Old 8th September 2020, 14:57   #1  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
x266 VVC Encoder
Development is already underway:
MulticoreWare announces the formation of x266 consortium and development of an open source code for VVC encoding is already underway. Similarly, MulticoreWare’s x265 consortium led the development of the open source code x265 for HEVC based encoding and become the mmost widely used HEVC encoding software.
Application areas of x266 will include encoding High Definition(HD) and Ultra High Definition(UHD- 4K and 8K) video for broadcasting, live streaming, Over The Top(OTT) video distribution, Adaptive Bit Rate(ABR) streaming, video storage and archiving, surveillance, screen content sharing, video teleconferencing, video games, eSports, immersive media such as 360-degree video, Virtual Reality (VR) etc.
x266 will be able to encode video with Standard, High Dynamic Range and Wide Color Gamut. It will also offer a user flexibility to trade-off speed of encoding with coding efficiency. Initial version of the x266 software will support single layer coding of 10 bits video with 4:2:0 chroma format. More advanced versions will support multilayer coding, higher than 10 bits depth video and higher than 4:2:0 chroma formats.
birdie is offline   Reply With Quote
Old 8th September 2020, 17:14   #2  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Great news!!
Old 8th September 2020, 21:02   #3  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
Awesome!
TV: Samsung 50" QE50Q60T AVR: Yamaha RX-V481 5.1 CD Player: Yamaha CD-S300 DAB+ Tuner: Yamaha T-D500 BD Player: Samsung UBD-M8500 UHD Speakers: Klipsch 5.1 Reference Phono: Audio-Technica AT-LP120XUSB
Old 8th September 2020, 23:27   #4  |  Link
Greenhorn
Hopefully, this will get off to a good start; the availability of a genuinely good encoder seems like it'll be critical for VVC.
Greenhorn is offline   Reply With Quote
Old 9th September 2020, 07:00   #5  |  Link
ksec
Hopefully x265 and x266 being developed by the same team would speed things up a little bit.
What that means is that we could see EVC, VVC and AV2 Encoder all appearing within a year.
Previously iwod
ksec is offline   Reply With Quote
Old 9th September 2020, 09:15   #6  |  Link
hajj_3
AV2? That would be a bad idea as it would make it less likely for AV1 to receive mass adoption. They should wait 2.5yrs more to ratify AV2.
Also lots of patents will have expired over 5yrs since AV1 was ratified it they wait.
Old 9th September 2020, 10:24   #7  |  Link
ksec
Yes..... and the originally schedule for AV2 is 2020. And AV1 was suppose to be 2017....
They sure should take their time to ratify, but who knows.
Previously iwod
Old 9th September 2020, 11:03   #8  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Yep, that's the idea.
I really hope it will be ready for 2021. That would be great.
(On the other hand, it would mean that now I don't have any excuses not to buy a new CPU...)
Speaking of new hardware, what about decoding support? Is there anything in program? Like new gen GPUs?
Old 9th September 2020, 11:16   #9  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
To be honest I'm a lot more excited by VVC than AV1. The former looks like a codec which will be embraced by the scene and which will be viable for end users. AV1 is so computationally expensive it's suitable only for Google with their insane compute resources. SVT-AV1 is fast and ... blurry at all presets. Of course, patents and everything, only it doesn't matter for your personal archival purposes.
Also, AV1/H.265/VP9 basically offer nothing/very little vs. H.264 in terms of transparent near-lossless compression where H.264 is still the king. I wonder if H.266 could change that.
Old 9th September 2020, 11:32   #10  |  Link
hajj_3
Now is a bad time to buy a new cpu. AMD's zen 3 cpu's are going to be released soon, i'd wait until then before buying.
VVC was only ratified recently, it will likely take 1.5-2.5yrs for hardware decoders to ship in apu's or gpu's. So not likely until 2022.
Old 10th September 2020, 08:01   #11  |  Link
tnti
Hope that there is something new in the rate control algorithm of X266.
tnti is offline   Reply With Quote
Old 10th September 2020, 15:58   #12  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
Is VCC specced to support floating point code values?
Cary Knoop is offline   Reply With Quote
Old 10th September 2020, 17:07   #13  |  Link
benwaggoner
Like what?
Ben Waggoner
My Compression Book
Old 13th September 2020, 17:26   #14  |  Link
tnti
Like what?
You should understand Alibaba's S265 encoder.
Old 14th September 2020, 16:27   #15  |  Link
benwaggoner
What about it? Is there a particular rate control feature you'd like to see adopted elsewhere? If so, can you provide details?
Ben Waggoner
My Compression Book
Old 22nd September 2020, 04:58   #16  |  Link
tnti
https://www.livevideostack.cn/news/t...-h265-cdn-rtc/
Sorry, there is no English version of the PPT.
Old 22nd September 2020, 17:41   #17  |  Link
benwaggoner
Can you offer a summary? I can't read Chinese, nor can most of us here.
Ben Waggoner
My Compression Book
Old 24th September 2020, 04:12   #18  |  Link
quietvoid
Does anyone have more info about this repo here: https://github.com/chenm001/x266
Looks like just a research implementation but curious.
quietvoid is offline   Reply With Quote
Old 24th September 2020, 06:23   #19  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
The last release says "on Oct 21, 2017" when the standard wasn't even remotely a thing and was so far away from being finalized. I don't think it's something official nor from Multicoreware...
Old 2nd October 2020, 09:33   #20  |  Link
tnti
Min Chen temporarily has no time to maintain this open source project.
I asked about this in July 2020.
vvc, x266
