28th January 2020, 20:15 | #21 | Link | |
From my understanding the parameter "pools" has no impact on quality. It is by default set to max number of available Hyperthreading cores |
29th January 2020, 17:06 | #22 | Link | |
29th January 2020, 17:16 | #23 | Link |
Hi
I only have 1 Socket iny my TR 3960x. I currently don't know if x265 detects it as 1 or 2 Numa nodes. However increasing pools from default/auto 48 to 64 does help with CPU utilization and speed - although it's not stuck at 100%, but at least 85 to 95 which is better than 75% average with the auto setting. In the end it al comes down to: Scaling isn't optimal above 12c CPUs and If one just encodes one job a 16c and 32t is the optimal CPU / bang for the buck here with a 3950x as the higher cost of a 24c CPU isn't worth it at the moment A 24c CPU makes sense if one encodes more than one job in parallel or uses distributed encoding |
29th January 2020, 18:01 | #24 | Link | |
29th January 2020, 19:25 | #25 | Link | |
結城有紀
In my personal use case I found it a good balance to run 4-6 threads for x265 and another 2-4 threads for AviSynth. |
29th January 2020, 19:33 | #26 | Link |
結城有紀
Also don't forget that, half of the CPU threads are SMT. So if you wisely use half of the CPU threads (i.e. 16 threads, each per 16 physical cores) you'll see 50% CPU utilization but underneath you are already using 80% of your CPU capacity. Pushing it to 100% CPU utilization will get you at most 25% more speed from 50% utilization before any extra threading loss.
2nd February 2020, 17:02 | #27 | Link |
current settings are more like that for 1080p video on 4c 8t i7 cpu:
wpp / ctu=32 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=2 / tu-inter-depth=2 / me=3 / subme=5 / merange=57 / rect / no-amp / max-merge=3 / temporal-mvp / no-early-skip / rskip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=23 / scenecut=40 / rc-lookahead=30 / lookahead-slices=4 / bframes=8 / bframe-bias=0 / b-adapt=2 / ref=4 / limit-refs=2 / limit-modes / weightp / weightb / aq-mode=3 / qg-size=32 / aq-strength=0.80 / cbqpoffs=0 / crqpoffs=0 / rd=4 / psy-rd=0.70 / rdoq-level=2 / psy-rdoq=1.00 / log2-max-poc-lsb=8 / limit-tu=0 / no-rd-refine / signhide / deblock=1:1 / no-sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=crf / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ipratio=1.40 / pbratio=1.30 Last edited by sonyzz; 2nd February 2020 at 17:05. |
3900x, 3950x, hevc, ryzen, x265 |
