Old 15th April 2021, 14:47   #61421  |  Link
the FSE inmpc-hc is not the same FSE as in madVR just use that instead the cursor should show.
but that would only be the case with a really old mpc-hc version so the cursor should be there.
Old 17th April 2021, 09:09   #61422  |  Link
Pastol
Hi guys. do you know if madvr passthrough hdr works in beta insider program for windows? And which latest drivers are able to passthrough HDR ?
Sory for bad english. I hope it is understandable
Pastol is offline   Reply With Quote
Old 17th April 2021, 09:30   #61423  |  Link
should work with all latest driver.
Old 18th April 2021, 09:02   #61424  |  Link
GCRaistlin
GCRaistlin's Avatar
The fact is that a time ago, "with the really old MPC-HC versions", the cursor was visible. But with new ones it is not. Is it expected?
Magically yours
Raistlin
GCRaistlin is offline   Reply With Quote
Old 18th April 2021, 18:44   #61425  |  Link
i only remember a missing cursor in old MPC-HC FSE but madVR FSE should totally superseed it and a cursor should be present.
Old 19th April 2021, 09:42   #61426  |  Link
GCRaistlin
GCRaistlin's Avatar
MPC-HC x64 1.9.10 (default settings, only video renderer is changed to madVR) + madVR 0.92.17 (default settings except [x] enable automatic fullscreen exclusive mode) = no cursor in fullscreen mode.
Magically yours
Raistlin
Old 19th April 2021, 10:11   #61427  |  Link
shouldn't be the case.
could be a custom cursor madVR can't handle up to buggy GPU driver or windows issues.
are you using intel by any chance?
Old 19th April 2021, 20:31   #61428  |  Link
GCRaistlin
GCRaistlin's Avatar
No, AMD HD7850 + Crimson 17.7.1 (the latest one for it).
Magically yours
Raistlin
Old 21st April 2021, 18:02   #61429  |  Link
el Filou
el Filou's Avatar
So they're still updating the driver for Windows 7 and Windows 10, but not for Windows 8.x ? Bummer.
HTPC: Windows 10 20H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 466.27
Old 22nd April 2021, 23:04   #61430  |  Link
ttnuagmada
maybe someone here can help. Im using MPC-BE/Lav/MadVR/XYsubfilter
I've tried different versions of everything but MadVR, but, for the LIFE of me, I cannot keep it from displaying whatever the default subtitles are anytime i open a video. I have it set to load forced subtitles only in every single location I can find. I have tried uninstalling and reinstalling everything. I have tried different versions of BE/LAV/XY. I am about to blow my brains out.
ttnuagmada is offline   Reply With Quote
Old 23rd April 2021, 01:38   #61431  |  Link
brazen1
Try this in LAV Splitter:
Audio: eng
Subtitles:
eng:eng|f;eng:off;*:eng
In Subtitles Selection Mode select Advanced.
Check Enable Automatic Forced Subtitles Stream.
In MPC-BE Subtitles menu select Forced Subtitles (auto)
OR
Do what I do and avoid PGS subs because they display in the video real estate and use .srt subs from subscene that display below the video in the black bar. Name the .srt same as the video and it should display automatically.
I know nothing about XYsubfilter or any possible conflicts because I have no use for it.
W10 21H1 960-4GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit
KODI 20 MPC-HC/BE PDVD19 DVDFab 3,5 & 6 PotPlayer
82" Q90R Denon S720W
Old 23rd April 2021, 02:44   #61432  |  Link
VBB
VBB's Avatar
@ttnuagmada - Hey, nice to see you here. You should check our OLED thread, since you're the first one with a C1. We'd love to hear some feedback
Henry | LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 | NVIDIA SHIELD TV Pro 2019 | Plex
VBB is offline   Reply With Quote
Old 23rd April 2021, 04:47   #61433  |  Link
Asmodian
It sounds like everything is working as intended, at least if you are watching MKV's. A subtitle track marked as "default" in a mkv counts as forced subtitles.
Perhaps it would be good practice to not set any subtitle tracks as default when muxing matroska files.
madVR options explained
Old 1st May 2021, 07:31   #61434  |  Link
Megalith
Is http://madshi.net/madVRhdrMeasure131.zip the latest version? I updated to it but am still getting the annoying message about having to update my build.
Megalith is offline   Reply With Quote
Old 1st May 2021, 15:24   #61435  |  Link
zveroboy
Originally Posted by Megalith View Post
404 Not Found
zveroboy is offline   Reply With Quote
Old 1st May 2021, 16:01   #61436  |  Link
JaylumX
Something Else
Originally Posted by zveroboy View Post
404 Not Found
I do not know what has happened to v131 in the link but if you change it to v130, the link will work.
"If it doesn't scorch my eyes then it's not HDR"
JaylumX is offline   Reply With Quote
Old 1st May 2021, 16:59   #61437  |  Link
SamuriHL
SamuriHL's Avatar
Um, 131 doesn't exist. 130 is the latest beta build. And it will expire at the end of May.
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
Old 2nd May 2021, 05:32   #61438  |  Link
Perenista
Not sure if you have been following, if not take a look at this: I explained in these two links a bug probably from madVR, or D3D11 related. I thought this was MPC-BE's fault.
https://forum.doom9.org/showthread.p...12#post1940912
https://forum.doom9.org/showthread.p...93#post1941893
I was told to disable D3D11, which I did, first for h.264, then for MPEG-2, and now for good.
And so far the problems I reported have not returned. In fact they returned only when I tried today for the first time a DVDRip, which uses a different codec: MPEG-2. They haven't been seen ever since D3D11 was enabled and playing h.264 videos.
Even so, I keep using madVR. And was using when the bug occured in MPC-BE.
Perenista is offline   Reply With Quote
Old 2nd May 2021, 10:31   #61439  |  Link
it's not a bug madVR simple can't deint with d3d11 it was never implemented.
Old 3rd May 2021, 08:46   #61440  |  Link
Megalith
My bad; madVRhdrMeasure130 is indeed the latest version. But it's already expired.
