Old 23rd November 2016, 00:53   #40621  |  Link
austonrush
How many NGU users are using soften edges or add grain?
I'm using both . At a level of one each. Since Add grain was fixed it has grown on me for real life video (I don't use it for animation). Soften edges is a must with NGU.
austonrush is offline   Reply With Quote
Old 23rd November 2016, 00:59   #40622  |  Link
austonrush
I'm not liking any version of NGU for lower quality SD content. It significantly enhances artifacts and blocking. NNEDI3 64 with SR2 or SR3 performs much better in this space. Anyone else tested this. I don't have images to post right now but, it was not hard to see.
My current profiles are setup to use NGU image doubling for 720 and 1080 content. I'm sticking with NNEDI3 SR2 for low def content.
Old 23rd November 2016, 01:02   #40623  |  Link
Warner306
So far, I agree soften edges is a must have. Haven't played with add grain. Neither option appears to hamper performance much.
Old 23rd November 2016, 01:04   #40624  |  Link
Scyna
Originally Posted by Sp00kyFox View Post
thighhighs got it right. I just tried it with MPC-HC and the problem is still there with the x32 version but gone with the x64 version.
I have the exact same problem you have except I get no video just audio. The queues also stay at 1/1. I'm on win 10 64x MSI Nvidia 1070 laptop 375.95 drivers.
Scyna is offline   Reply With Quote
Old 23rd November 2016, 01:05   #40625  |  Link
ryrynz
ryrynz's Avatar
I didn't stated that this were the case. I actually asked if anyone else experienced this issue and as you can see someone did. so your claim that no one else has this problem is already false.
I've not seen this listed as an issue. You found the one guy that experienced it.. Congrats, now lose the attitude.
no other applications were running at the time of capturing and if you've read my post you should know that I just installed a new GPU driver.
inb4: format c and reinstall windows
So? Installing a new driver doesn't always fix issues. What you're doing is just bypassing the issue with the driver working in 32 bit, so reverting or doing what I said may just fix it. inb4: I actually know what I'm doing but yet here I am using a 32 bit player :P
Try earlier drivers or completely remove the old set and reinstall. This probably isn't an issue across the entire set released by Nvidia and doesn't appear to be related to a specific family of cards.
I have no issues using the latest drivers on my 960 with a 32 bit player, so you shouldn't either..
Old 23rd November 2016, 02:12   #40626  |  Link
Sp00kyFox
Sp00kyFox's Avatar
two guys, see Scynas post. and what attitude? I wasn't trying to anger or lecture you. maybe don't assume people are stupid before acting all so snippy and we can all help each other out in a friendly tone.
I didn't claim that installing a new driver would fix the issue. I just installed a new one recently but the problem was already there with the previous one. and did you read my posts? it does NOT work in 32bit but in 64bit.
you're not the only one who knows how to properly handle a computer. yet here I am, a computer scientist who knows what he's doing and it's still not working in 32bit players. that's why I asked for help in the first place not because I'm too lazy to look for a solution.
there are more components to a system then the GPU and its driver. reminds me of gaming forums where "but it works fine here so you're the problem" is a common answer.
now, to cite you, lose the attitude. you could start by telling us what OS, what player and what render path in madvr you use and maybe we can figure out together what the issue is.
Sp00kyFox is offline   Reply With Quote
Old 23rd November 2016, 02:24   #40627  |  Link
what decoder is used?
Old 23rd November 2016, 02:24   #40628  |  Link
Hyllian
Hyllian's Avatar
with real pixelart, not good. with downscaled drawings or renderings it works great though as expected. here are some examples, the last one works best with this filter:
https://imgur.com/a/TnTFW
Thanks for the images. Waifu2x presents the same behavior too. They have very similar outputs. It should be great with pre-rendered games.
Hyllian is offline   Reply With Quote
Old 23rd November 2016, 02:56   #40629  |  Link
Sp00kyFox
Sp00kyFox's Avatar
on my side it's LAVFilters v0.68.1-35. I usually use it with DXVA2 (copy-back) but I just tried all the other options with no success.
no problem. the challenge would be to seperate the image between pre-rendered elements and pixelart or 3D objects. maybe a similar approach like you once did with xBR does also work with NGU.
Old 23rd November 2016, 07:23   #40630  |  Link
Backflash
to repeat myself, the problem is not performance related.
Do videogames run fine? If you didn't try probably VRAM is fried or slowly dying. Chip itself might be giving out such artifacts as well.
Does it crash your system? It soon will. I fried a few cards this way.
Which brand?
I think people need a disclaimer to stop running scalers that spin GPUs to max temperatures on lower end hardware or weak brands, it's really easy to ruin videocard with NNDI3 specially if you like to watch some series whole weekend non stop like me, games are much more tame temperature wise.
Also this is why I switched to NGU, it doesn't 100% my GPU(r9 390) all the time like NNDI3, I like when it's 55C' on a moderate load.
Backflash is offline   Reply With Quote
Old 23rd November 2016, 07:29   #40631  |  Link
burfadel
I agrree Backflash, that looks like video memory corruption. It's one of the side affects you can get from overclocking too high, it might not necessarily crash. I'm not suggesting he was overclocking, just using that as an example. It could be something else as well of course, it's just one possibility that seems most likely at this stage. The settings used seems very overkill though.
Old 23rd November 2016, 07:46   #40632  |  Link
ryrynz
ryrynz's Avatar
Switching to a 64 bit media player fixes it so it's obviously driver related.
Definitely corruption but I'm guessing he wanted to know the cause.
It was, pretty silly to say it's not related to performance then post a screenshot with the most extreme settings.. but whatever.
Not posting like your stupid is a good start.
Cool story bro. Tell me about the driver that came before that and the one before that.. same issue? Tell me about all the ones you tried?
Oh wait, that would've been the smart thing to do when first posting. Because troubleshooting is the obvious smart thing to do before doing so, and you did none so...
Obviously.. you just needed to take a few minutes to troubleshoot, which you didn't. If that's not lazy...
When it's only related to NNEDI3? When it's only happening on 32 bit players? When hardly anyone else is having the same issue?
C'mon now.. where are all the arrows pointing?
That's rich considering how you chose to repond first, but whatever.
375.95, Windows 10 14393.447, GTX 960 madVR 0.91.1
Now just do what I said and uninstall your drivers properly and try at least a few different previous versions if not more if you care.
Thing is you shouldn't really be using a 32 bit player without good reason anyway which I'll assume you're not now and hence no more issue.. but if you were interested in resolving it, that's where I'd start.
I'd probably reset madVR to defaults too if previous drivers versions changed nothing.
Old 23rd November 2016, 07:59   #40633  |  Link
MariaX9
I use soften edges 2 atm.
MariaX9 is offline   Reply With Quote
Old 23rd November 2016, 08:09   #40634  |  Link
Smithy
DXVA2 Copy Back, ED2 + colored + change, Fullscreen Window Mode (8 backbuffer) D3D9 old path, CPU64/GPU24
no General Settings Checked, no Image Enhancements Checked and no Trade Quality for Performence Checked
reduce Banding High/High, reduce Ringing only
Chroma ReconSoft SR2, Image Upscaling Jinc AR SL, Image Downscaling Bicubic 150 AR LL
SD 720x404 25p -> 1080p60 Smoothmotion
Jinc AR SL http://pix.defcon5.biz/images/79967370398173641729.png -> 9ms
Jinc AR SL - SR2 AR LL http://pix.defcon5.biz/images/19049767906798837580.png -> 14,5ms
SXBR AB25 -> SR2 AR LL http://pix.defcon5.biz/images/37724967688991784662.png -> 16ms
SXBR AB25 Quadruple -> Down http://pix.defcon5.biz/images/22247513489246501043.png -> 18,5ms
NGU Low/Low se1 -> http://pix.defcon5.biz/images/02571542679210162091.png -> 13,5ms
NGU Med/Med se1 -> http://pix.defcon5.biz/images/49239113436890867062.png -> 16ms
NGU High se1 / Jinc AR SL -> ~20,5ms
NGU High/Low se1 -> ~20,5ms
NGU High/Med se1 -> ~23ms
NGU High/High se1 -> http://pix.defcon5.biz/images/73322545513825247537.png -> ~37-62ms
NGU Quadruple High/High se1 -> Down http://pix.defcon5.biz/images/20754926886660168998.png -> 160ms
32bit Vista SP2 (DX11 Platform Update), Nvidia GTX960 4GB AMP (365.19), 1. 27' FHD Benq / 2. 65' UHD HDR Sony XE93, madVR 0.92.17, LAV 0.73.1, MPC-HC 1.8.3
Smithy is offline   Reply With Quote
Old 23rd November 2016, 08:25   #40635  |  Link
ts1
Congrats, madshi! By looking at the comparison pictures, the envelope is pushed a little further. The results are amazing, mainly with good sources. I wonder how it would perform with retro games!
I suppose it'll stay closed source undefinitly, right? (I hope someday it'll be released.)
Is it totally based on shaders? Multipasses? Multialgorithms or is it just one algorithm?
I'm pretty sure it is based on this paper. It is implemented in python here and partly here.
ts1 is offline   Reply With Quote
Old 23rd November 2016, 09:07   #40636  |  Link
leeperry
Kid for Today
Originally Posted by HillieSan View Post
If I set the display to 23 or 24 fps for a 24 fps movie then I still get judder. Same problem with 59 and 60 fps. Only bluesky fps solves this. Any idea what the problem can be?
It takes at least 72 actual fps to fool the visual cortex FWIR and fighter pilots would be able to see up to 100fps so don't expect miracles but IME judder becomes a lot more bearable if it comes with perfect timing using Reclock + mVR's 60Hz FRC + both chroma and luma SR. Both kinds of SR together sharpen up motion blur and much improve motion smoothness to my eyes, like the LSF Avisynth plugin did IME ages ago. I can't always afford luma SR on 720p but chroma SR alone still helps.
The higher the refresh rate the better eventually, I really liked 100Hz FRC on CRT's and can hardly wait for 144Hz FRC on the BenQ EX3200R
Old 23rd November 2016, 09:12   #40637  |  Link
sauma144
@madshi
NGU luma doubling is just amazing!
I think add grain and soften edges should be always on.
However for 30hz/60hz (mostly from youtube) video files, my laptop can't handle NGU low luma doubling.
Are you working on a NGU luma upscaler (not doubler)?
Is there any chance to get a NGU as fast as Jinc? Spline3?
sauma144 is offline   Reply With Quote
Old 23rd November 2016, 10:02   #40638  |  Link
madshi
Originally Posted by Kotik View Post
Either I am doing something totally wrong or things are not supposed to work the way I expect them to.
I ripped countless of times my Avatar 3D BluRay disc with latest MakeMKV v1.10.2 and yet the 3D subtitles are not working properly, for that matter they are not working properly even when I directly play the movie from my disc.
The 3D effects of the movie most of the time cut through the subtitles, and it doesn't matter which subtitle language I am using.
Maybe you can create a small sample which demonstrates the problem, using the latest MakeMKV version?
Thanks!
I wanted an algo which reconstructs lines correctedly without any bloating and there simply wasn't anything available (except very slow neural networks like waifu2x), so I finally created my own.
Although I wanted to have a rudimentary support for "decimated" sources (pixel art, or images downscaled with nearest neighbor sampling), my main target was to get the best out of high-quality sources. So I suppose pixel art / games probably isn't where NGU shines.
It's just one PS3.0 shader algorithm with multiple passes (number of passes depends on quality level).
No plans to open source it any time soon, unfortunately. I'm sorry about that. If I could just share it with you, for game playback, and could be 100% sure nobody else (except me) would ever use it for any other purpose, I would share it in a heartbeat. But I don't think sharing is possible without my "competition" getting access to it, too.
Really? I thought waifu2x would do much better with pixel art!
Some screenshots would be nice. With SR4, if you don't mind, so I can see if SR really handles this better than NGU.
But I do agree, if you have sources with high compression artifacts, NGU will try to interpret the artifacts as important image detail. The current NGU version really needs high quality sources to shine.
No, not at all. If my algo were based on that paper, it would be named after it instead of "NGU". I wouldn't touch that paper with a ten-foot pole, considering that it was written by MagicPony and then bought by Twitter and could potentially be burdened with patents. I specifically excluded that paper from my research, just to be safe.
My algo is not based on any one specific paper. As I said before, I combined ideas from several papers, and added a couple ideas of my own.
Old 23rd November 2016, 10:46   #40639  |  Link
cork_OS
cork_OS's Avatar
Since NGU doesn't benefit from SuperRes, is possible/useful to apply SuperRes only to the last upscale step (Jinc/C-R etc.), after NGU?
Maybe similar <to waifu2x> results/quality could be possible with NGU, too, when doing proper noise/artifact reduction before upscaling. I don't know, but something like this not likely to come to madVR soon.
Unfortunately, I have a lot of noisy/blocky SD stuff. Which AviSynth deblocker/denoiser could be used for real-time NGU preprocessing?
cork_OS is offline   Reply With Quote
Old 23rd November 2016, 10:58   #40640  |  Link
ryrynz
ryrynz's Avatar
I know NNEDI3 might be hard to beat in the lower source quality arena but still.. I await what may be cooked up from NGU to possibly replace it in future.
I wouldn't be surprised if this was perhaps a little higher on madshi's todo list. I have no doubt we'll see something in future.
I've always been quite partial to Didee's double Fluxsmooth on noisier sources.
FluxSmoothST(12,4).FluxSmoothT(4).Merge(last,0.49)
The thing is though with how NGU picks things up it'd be hard to avoid the issues it creates with low quality sources without killing what little there is of the detail in the picture.
Might need a combination of filters to combat this. Certainly the best thing you can do right now is soften edges and use a soft scaler and avoid extra sharpening.
