Old 2nd January 2022, 16:16   #41  |  Link
rupeshforu3
rupeshforu3's Avatar
Ok thanks for your clarification.
Sent from my LM-G710 using Tapatalk
rupeshforu3 is offline   Reply With Quote
Old 2nd January 2022, 21:09   #42  |  Link
jlw_4049
Honestly just get the Anthlon dual core from ryzen. It'll be two cores and 4 threads, music encoding is very thread limited and this is more then enough.
It also has an on the die GPU.
AMD Athlon 3000G 2-Core, 4-Thread Unlocked Desktop Processor with Radeon Graphics https://www.amazon.com/dp/B0815JGFQ8...ing=UTF8&psc=1
Sent from my SM-G986U1 using Tapatalk
jlw_4049 is offline   Reply With Quote
Old 3rd January 2022, 03:56   #43  |  Link
rupeshforu3
Ok can I buy Athlon x4 970 or a8 9600 which are quad core apus and with AM4 socket. These costs less than Athlon 3000g.
Old 3rd January 2022, 04:18   #44  |  Link
jlw_4049
Just verify what ever chip you get will be supported by the board you own. Then yes it'll work fine.
Old 3rd January 2022, 13:38   #45  |  Link
rupeshforu3
Yes I have checked whether these processors are supported by my am4 motherboard b350.
Someone of you suggested to buy second hand but the above are better than second hand. If they are available in market it's better to buy as they cost less and require lower psu etc.,.
Old 3rd January 2022, 15:20   #46  |  Link
One good thing about 2nd hand gear is that it has already been 'burnt in' for you,
Burn-in:- https://en.wikipedia.org/wiki/Burn-in
The most likely time for a system to fail is when its brand spanking new. [or when it is really really really old - where it would be really really really cheap]
Old 3rd January 2022, 17:47   #47  |  Link
rupeshforu3
No i am not going to buy any second hand but I am suggesting not to buy them. I am saying that we can get other new components at reduced price and with lower specs.
audio dsp, transcode audio
