Old 8th November 2015, 02:33   #1461  |  Link
ndjamena
I can't get the source to compile in VS2012.
At first if complains that hmac.h is missing, so I found that file and added the directory to the include list, then it complains that "unresolved external symbol _hmac_sha | C:\Projects\MediaInfo\MediaInfoLib\Project\MSVC2012\Dll\MediaInfo.lib(Reader_libcurl.obj) | MediaInfoDll"
Anyway, I'm pretty sure all you'd have to do to fix part of the Matroska Tags issue is to, in file_mk.cpp, replace this line
if (Retrieve((stream_t)StreamKind, StreamPos, General_ID)==ID)
http://sourceforge.net/p/mediainfo/c...e_Mk.cpp#l2182
https://github.com/MediaArea/MediaIn...e_Mk.cpp#L2181
with
if (Retrieve((stream_t)StreamKind, StreamPos, General_UniqueID)==ID)
Then, as and addition, replace this
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("BPS")) return; //Useless
http://sourceforge.net/p/mediainfo/c...e_Mk.cpp#l2147
https://github.com/MediaArea/MediaIn...e_Mk.cpp#L2146
with this:
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("_STATISTICS_WRITING_APP")) return; //Useless
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("_STATISTICS_WRITING_DATE_UTC")) return; //Useless
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("_STATISTICS_TAGS")) return; //Useless
(It doesn't check to see if they're in the correct file, but it's better than what's happening now. I can't tell if all the tags have been read by that point or how to iterate through them and compare them to the headers.)
I can't compile it to check.
-edit-
This would be even better (I think)
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("BPS")) {Segment_Tag_SimpleTag_TagNames[0]=__T("*Bit rate"); TagString.append(__T(" bps"));}
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("DURATION")) {Segment_Tag_SimpleTag_TagNames[0]=__T("*Track duration/(HH:MM:SS.NNNNNNNNN");}
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("NUMBER_OF_FRAMES")) {Segment_Tag_SimpleTag_TagNames[0]=__T("*Track size/(Frames)");}
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("NUMBER_OF_BYTES")) {Segment_Tag_SimpleTag_TagNames[0]=__T("*Track size/(Bytes)");}
ndjamena is offline   Reply With Quote
Old 8th November 2015, 11:18   #1462  |  Link
ndjamena
How's this:
https://github.com/MediaArea/MediaIn...le_Mk.cpp#L385
		//Tags
		bool Tags_Verified=false;
		Ztring TagsList=Retrieve(Temp->second.StreamKind, Temp->second.StreamPos, "Security Tags List", Info_Text);
		if (!TagsList.empty())
			Clear(Temp->second.StreamKind, Temp->second.StreamPos, "Security Tags List");
			Ztring WritingApp=Retrieve(Temp->second.StreamKind, Temp->second.StreamPos, "Security Writing Application", Info_Text);
			Ztring WritingDate=Retrieve(Temp->second.StreamKind, Temp->second.StreamPos, "Security Writing Date", Info_Text);
			if ((!WritingApp.compare(Retrieve(Stream_General, 0, "Encoded_Application", Info_Text))) && (!WritingDate.compare(Retrieve(Stream_General, 0, "Encoded_Date", Info_Text))))
				{ Fill(Temp->second.StreamKind, Temp->second.StreamPos, "*Statistics Tags Varified", "True");  Tags_Verified=true; }
			else
				Fill(Temp->second.StreamKind, Temp->second.StreamPos, "*Statistics Tags Varified", "False");
			Clear(Temp->second.StreamKind, Temp->second.StreamPos, "Security Writing Application");
			Clear(Temp->second.StreamKind, Temp->second.StreamPos, "Security Writing Date");
			Ztring::iterator Back = TagsList.begin();
			Ztring TempTag;
			while (true)
				if ((Back == TagsList.end()) || (*Back == ' ') || (*Back == '\0'))
					if (TempTag == __T("BPS")) { TempTag = __T("Bit rate"); }
					else if (TempTag == __T("DURATION")) { TempTag = __T("Track Duration/(HH:MM:SS.NNNNNNNNN)"); }
					else if (TempTag == __T("NUMBER_OF_FRAMES")) { TempTag = __T("Track Size/(Frames)"); }
					else if (TempTag == __T("NUMBER_OF_BYTES")) { TempTag = __T("Track Size/(Bytes)"); }
					Ztring TagValue = Retrieve(Temp->second.StreamKind, Temp->second.StreamPos, TempTag.To_Local().c_str(), Info_Text);
					if (!TagValue.empty())
						Clear(Temp->second.StreamKind, Temp->second.StreamPos, TempTag.To_Local().c_str());
						Fill(Temp->second.StreamKind, Temp->second.StreamPos, __T('*') + TempTag.To_Local().c_str(), TagValue.To_Local().c_str());
					if (Back == TagsList.end()) break;
					TempTag.clear();
				else
					TempTag+=*Back;
				Back++;
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("BPS")) {Segment_Tag_SimpleTag_TagNames[0]=__T("Bit rate"); TagString.append(__T(" bps"));}
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("DURATION")) {Segment_Tag_SimpleTag_TagNames[0]=__T("Track Duration/(HH:MM:SS.NNNNNNNNN)");}
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("NUMBER_OF_FRAMES")) {Segment_Tag_SimpleTag_TagNames[0]=__T("Track Size/(Frames)");}
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("NUMBER_OF_BYTES")) {Segment_Tag_SimpleTag_TagNames[0]=__T("Track Size/(Bytes)");}
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("_STATISTICS_WRITING_APP")) {Segment_Tag_SimpleTag_TagNames[0]=__T("Security Writing Application");}
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("_STATISTICS_WRITING_DATE_UTC")) {Segment_Tag_SimpleTag_TagNames[0]=__T("Security Writing Date"); TagString.insert(0, __T("UTC ")); }
    if (Segment_Tag_SimpleTag_TagNames[0]==__T("_STATISTICS_TAGS")) {Segment_Tag_SimpleTag_TagNames[0]=__T("Security Tags List");}
Old 8th November 2015, 15:17   #1463  |  Link
ndjamena
I moved the tag processing up to the top of File_MK.cpp | File_Mk::Streams_Finish() so I could try to set the tag duration as a proper duration. I have no idea if the code will work though.
			Ztring Duration_Temp, Codec_Temp;
			if (Tags_Verified)
				Duration_Temp = Retrieve(Temp->second.StreamKind, Temp->second.StreamPos, "*Track Duration/(HH:MM:SS.NNNNNNNNN)", Info_Text);
				if (!Duration_Temp.empty())
					Ztring::iterator Front = Duration_Temp.begin();
					Ztring Parts [4];
					int CountParts = 0;
					while (true)
						if (Front == Duration_Temp.end() || *Front == __T(':') || *Front == __T('.'))
							CountParts++;
							if (Front==Duration_Temp.end() || CountParts == 4) break;
						else if (isdigit(*Front))
							Parts[CountParts]+=*Front;
						Front++;
					if (CountParts == 4)
						int64u Hours = Parts[0].To_int64u(10);
						int64u Minutes = Parts[1].To_int64u(10);
						int64u Seconds = Parts[2].To_int64u(10);
						Parts[3] = Parts[3].substr(0, 3);
						int64u Milliseconds = Parts[3].To_int64u(10);
						Duration_Temp.From_Number((((Hours * 3600) + (Minutes * 60) + Seconds) * 1000) + Milliseconds, 10);
						//Fill(StreamKind_Last, StreamPos_Last, Fill_Parameter(StreamKind_Last, Generic_Duration), Duration_Temp, true);
						//Clear(Temp->second.StreamKind, Temp->second.StreamPos, "*Track Duration/(HH:MM:SS.NNNNNNNNN)");
					else Duration_Temp.clear();
			if (Duration_Temp.empty())
				Duration_Temp=Retrieve(StreamKind_Last, Temp->second.StreamPos, Fill_Parameter(StreamKind_Last, Generic_Duration)); //Duration from stream is sometimes false
I had to move the declaration of the tag verification Boolean outside of my if statement...
Am I missing a library somewhere or is hmac.h not actually supposed to be included?
I really want this tag business done with.
Old 8th November 2015, 21:38   #1464  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
How are you building it? Only the MSVC 2013 project is kept up to date, which has it in the MediaInfoLib project under ThirdParty/hmac, so it should always be built with the rest of the lib. Don't use the older projects unless you regenerate them from cmake first. The GNU project is also kept up to date if you use mingw/gcc.
Old 8th November 2015, 22:49   #1465  |  Link
Zenitram
I forgot to update it when I added HMAC support.
Fixed
I take it, but copy/paste of code is not ideal (actually it is super difficult to understand the goal of the patch). Is it possible to fork, commit the code on your repo then do a pull request on GitHub? so we can discuss with the code directly and you can get comments directly on modified lines.
Want to know all about your media files? http://mediaarea.net/MediaInfo
Zenitram is offline   Reply With Quote
Old 8th November 2015, 23:03   #1466  |  Link
Zenitram
This was not intentional.
But I definitely can not support indefinitely all MSVC versions, so I just trashed MSVC 2005 / 2008 / 2010 projects.
I plan to keep MSVC 2012 and 2013 projects, and also propose soon MSVC 2015 project.
Old 8th November 2015, 23:45   #1467  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Actually all MSVC versions since VS2010 use the same Project file format. So you can just keep the VS2013 project up-to-date and still open it in VS2010/VS2012.
In my experience, VS2010 or VS2012 will complain that it doesn't support toolset "v120" when you open the VS2013 project, but you can easily fix that by changing the toolset to "v100" or "vs110" as needed. The rest usually works fine.
Old 9th November 2015, 00:33   #1468  |  Link
ndjamena
https://mediaarea.net/en/MediaInfo/S...nicodeControls
This link doesn't go anywhere...
Old 9th November 2015, 04:39   #1469  |  Link
ndjamena
Looky, a Matroska file with streams of different length!
General
Unique ID                                : 186503756937573924653882743356120778548 (0x8C4F512865F76243A09179B2D1FE4734)
Complete name                            : D:\Make\Test.mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 259 MiB
Duration                                 : 22mn 49s
Overall bit rate                         : 1 584 Kbps
Encoded date                             : UTC 2015-11-09 03:36:45
Writing application                      : mkvmerge v8.5.1 ('Where you lead I will follow') 64bit
Writing library                          : libebml v1.3.3 + libmatroska v1.4.4
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Baseline@L3
Format settings, CABAC                   : No
Format settings, ReFrames                : 1 frame
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 22mn 49s
Bit rate                                 : 1 548 Kbps
Width                                    : 628 pixels
Height                                   : 474 pixels
Display aspect ratio                     : 4:3
Frame rate mode                          : Constant
Frame rate                               : 23.976 fps
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.217
Stream size                              : 253 MiB (98%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.601 NTSC
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.601
*Statistics Tags Varified                : True
*Track Duration/(HH:MM:SS.NNNNNNNNN)     : 00:22:49.828000000
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : A_AAC
Duration                                 : 5mn 2s
Bit rate                                 : 152 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 KHz
Stream size                              : 5.49 MiB (2%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
*Track Duration/(HH:MM:SS.NNNNNNNNN)     : 00:05:02.976000000
Old 9th November 2015, 10:44   #1470  |  Link
ndjamena
Bah! It's still showing 'unknown' for the DTS-MA bitrate. That must be hardcoded somewhere else!!!!!
Old 9th November 2015, 11:16   #1471  |  Link
Teebeeke
am trying to use mediainfo to import file information, but i can't seem to get the right code for height and width of a moviefile.
these work fine:
Dim temp_FileName As String = MI.Get_(StreamKind.General, 0, "FileName")
Dim temp_FileSize As String = MI.Get_(StreamKind.General, 0, "FileSize")
Dim temp_FileOverallBitRate As Decimal = MI.Get_(StreamKind.General, 0, "OverallBitRate")
Dim temp_FileDuration As Integer = MI.Get_(StreamKind.General, 0, "Duration")
but here i kinda am lost when i want height / width
Dim temp_Filewidth1 As String = MI.Get_(StreamKind.General, 0, "Width_Original")
Dim temp_FileWidth2 As String = MI.Get_(StreamKind.Video, 0, "Width")
Dim temp_FileWidth3 As String = MI.Get_(StreamKind.Video, 1, "Width_Original")
Dim temp_FileWidth4 As String = MI.Get_(StreamKind.Video, 0, "Width/string")
Dim temp_FileWidth5 As String = MI.Get_(StreamKind.Video, 1, "Width/string")
i'm a bit confused, where am i going wrong? (hope someone can/will help)
file info:
PHP Code:
General
UniqueID
/String                  262114971647940602408317479032599003676 (0xC53181DCE616FD46A51C09EE1152C21C)
CompleteName                     D:\testfile.hevc.x265.mkv
Format
Matroska
Format_Version
Version 4 Version 2
FileSize
/String                  262 MiB
Duration
/String                  55mn 1s
OverallBitRate
/String            666 Kbps
Movie
Test File made for testing mediainfo import
Encoded_Application
/String       Lavf56.40.101
Encoded_Library
DESCRIPTION
testfile
Video
ID
/String                        1
Format
HEVC
Format
/Info                      High Efficiency Video Coding
Format_Profile
Main@L3.1@Main
CodecID
V_MPEGH/ISO/HEVC
Width
/String                     1 280 pixels
Height
/String                    720 pixels
DisplayAspectRatio
/String        16:9
FrameRate_Mode
/String            Variable
FrameRate_Original
/String        23.976 fps
ColorSpace
YUV
ChromaSubsampling
4:2:0
BitDepth
/String                  8 bits
Encoded_Library
/String           x265 1.7+399-cbdefdfca877:[Linux][GCC 4.9.3][64 bit8bit
Encoded_Library_Settings
deleted (too big)
Default/
String                   Yes
Forced
/String                    No
DURATION
00:55:01.736000000
Audio
ID
/String                        2
Format
AAC
Format
/Info                      Advanced Audio Codec
Format_Profile
LC
CodecID
A_AAC
Duration
/String                  55mn 1s
Channel
(s)/String                2 channels
ChannelPositions
FrontL R
SamplingRate
/String              48.0 KHz
Compression_Mode
/String          Lossy
Encoded_Library
/String           Lavc56.57.100 aac
Default/String                   Yes
Forced
/String                    No
DURATION
00:55:01.749000000
Teebeeke is offline   Reply With Quote
Old 9th November 2015, 11:27   #1472  |  Link
Zenitram
You don't say why you are lost: no result or no knowledge of which field is good for you.
for 99% of people, MI.Get_(StreamKind.Video, 0, "Width") is the only one needed.
Old 9th November 2015, 11:36   #1473  |  Link
ndjamena
InString = MI.Get(Stream_Video, a, L"Width_Original", Info_Text);
if (InString.empty())
InString = MI.Get(Stream_Video, a, L"Width", Info_Text);
Old 9th November 2015, 11:45   #1474  |  Link
Teebeeke
using .net (VS2012)
When i use MI.Get_(StreamKind.Video, 0, "Width") it doesnt give me a result, it stays empty.
Old 9th November 2015, 12:17   #1475  |  Link
Zenitram
It is also filled by the DTS parser, and I guess there is a conflict between parsers.
I don't have a file with DTS-HD and statistic tags, please provide one.
Old 10th November 2015, 06:48   #1476  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
using .net (VS2012)
MediaInfo can parse the width out of mkv, but not raw HEVC. Your file name shows you running it against the raw, not the muxed file.
Edit: Actually, I take that back, it looks like MediaInfo should be able to run against raw HEVC too now. What file format is your test file being detected as?
Old 10th November 2015, 09:28   #1477  |  Link
Teebeeke
This is all the information i get:
Format : HEVC
Format/Info : High Efficiency Video Coding
Format/Url : http://www.itu.int
Commercial name : HEVC
Format profile : Main@L3.1
Internet media type : video/H265
Codec ID : V_MPEGH/ISO/HEVC
Codec : V_MPEGH/ISO/HEVC
Codec profile : Main@L3.1
PHP Code:
Open
Inform with Complete
=true
General
Count
285
Count of stream of this kind
1
Kind of stream
General
Kind of stream
General
Stream identifier
0
Unique ID
Unique ID
Count of video streams                   1
Count of audio streams
1
Video_Format_List
HEVC
Video_Format_WithHint_List
HEVC
Codecs Video
V_MPEGH/ISO/HEVC
Video_Language_List
English
Audio_Format_List
AAC
Audio_Format_WithHint_List
AAC
Audio codecs
AAC LC
Complete name
Folder name
D:
File name                                testfile.hevc.x265
File extension
mkv
Format
Matroska
Format
Matroska
Format
/Url                               http://packs.matroska.org/
Format/Extensions usually used           mkv mk3d mka mks
Commercial name
Matroska
Format version
Version 4 Version 2
Codec
Matroska
Codec
Matroska
Codec
Codec/Extensions usually used            mkv mk3d mka mks
File size
274728718
File size
262 MiB
File size
262 MiB
File size
262 MiB
File size
262 MiB
File size
262.0 MiB
Duration
3301749
Duration
55mn 1s
Duration
55mn 1s 749ms
Duration
55mn 1s
Duration
00:55:01.749
Overall bit rate
665656
Overall bit rate
666 Kbps
Title
testfile.hevc.x265
Movie name
File creation date
UTC 2015-11-09 08:53:25.743
File creation date
(local)               : 2015-11-09 09:53:25.743
File last modification date
UTC 2015-11-09 08:55:38.124
(local)      : 2015-11-09 09:55:38.124
Writing application
Lavf56.40.101
Writing library
Lavf56.40.101
Writing library
Lavf56.40.101
DESCRIPTION
Testfile
Video
Count
278
1
Kind of stream
Video
Kind of stream
Video
Stream identifier
0
StreamOrder
0
ID
1
ID
1
Unique ID
1
Format
HEVC
Format
Format
/Url                               http://www.itu.int
Commercial name                          HEVC
Format profile
Main@L3.1
Internet media type
video/H265
Codec ID
V_MPEGH/ISO/HEVC
Codec
V_MPEGH/ISO/HEVC
Codec
V_MPEGH/ISO/HEVC
Codec profile
Main@L3.1
Width
1280
Width
1 280 pixels
Height
720
Height
720 pixels
Pixel aspect ratio
1.000
1.778
16:9
Frame rate mode
VFR
Frame rate mode
Variable
Original frame rate
23.976
Original frame rate
23.976 fps
Resolution
8
Resolution
8 bits
Colorimetry
4:2:0
Color space
YUV
Chroma subsampling
4:2:0
Bit depth
8
Bit depth
8 bits
Delay
0
Delay
00:00:00.000
Delay
origin                            Container
Delay
origin                            Container
Writing library
Lavc56.57.100 libx265
Writing library
Language
en
Language
English
Language
English
Language
en
Language
eng
Language
en
Default                                  : Yes
Default                                  : Yes
Forced
No
Forced
No
DURATION
00:55:01.736000000
Audio
Count
223
1
Kind of stream
Audio
Kind of stream
Audio
Stream identifier
0
StreamOrder
1
ID
2
ID
2
Unique ID
2
Format
AAC
Format
Commercial name
AAC
Format profile
LC
Format settings
SBR                     No (Explicit)
Format settingsSBR                     No (Explicit)
Codec ID                                 A_AAC
Codec
AAC LC
Codec
AAC LC
Codec
/Family                             AAC
Duration
3301749
Duration
55mn 1s
Duration
55mn 1s 749ms
Duration
55mn 1s
Duration
00:55:01.749
Channel
(s)                               : 2
Channel
(s)                               : 2 channels
Channel positions
FrontL R
Channel positions
2/0/0
ChannelLayout
L R
Sampling rate
48000
Sampling rate
48.0 KHz
Samples count
158483952
Resolution
32
Resolution
32 bits
Compression mode
Lossy
Compression mode
Lossy
Delay
0
Delay
00:00:00.000
Delay
origin                            Container
Delay
origin                            Container
Delay relative to video
0
Video0 delay
0
Writing library
Lavc56.57.100 aac
Writing library
Lavc56.57.100 aac
Default                                  : Yes
Default                                  : Yes
Forced
No
Forced
No
DURATION
00:55:01.749000000
Old 10th November 2015, 16:41   #1478  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Video
Count of stream of this kind             : 1
Kind of stream                           : Video
Unique ID                                : 1
Format                                   : HEVC
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Pixel aspect ratio                       : 1.000
Display aspect ratio                     : 1.778
Display aspect ratio                     : 16:9
Frame rate mode                          : VFR
Frame rate mode                          : Variable
Original frame rate                      : 23.976 fps
Resolution                               : 8 bits
Colorimetry                              : 4:2:0
Bit depth                                : 8 bits
I wonder why the HEVC video stream has been encoded with a 'variable' frame rate
Old 10th November 2015, 16:55   #1479  |  Link
Zenitram
VFR/CFR detection in Matroska is sometimes buggy, I would not rely too much on it. having less false positives is on the ToDo-list.
Here, the frame rate is also filled in the HEVC bitstream, I would rely more on it.
Old 10th November 2015, 17:00   #1480  |  Link
Teebeeke
But does that explain why MI.Get_(StreamKind.Video, 0, "Width") gives me 0 results?
If i use:
MI.Option_("Complete")
To_Display += MI.Inform()
which gives above info, it shows the width, but if i use MI.Get it shows no value.
