Old 1st July 2021, 12:33   #61661  |  Link
ryrynz
ryrynz's Avatar
Based on a review I saw it looks like Sony is the king of upscaling at this resolution.. I do wish there was a smooth motion frame blending option in hardware what with 120Hz now filtering down the chain.. C1/CX owners how does your motion options at lowest/closest to 100% frame blending look compared to madVR's Smooth Motion? Are we almost there near MadVR quality yet?
Old 1st July 2021, 12:38   #61662  |  Link
i have a sony Tv here and it is really bilinear with 120 hz this is not a joke well maybe from sony.
the 60 HZ 1080->2160 is decent but far from a really good scaler.
Old 1st July 2021, 17:15   #61663  |  Link
mclingo
i'm with SamuriHL, i think we'll see V1.0 at some point, I think MADSHI would understand the massive disappointment to us all for all our support if we dont see this, most of us are also happy to pay for it should that be the only option.
We'll just have to see what happens and continue to enjoy what we have, and what we've had for years completely free of charge
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - http://madshi.net/madVRhdrMeasure140.zip
Old 1st July 2021, 17:34   #61664  |  Link
oldpainlesskodi
^ What he said.
Sapphire RX 5700 XT (21.6.1) Ryzen 7 3700x, PRIME X570-Pro, Win 10 x64 (20H2), Silverstone LC13B-E, Kodi Dsplayer 17.6 X64, LG OLED55BX6LB, Denon AVR-X3300W, Mission M35i speakers.
oldpainlesskodi is offline   Reply With Quote
Old 2nd July 2021, 01:23   #61665  |  Link
SoySauceWDF
I've got a weird issue using madvr that's been happening for a while. If I pause or sometimes randomly during playback, the render queue drops to 3-4/8 and I start getting dropped frames. It fills up if I backup a little bit and start playing again. I've messed with queue sizes, vsync, present frames in advance, etc, almost every setting I could think of.
Running windowed with D3D11, output in sdr bt.2020 and 10 bit, display set to 12 bit. Happened on both my 2080 ti and 3090, latest drivers. Wondering if its an issue with nvidia outputting 12 bit?
SoySauceWDF is offline   Reply With Quote
Old 2nd July 2021, 02:58   #61666  |  Link
ryrynz
ryrynz's Avatar
Well the easiest way to test is by simply outputting to 8-Bit instead yeah?
No there's no problems with outputting 12-bit with your GPU, if there was you would've seen a post about it.
If it's randomly dropping the queue down it's either an app that's interfering with it or it's your config in which case, reset, revert, restore etc.
Old 2nd July 2021, 03:12   #61667  |  Link
SoySauceWDF
It seems to stop doing in when its set to D3D9 but I'd like to run D3D11 so I can output 12 bit. Does it using DXVA2 copyback as well. I've done multiple windows clean installs and used the default settings and have tested multiple settings. Don't know what app could be interfering, any common ones? Kind of a head scratcher
Old 2nd July 2021, 08:19   #61668  |  Link
ryrynz
ryrynz's Avatar
Would recommend booting without anything programs loading in startup and also changing you power profiles with your graphics card and PC just to test that the system isn't moving into lower power states for whatever reason. Short of that I really don't know, but I would be logging everything I can in the system to figure out what's triggering it. Might be a tough one to nail down.
Old 2nd July 2021, 14:00   #61669  |  Link
tp4tissue
tp4tissue's Avatar
We're all very confident Madvr as a paid software pack will have a wide market.
As a $2000-3000 device, It's a tough sell.
Upscaling just isn't that important.
Tonemapping, we're getting brighter and better devices every year that do their own tonemapping, this solution is better overall as the devices are aware of the impact of its own ABL. Once we hit a steady 1000 nit on devices, which is already possible just too expensive on LMCL, tonemapping itself becomes niche. Those 4000nit dolby pulsars arn't getting that much use, The panasonic 1000nit lmcl builds are much more widely used grading monitors.
3DLut, I love madvr's implementation to death, but high end TVs support this.
Where is the niche for Envy. The Sony/Epson, all of their expensive projector units will also improve on internal tonemapping year over year.
_Projectors_ in general going the way of the dodo.
_Oleds_ getting BIGGER and CHEAPER all the time.
_LCDs_ Already hitting 1500nits
_LMCL_ Most promising short term solution @ ~500nits
_Samsung QNED_ Self Emmisive. Spanks Oled in sustained output, <in active development, allegedly screen burn proof.>
Madvr's PRIMARY societal role
has been to leverage the average ghetto boxes of the PC-masses and turning them into very capable, high-Quality video players.
Going the ENVY route, madshi is taking a path away from his BIGGEST FAN BASE, the people MOST LIKELY and WILLING to PAY HIM MONEY.
Compared to Madvr's existing success reaching the eyes and imagination of world wide active users, Envy is going from an ocean to a drop.
Then there's the point of sale dilemmas. It usually takes a salesmen to sell a $3000 box. These guys take a cut, you have consumer education, friction upon friction.
Meanwhile, we the madvr Fanbase, madshi doesn't have to prove anything to us, we know this stuff is legit, Take my money, we want m0ar madvr.
I even setup madvr for my grandma. That's how much koolaid I am downing. .
Ghetto | 2500k 5Ghz
Old 2nd July 2021, 14:17   #61670  |  Link
tp4tissue
tp4tissue's Avatar
@ Soysaucewdf,
You have to TEST 10 bit VISUALLY, don't just turn it on and assume it works, it may not work, it may actually be worse (Some LG oleds).
https://forum.doom9.org/showthread.p...29#post1928929
Ghetto | 2500k 5Ghz
Old 2nd July 2021, 16:17   #61671  |  Link
SoySauceWDF
I've tested it on my Epson 5050UB and 10/12 bit works fine, at least to my eyes. I watched a movie in Fullscreen Exclusive last night and it didn't have any render queue issues, so might be a window overlay problem with windows/nvidia/something else. Just had 2 presentation glitches at the very start but was smooth from then on so might just stick with FSE
Old 2nd July 2021, 17:06   #61672  |  Link
ashlar42
Do I assume correctly that to avoid "glitches" it's not recommended to set 1 frame to be rendered in advance and not more? Is there anything else to do? I've pretty much solved the custom refresh thing (at least with madVR, in Kodi for some reasons it's avoiding the custom refresh rates in HDR, while accepting them in SDR) and I don't want no stinking glitches in my media viewing! :-D
Old 2nd July 2021, 20:15   #61673  |  Link
FSE can lower presentation issues but this is usually issue with a different program interfering with madVR
Old 3rd July 2021, 05:24   #61674  |  Link
galneon
Getting a C1 tomorrow so it looks like I need to move to the timed betas... Is the beta closed or am I missing a really obvious link?
galneon is offline   Reply With Quote
Old 3rd July 2021, 07:15   #61675  |  Link
VBB
VBB's Avatar
http://madshi.net/madVRhdrMeasure134.zip
Henry | LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 | NVIDIA SHIELD TV Pro 2019 | Plex
VBB is offline   Reply With Quote
Old 3rd July 2021, 07:40   #61676  |  Link
galneon
Thank you.
Old 3rd July 2021, 16:53   #61677  |  Link
ashlar42
Such as? This is a dedicated HTPC machine, so I don't think there's a lot going on "behind the scenes". If you have anything in mind, please share it, as it could help me looking in the right direction.
Thanks in advance!
Old 3rd July 2021, 18:00   #61678  |  Link
i don't know the name but programs to lower blue light output.
Old 3rd July 2021, 19:45   #61679  |  Link
el Filou
el Filou's Avatar
In Windows Task Manager, Details tab, add the GPU column and sort by its usage and watch it during playback (you can move the colum to the leftmost position and put TM in the lower right corner) to see if another process uses the GPU from time to time.
Maybe also use something like GPU-Z to check if there's not something wrong with clocks/GPU utilization.
HTPC: Windows 10 20H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 466.27
Old 4th July 2021, 00:18   #61680  |  Link
ashlar42
f.lux I don't have installed on the HTPC. But I'll check for the similar function in Windows 10... also good suggestion on checking task manager. I'll try that as well.
Cinema Screen in conjunction with TruMotion Cinematic Movement is satisfactory in my limited experience (I've had the C1 for just a couple of weeks).
LG 77C1 - Windows 10 Pro 21H1 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Reclock) - GTX 3070 - Ryzen 3 1200 - 16GB RAM
