14:16   #254  |  Link
active1
will vapoursynth support outputing more than 8 bits? and will vdub be able to preview the +8bit.vpy script?
Old 29th September 2012, 14:30   #255  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
Vapoursynth has been able to output >8bit stuff for quite a while already. That is why the Vapoursynth ffms2 plugin can output >8bit stuff as well, which was never officially implemented on the Avisynth side as it was a hack.
No idea what colorspaces can be used in the VFW interface. Also I have no idea what colorspaces VDub can take in. IIRC it doesn't support the MS-specified 10bit+ YCbCr formats at least. It is an open source application though, so things can be implemented.
Old 29th September 2012, 14:31   #256  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Just want to rephrase this a bit
Lets say I want to open any 10 (or more) bit file supported by ffmpeg using ffms2 in vapoursynth and then preview it in something. How should I do this correctly?
From what I understand VDub needs to add support for planar colorspaces, then how do I convert colorspace to somthing VDub already understands? 8bit YV12 for example
edit: this? Bicubic(clip=clip, format=vs.YUV420P8) why bicubic and not something else? how it is related to colorspace conversion if no subsampling involved? And it seems it crashes anyway.
Old 29th September 2012, 14:52   #257  |  Link
active1
i meant outputing more than 8bit with using the vfw module
i hope that vapoursynth will be able to do it
Old 29th September 2012, 15:03   #258  |  Link
Reel.Deel
then how do I convert colorspace to somthing VDub already understands? 8bit YV12 for example.
This allows you to preview 10-bit video as 8-bit in VDub.
# 10-bit source
src = core.ffms2.source(source=r"C:\10 bit.mkv")
# Change bit depth to 8-bit
src = core.resize.Bicubic(clip=src, format=vs.YUV420P8)
# Ouput for VDub
last = src
Also, you can change Bicubic to any of the other resize listed here.
@ Myrsloik
Is there any dithering going on when converting YUVxxxP16 to lower bit depths?
Old 29th September 2012, 15:11   #259  |  Link
hajj_3
python 3.3 final is out now: http://python.org/download/
Maybe you could release a new build using Visual Studio.NET 2010 now I wonder if windows 8 has the C++ 2010 pre-installed?
Old 29th September 2012, 15:15   #260  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
@ Myrsloik
Yes, depends on the swscale linked into vapoursynth, after the dither package gets implemented we should get various things for that.
Of course for preview you could just convert it to RGB straight away (and after the dither package gets ported you'd have more ways to do that, too)
speed, vaporware, vapoursynth
