Old 9th March 2024, 13:24   #4861  |  Link
LigH
LigH's Avatar
hydra3333 reported a few issues regarding the portability support and installation in M-AB-S, to be tested...
New German Gleitz board
Old 10th March 2024, 13:23   #4862  |  Link
amayra
Quality Checker
amayra's Avatar
are you going to drop support for CPU without AVX2 like intel ivy bridge architecture (i have i7 3770)
i think there way to optimize VapourSynth for new CPU extensions when it detect without breaking support for old one right ?
I love Doom9
amayra is offline   Reply With Quote
Old 10th March 2024, 13:33   #4863  |  Link
LigH
LigH's Avatar
AVX2 should not be a minimum requirement, but one of several optimization paths. VapourSynth, as a Python extension, could also run on non-intel CPUs, where a required SSE/AVX support would make no sense but comparable SIMD instruction sets are available instead...
Old 10th March 2024, 16:48   #4864  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Not planned. I do however think it's pointless to write optimized code paths for anything less than AVX2 for new code.
Things that definitely will be dropped at some point:
  • API3 compatibility - in a year or so, everything of value has been converted or will be soon
  • Windows 7 support - probably as a result of Python 3.8 becoming too old, not enough users actually testing it or MS relegating it to a separate compiler option with a long list of quirks much like windows XP support
Also a big part of the reason for requiring SSE2 was feature parity with x64 builds. Lots of instruction support checks that could be skipped and compiling with SSE2 instructions also produces a bit faster code.
Myrsloik is offline   Reply With Quote
Old 10th March 2024, 19:27   #4865  |  Link
amayra
Quality Checker
amayra's Avatar
i always hate it when developers forced minimum requirement by not optimized application instead they use compiler flags like ("-march=cpu-type", CFLAGS, CCFLAGS and CXXFLAGS )
i fully understand and agreed with dropping old OS that not even modern web browser support
any CPU that don't support SSE2 i don't think can do anything with VS or any other applications
I love Doom9
Old 13th March 2024, 12:31   #4866  |  Link
Myrsloik
Myrsloik's Avatar
The portable install script and portable zip have now been sneakily updated to fix several annoying issues related to plugin and script paths. Windows 7 support also added, however you'll need to install powershell 5.0 or later to actually run it since the bundled version on win7 is ancient.
Old 13th March 2024, 19:59   #4867  |  Link
_Al_
Loading vapoursynth clip from any path to portable vapoursynth could be done via loading script text using importlib module, not using scripts path.
If python loading script utility is in portable directory (or as an app), current path is an utility directory (portable directory), so dlls are loaded from portable directory. VSPipeloads that script (from portable directory) ok.
Is it related to that?
But vapoursynth installed dll's are preferred if vapoursynth is installed, dll's from Program Files/VapourSynth or AppData/Roaming/VapourSynth directory (Selur brought it up couple of times).
import importlib
vs.clear_outputs()
spec = importlib.util.spec_from_loader('vs_script_text', loader=None)
my_script_module = importlib.util.module_from_spec(spec)
exec(script_text, my_script_module.__dict__)
clip = vs.get_output(index)[0]
#or: clip = my_script_module.clip
_Al_ is offline   Reply With Quote
Old 13th March 2024, 20:11   #4868  |  Link
Selur
Selur's Avatar
Yeah, still hoping that we will one day get a way to disable autoloading inside a script.
Old 27th April 2024, 07:14   #4869  |  Link
Selur
Selur's Avatar
How can one validate the frame properties?
I want to check that '_Transfer', '_Matrix', 'Primaries', '_ColorRange', '_FieldBased' are set to valid values.
Are the enums of valid values for these properties accessible in a script, so I can compare against them?
Cu Selur
Old 28th April 2024, 23:31   #4870  |  Link
_Al_
besides manually provide dictionaries or lists (as in the other thread) , vapoursynths Enums could be used:
vs.MatrixCoefficients
vs.TransferCharacteristics
vs.ColorPrimaries
vs.ColorRange
vs.FieldBased
using MatrixCoefficients Enum for example getting names and values:
print(vs.MatrixCoefficients.__members__)
getting values only:
print(vs.MatrixCoefficients.__members__.values())
so for matrix, checking if value is valid might be:
clip =  vs.core.std.BlankClip()
frame = clip.get_frame(0)
value = frame.props.get('_Matrix', None)
if value in [None, 2, 3] or value not in vs.MatrixCoefficients.__members__.values():
    clip = clip.std.SetFrameProps(_Matrix=1) # defaulting
print(frame.props)
<vapoursynth.FrameProps {'_DurationNum': 1, '_DurationDen': 24, '_Matrix': 1}>
Old 29th April 2024, 04:14   #4871  |  Link
Selur
Selur's Avatar
@_AI_: Thanks! That's what I was looking for.
Cu Selur
Old 2nd May 2024, 15:31   #4872  |  Link
Selur
Selur's Avatar
Does anyone have an alternative TemporalDegrain2 for Vapoursynth?
(the one in G41Fun.py) crashes with extraSharp=True and I can't figure out why)
Update:
=> fixed it; problem was in CTMF
Cu Selur
Old 3rd May 2024, 19:17   #4873  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
There's also a version in VSDenoise: https://github.com/Jaded-Encoding-Th.../funcs.py#L193
Old 3rd May 2024, 19:24   #4874  |  Link
Selur
Selur's Avatar
Nice! Thanks for the info!
(sadly: vs-denoise does not seem to work with Vapoursynth R65 portable, https://github.com/Jaded-Encoding-Th...se/issues/121; works with R66)
Old 3rd May 2024, 19:24   #4875  |  Link
Adub
Adub's Avatar
@Myrsloik - plugin development question for you
Is it possible for a plugin to deterministically calculate max memory usage in Vapoursynth? For example, if I have a plugin that I know is going to work on N number of frames (say 3, prev + current + next), then can I use some aspect of the VS API to calculate the upper bound of memory usage?
It might even as simple as saying a plugin needs to process N frames, where each frame requires Y amount of data per frame and multiply that by the Z cores returned from the VS API?
I ask, because I'm considering the potential of allocating all required memory in one fell swoop (say at plugin Create) and then passing that pointer in the plugin data to GetFrame, using that as a pool, and then freeing that memory in plugin Free. Basically, I'm trying to minimize as many calls to malloc as possible.
Old 3rd May 2024, 19:32   #4876  |  Link
Myrsloik
Myrsloik's Avatar
Technically the upper bound would be the number of threads times the buffer space you need. But usually you don't even get remotely close to that due to threads spending time in other places. If you do it, WHICH YOU ABSOLUTELY SHOULDN'T, you'd be better off simply making new allocations when your filter local pool doesn't have an available set of buffers.
What you should do:
For small allocations (up to a few kb) are handled very well by new/delete/malloc/free and the process heap is your pool.
For larger allocation (like frame sizes) you can simply create a new frame (gray format for single plane). The overhead is very low and it's fast. The memory is now in the frame buffer pool and can be shared between everything. Including other instances of your own plugin.
Work with the system, don't reimplement it.
Old 4th May 2024, 15:09   #4877  |  Link
Selur
Selur's Avatar
@Mysrloik: I encountered that vsedits memory usage increases on each reload (when having biforst.dll in my scripts). Can you chime in whether this (https://github.com/YomikoR/VapourSynth-Editor/issues/55) is likely an issue of vedit, bifrost or Vapoursynth itself?
Thanks!
Old 4th May 2024, 18:51   #4878  |  Link
Myrsloik
Myrsloik's Avatar
R67 is out. A pure bugfix release that should make everyone snooze.
speed, vaporware, vapoursynth
