29th May 2021, 13:34 | #61501 | Link |
You may need to select the OTHER display hardware for your display device. where it says GTX xxxxxx note that the gpu is listed xxxx for each connected xxxxx
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 29th May 2021 at 13:37. |
29th May 2021, 13:58 | #61502 | Link |
I don't think which GPU is used for decoding matters for black bar detection, as long as madVR gets the image back on the CPU (i.e. any decoding mode and config except 'native' hardware decode).
Sometimes with some madVR options it's difficult to find out why they don't work when they should...
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
29th May 2021, 20:45 | #61504 | Link |
i rolled back to 1909, no issues with MADVR but youtube was a mess, audio dropouts all over the place even with latest and AMD driver, no issues with 1909 and for once rolling back was seemless, took 5 mins.
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions |
30th May 2021, 01:37 | #61505 | Link |
Today I went to watch a movie and I noticed that hdr wasn’t enabled. I checked the osd and I noticed these that I’ve never seen and have no idea what they are or how they got there. First is the panavision one and second is the hlg thing. I have no idea how to fix this and I really want to watch a movie
30th May 2021, 02:31 | #61506 | Link |
HLG is Hybrid Log Gamma which is a combined std SDR curve for the first part and an aggressive Log curve for the highlights that makes a HLG file playable on both a SDR Display (with slightly washed out highlights) and a HLG compatible HDR TV. HLG is being pushed by both the BBC and NHK as a broadcast format that will work OK on both SDR and HDR(HLG) compatible sets. Think of it as a compromise of SDR and HDR together. Unless something recently changed, madVR does not support tone mapping HLG, and if your TV does not support HLG then it will display as SDR.
30th May 2021, 02:33 | #61507 | Link | |
Ok but why is it all of the sudden doing this ? This have never shown up like this before. My movies have always played in hdr not this hlg |
30th May 2021, 04:04 | #61508 | Link |
It is because of the metadata attached to that file, it says it is BT.2020 and HLG.
madVR options explained |
30th May 2021, 10:41 | #61511 | Link |
This might also happen if you use an old version of LAV Filters (pre-0.74) and madVR has dropped its previously accepted values for PQ HDR in recent development versions.
Some time ago, madVR introduced a custom value for PQ HDR signaling, but that value then collided with the official value for HLG when it was introduced, so you need to make sure all parts are up to date.
30th May 2021, 10:43 | #61512 | Link |
Hi, a quick question.
I'm using an old SDR monitor, so when playing HDR BT.2020 content the color is off. Based on some tutorials I learned from here, I enabled the option calibration and set the option "the display is calibrated to BT.709": Now MadVR will convert HDR content to SDR so they look good on my screen. However, I found out later if I enable this option, BT.601 (smpte170m) content will not playback correctly: the color will be converted too so the red colors no longer have the correct RGB values. Is there anyway to have both work? I tried MPV and they all work fine (BT.2020 got converted to SDR, BT.601/BT.709 content plays as-is.) Thanks. Edit: never mind. It looks like the video I got just has the wrong color primaries tagged: it's actually BT709 but tagged as BT601. MPV "works" because it ignores color primaries. Last edited by fireattack; 30th May 2021 at 12:16. Reason: Fix |
30th May 2021, 12:57 | #61514 | Link | |
The file isn’t tho, if I watched the same movie last week and it didn’t do how would it all of the sudden change ? |
30th May 2021, 17:20 | #61516 | Link | |
It seems that MadVR's custom modes menu has permanently damaged my monitor. The program really should include some kind of disclaimer that this can happen. |
30th May 2021, 19:14 | #61517 | Link | |
Beside that it could be coincidence of another problem. When e.g. electrolytic capacitors of the monitor are older, they can loose capacity and similar effects like showing black picture, going on and off can occur. Normally, if you exceed the capabilities of your monitor´s input range, the monitor shows an error message by OSD and you have a permanent black 'image' then until you change the timings to the allowed range. When sending a 'wrong' signal, a monitor simply doesn´t show an image or a corrupted one or an error message, but nothing gets defective on the hardware side. It could be coincidence or maybe something in your monitor was already a little bit out of spec and there was only missing a small deviation to produce a permanent damage. But such a case is VERY unlikely. |
30th May 2021, 20:14 | #61519 | Link | |
This is extremely rare.
Ghetto | 2500k 5Ghz |
30th May 2021, 20:18 | #61520 | Link | |
In this case, by telling madvr that your monitor is 2.2g and has 709 primaries isn't exactly right, because your monitor almost certainly does not fit those descriptions by default without real calibration. If the image looks Better to you , it's likely just the effect of lowering gamma which makes everything more saturated. An OLD monitor usually means its gamma tracking is really out of wack. What monitor are you using.
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 30th May 2021 at 20:23. |
