#1 | Link |
Linux Subtitle "calculator"?
Is there something like a Linux Subtitle "calculator"?
By "calculator" I mean the following. Suppose you have several episodes of a series, and you have created the Subtitle .ass file for one episode creating the subtitles for the intro song and probably also for the "extro" song. Now, the intro starts at different times for each episode. I would need a way to convert e.g. Code:
Dialogue: 0,0:22:55.00,0:23:05.50,Rava Dialogue,,0000,0000,0000,,I will head for tomorrow in this cradle woven from kindness E.g. add 15 seconds zero milliseconds to the start time of 0:22:55:0,0 and the same offset to the end time of 0:23:05.50, making the above Code:
Dialogue: 0,0:23:10.00,0:23:20.50,Rava Dialogue,,0000,0000,0000,,I will head for tomorrow in this cradle woven from kindness |
#2 | Link |
You can run SubtitleEdit with mono, this is what I do.
The synchronization requires selecting specific lines, though.
LG C2 OLED | GitHub Projects |
#3 | Link |
This is what you would use prass for.
https://github.com/tp7/prass (or maybe https://github.com/Ryu1845/Prass since it's been updated) But you might need to splice the files apart first so only the lines that need to get shifted do (an alternative is that you could use ordered chapters and have the intro/outro in their own files, in which case the subs are always correctly timed). Or you know, just load the thing up in Aegisub and use it to perform the time shifting. |
#4 | Link | ||
I check that out, Quote:
ffmpeg -i INPUT -f ffmetadata FFMETADATAFILE Code:
ffmpeg -i INPUT -i FFMETADATAFILE -map_metadata 1 -codec copy OUTPUT If so, how does have the intro/outro in their own files work? You mean the video itself split? Or chapters added via metadata (like the code above) but the video still only one file? If so how does that work? E.g. mpv loads subtitle when video and subtitle file have the same name. E.g. video "whatever ep. 01.mp4" and subtitles "whatever ep. 01.ass" |
#5 | Link |
Ordered chapters is a Matroska feature. It's possible through manipulating the XML chapters file and doing segment linking in combination, so that the OP file and ED files are separate, and each of the episodes has those segments removed (but the chapters file redirects the chapter points for the OP and ED to the external files).
